Hello guys,
I want to retrofit seat heating in a Passat B8. I added all the wiring and do the adaptation but still doesn't work.
Can somebody tell me if the BCM support heating seat or i need to replace it?
Thanks for your help!
Saturday,23,January,2021,10:50:57:32554
VCDS Version: 20.12.0.1 (x64) HEX-NET CB: 0.4529.4
Workshop Code: 022 21992 002029
VIN: WVWZZZ3CZHE043853 License Plate:
Mileage: 82600km-51325mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZHE043853 Mileage: 82600km-51325miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ES HW: 04L 907 309 R
Component: R4 2.0l TDI H23 1989
Revision: B5H23---
Coding: 0119003203451D083000
Shop #: WSC 05311 115 00313
ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
VCID: 7F4EF61AE682567C7B-802A
20001 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [039] - Malfunction / Open Circuit
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:45
Engine RPM: 767.50 /min
Normed load value: 33.3 %
Coolant temperature: 46 °C
Intake air temperature: 31 °C
Voltage terminal 30: 14.940 V
Oxygen sensor bank 1 after oxi cat: signal qual. pump flow controller: 13
Oxyg.sensor bank 1 after oxi cat: signal quality temp regulator: 13
Oxygen sensor bank 1 after oxi cat: electric. corrected Pump current: 0.0000000 A
Oxygen sensor bank 1 after oxi cat: heater activation: 1.801 %
O2 sensor bank 1 dwnstrm oxi cat: adjustable resistor value: 0.0 Ohm
Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0203
Part No SW: 5Q0 614 517 CC HW: 5Q0 614 517 AG
Component: ESC H62 0637
Revision: 00000000 Serial number: 62076000001239
Coding: 0EEC6A8F34240B6F477F060541C64970562CD0E2608292713460F078C00202
Shop #: WSC 21992 022 02029
ROD: EV_Brake1UDSContiMK100IPB_035.rod
VCID: 74A42936DFC4052416-8020
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0412225327
Coding: 002F0F060F
ASAM Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB.rod
VCID: 3B36C20AB21A8A5C17-806E
Part No SW: 5G0 907 044 BJ HW: 5G0 907 044 BJ
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020104202100011015500000101802
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 70AC2526ABDC3904F2-8024
197634 - Temperature Sensor for Rear Vent
B1089 15 [009] - Open or Short to Plus
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
Voltage terminal 30: 14.7 V
Outside temperature: 2.5 °C
459015 - Databus
[Feuchtesensor innen - kein Signal/Kommunikation]
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
263426 - Air Quality Sensor
B10AF 31 [009] - No Signal
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
System run time-Engine running time: 84 s
System run time-Terminal 15 on: 87 s
1048835 - Functionality limited due to Engine Control Module
P1719 00 [009] - -
[PTC-Reduzierung durch MSG]
Reset counter: 235
Mileage: 82600 km
Date: 2020.09.09
Time: 00:46:32
Voltage terminal 30: 14.9 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Target value: 3
Auxiliary heater: in stages-Specified value for control: 3
655618 - Control/Display Unit for Rear Climatronic
B10AA 31 [009] - No Signal
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
263682 - Exterior Air Quality/Humidity Sensor
B137A 31 [009] - No Signal
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 BF HW: 5Q0 937 086 BF
Component: BCM PQ37BOSCH 032 0222
Revision: -------- Serial number: 8658260616004Y
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017.rod
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150423 042 0607
Serial number: 150428184313
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S6Y16M07D21H15M16S25
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 08 04 2015 00001636
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1618109MV
Serial number: 00000000000036115966
8458 - Bulb for Right DRL
B121E 15 [009] - Open or Short to Plus
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:44
133899 - Voltage Supply; Terminal 30 for Seat Heaters
B1411 13 [009] - Open Circuit
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:25:46
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616170
Coding: 0271061841
Shop #: WSC 05311 115 00086
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000.rod
VCID: 0D525CD2DC2E74EC79-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 2A00608351FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3424E9369F444524D6-8060
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSPEE1GHH
Coding: 98FCC0C0000000005C5400CC008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EB00B1EE1885F7470-802A
Left seat belt tensioner:
Serial number: 3G2857705E0019R00764
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G2857706E0216Q00705
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 507 16
Serial number: 3576U000000C59143C1C
Subsystem 4 - Part No SW: ----------- HW: 454 002 107 16
Serial number: 3586U000000DE3249B1N
Subsystem 5 - Part No SW: ----------- HW: 454 801 107 16
Serial number: 3516R570F010C000000$
Subsystem 6 - Part No SW: ----------- HW: 454 801 707 16
Serial number: 3526R982A030C0000001
Subsystem 7 - Part No SW: ----------- HW: 454 800 407 16
Serial number: 3556V0B761F0B000000F
Part No SW: 3Q0 953 521 CS HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160607500528
Coding: 0000
ROD: EV_SMLSVALEOMQB.rod
VCID: 03467AEA8A6A329C1F-8056
Part No SW: 3G0 920 751 A HW: 3G0 920 751 A
Component: KOMBI 301 6420
Coding: 07A501102780000801886B011001000000000000
VCID: 23061A6A2AAAD29C3F-8076
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 20071610801073
Coding: 030300045F087300FB00005C080F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7CB40116F7944D645E-8028
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160001411190126284
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001607290049
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000157185012
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA2022A0D6300CFD-8024
Component: TSG FS 020 0041
Serial number: 060716EG41263A
Coding: 00350A20D000028000001000
VCID: 43C6BAEACAEAF29C5F-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000004246929
65799 - Door Warning / Entry Lighting
B1775 01 [009] - Electrical Failure
Reset counter: 235
Mileage: 82600 km
Date: 2020.09.09
Time: 00:47:17
65621 - Locking Module for Central Locking
B122F 29 [009] - Signal Implausible
Reset counter: 235
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000845757
Coding: 01010010005000
Shop #: WSC 00015 115 00303
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D32CC12AC0E846C29-8068
Component: TSG BFS 020 0041
Serial number: 270616EFQ0239A
Coding: 00350020DE00028000001000
VCID: 42C8BFEED5F0FB9454-8016
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000004271055
Coding: 090000
65578 - Motors for Central Locking
B122B 12 [009] - Short to Plus
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:20:28
65598 - Motor for mirror fold-in
B11F6 01 [009] - Electrical Failure
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Coding: 02840101FF00000051110101008808001F0100C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 312AE0226056700CBD-8064
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJU033UH
Subsystem 2 - Part No SW: 3G0 919 866 S HW: -----------
Component: ECE1 2016/17 --- 0635
0005 - Antenna Amplifier 1 for Radio
B126D 13 [009] - Open Circuit
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:42
Voltage terminal 30: 14.6 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 51 dBµV
0006 - Antenna Amplifier 2 for Radio
B126E 13 [009] - Open Circuit
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:41
Voltage terminal 30: 14.4 V
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 214 dBµV
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [009] - Open Circuit
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:42
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 3.357312
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 2.632250
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 234
Mileage: 82600 km
Date: 2020.09.09
Time: 00:17:42
End----------(Elapsed Time: 01:28, VBatt start/end: 14.8V/14.8V)-----------
