Saturday,03,October,2020,23:42:18:42444
-- Windows Based VAG/VAS Emulator Running on Windows 10 x86
Version: 19.6.0.2 HEX-V2 : 0.4505.4
Workshop Code: 123 12345 000001
VIN: WAUZZZ8K6DA039714 License Plate: FP12ATO
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CJCA) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 AC HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9977
Revision: 45H25---
Coding: 12194012242401080000
Shop #: 26483 002 1048576
Dataset: EV_ECM20TDI01103L906018AC 003006
ROD: EV_ECM20TDI01103L906018AC.rod
VCID: 6B80CD01330FAC9F0F3-803E
Address 03: Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Coding: 161544
Shop #: 06334 000 00000
VCID: 005A8AAD2A095FC7CA1-8054
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 FC HW: 8K0 907 064 FC
Component: BCM2 2.0 H10 0602
Coding: 03B20000000000000000
Shop #: 06335 000 00000
VCID: 76B6EC7578CD6177E0D-8022
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0512000020603012
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV H40 0046
Serial number: 2312000039309006
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AC HW: 8K2 820 043 AC
Revision: D0000000 Serial number: 01180320120860
Coding: 342402E000
VCID: 6A8EC8053C75B597745-803E
00457 - Central Electronics Control Module / (J519)
Reset counter: 97
Mileage: 255234 km
Date: 2020.07.31
Time: 14:02:10
Part No SW: 8K0 907 063 DC HW: 8K0 907 063 AC
Component: BCM1 1.0 H14 0103
Revision: 03014001 Serial number: 00000392564001
Coding: 290000308034A7C00081000000001F1F001D060827080201000008000000020000000024000000
Shop #: 21702 000 1048576
VCID: 73B0D5616BBF745FC73-8026
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 170312 H06 0070
Serial number: SWF12030175768
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20202095
Coding: 02005D
Component: E1 - H03 0031
Serial number: 00000000000803120146
Component: AQ_Hum_Sensor H02 0002
Serial number: 25588B16000000000001
Reset counter: 97
Mileage: 255234 km
Date: 2020.07.31
Time: 14:01:52
01229 - A/C Humidity Sensor (G260)
Reset counter: 97
Mileage: 255234 km
Date: 2020.07.31
Time: 14:01:52
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD91U3U
Coding: 30534435363030303030554A3052384B3053
Shop #: 10714 002 1048576
Dataset: EV_AirbaECUVWAUDI010 003010
VCID: 48CA528D4239A787421-801C
Serial number: 6334MSME6C40563BK
Serial number: 6344MSME6D7110709
Serial number: 6352QSME490F4D66Y
Serial number: 6362QSME420F4652G
Serial number: 63732SME250F0D60/
Serial number: 63832SME0C100D7E4
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120322000487
Coding: 000017
VCID: 4FF87991A7D770BF03B-801A
Component: E221 - MFL H03 0003
Address 17: Instruments
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y123050484
Coding: 00CF07FF00
VCID: 3FD849511777E03FF3B-806A
Serial number: 9813927001
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 12076000880021200181
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 94
Mileage: 255135 km
Date: 2020.07.26
Time: 20:43:40
Bin. Bits: 11111
Voltage: 14.40 V
Count: 6
Bin. Bits: 10000
Reset counter: 67
Mileage: 255369 km
Date: 2020.08.13
Time: 23:09:24
Bin. Bits: 11111
Voltage: 12.90 V
Count: 6
Text: FF30740C00028100
Text: 0000000000000000
Raw, Form. N/A: 000 000 000
Part No SW: 8K0 959 793 Q HW: 8K0 959 793 Q
Component: FA H02 0506
Revision: Serial number: 0000026666617
Coding: 011002204001410001
VCID: 4EC66495A0DD79B708D-801A
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0005422690
Coding: 100000000001
Shop #: 62635 000 1048576
Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 3432167D2EB133671E9-8060
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
[Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit]
Reset counter: 108
Mileage: 255617 km
Date: 2020.10.29
Time: 15:37:10
Write only channel
Revision: 00002001 Serial number: 0172315979
Coding: 013F062220B900408020023680000000
Shop #: 12345 123 00001
Component: BACKUP HO H05 1501
Part No SW: 8K0 959 792 Q HW: 8K0 959 792 Q
Component: BF H02 0506
Revision: Serial number: 0000026073863
VCID: 4DC46399ADDB42AF717-8018
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: -4 H01 0001
Revision: -------- Serial number: 00000000037009
Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 36362C7538CD217720D-8062
Part No SW: 4G0 035 061 A HW: 4G0 035 061
Component: Radio U DAB H60 V939
Revision: AB001007 Serial number: 109G%0E7942049
Coding: 010103020100000001
Shop #: 06325 000 00000
VCID: 1B60DDC1A3AF9C1F3F3-804E
02981 - Connection between Radio and Impedance Converter 1
Reset counter: 97
Voltage: 10.50 V
02982 - Connection between Radio and Impedance Converter 2
Reset counter: 97
Voltage: 10.50 V
Reset counter: 54
Mileage: 255369 km
Date: 2020.08.13
Time: 23:09:20
Reset counter: 94
Mileage: 255369 km
Date: 2020.08.13
Time: 23:09:20
Reset counter: 94
Bin. Bits: 00000000 00000001
Part No SW: 8R2 035 652 A HW: 8R2 035 652
Component: B-BN-EU H62 0175
Revision: -------- Serial number: 147C%0C7507929
Coding: 01010101000681ED01800B4E000000030000
VCID: 323E1065D4253D570C5-8066
Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Serial number: 9465C-0C2519347
Subsystem 2 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Serial number: 00000001101428
Reset counter: 71
Mileage: 256349 km
Date: 2020.11.02
Time: 15:29:33
Voltage: 12.30 V
Reset counter: 94
Mileage: 255302 km
Date: 2020.08.06
Time: 13:46:13
Voltage: 12.30 V
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: HL H01 0506
Revision: Serial number: 0000026554811
Coding: 010002204001210001
VCID: 43D045A17B9F84DF973-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: HR H01 0506
Revision: Serial number: 0000026554814
End----------(Elapsed Time: 01:40, VBatt start/end:
