99 VW Passat Transmission in Limp Mode
rhodebump
Verified VCDS-Lite User
Pittsburgh, PA, USA
C?ID=424511
If I clear the codes, the transmission gear indicator on the dashboard appears normal and no transmission faults occur on scan. If I start the car, transmission indicator lights up showing limp mode.
I replaced the TCM on this car a couple of years ago and put the module in a plastic bag. It did get damp down there but I don't think the TCM got damaged this time. I took the TCM apart and did not find any rust or water in the unit.
I appreciate the help. I would be willing to take it to a garage for repair, but nobody wants to touch a '99 :(
I did replace the shift selector solenoid this past weekend since I thought that was bad. Before I replaced it, I measured 14V coming in (car was on charger) and got a low reading on resistance. But the N110 code is still there (after the replacement)
Here is the most recent scan:
VCDS-Lite Version: Release 1.2
Thursday, 21 January 2021, 13:13:05:16989
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
Address 01: Engine       Labels: None
   Controller: 8D0 907 557 P
   Component: 1.8L R4/5VT MOTR AT D04
   Coding: 06051
   Shop #: WSC 05311
   VCID: 3D0DF8AA2469
18010 -  Power Supply Terminal 30: Voltage too Low
            P1602 - 35-00 -   -
Readiness: 0110 0101
Address 02: Auto Trans       Labels: 01V-927-156.LBL
   Controller: 8D0 927 156 BM
   Component: AG5 01V 1.8l5VT USA 8508
   Coding: 00000
   VCID: 79852CBA70C1
01236 -  Shift Selector Locking Solenoid (N110)
            31-00 -  Open or Short to Ground
Address 03: ABS Brakes       Labels: 8E0-614-111-ABS.LBL
   Controller: 8E0 614 111 B
   Component: ABS/EDS 5.3 FRONT   D00
   Coding: 0273004283
   Shop #: BB 24332
   VCID: 1D4D182A84A9
Address 15: Airbags       Labels: 1J0-909-60x-VW3.LBL
   Controller: 1J0 909 607 B
   Component: AIRBAG VW3 S        V04
   Coding: 00066
   Shop #: WSC 05311
   VCID: 2C2BC5EECF13
Address 17: Instruments       Labels: 3B0-919-xxx-17.LBL
   Controller: 3B1 919 930 G
   Component: B5-KOMBIINSTR. VDO V01
   Coding: 06242
   VCID: 2C2BC5EECF13
01039 -  Coolant Temperature Sensor (G2)
            30-10 -  Open or Short to Plus - Intermittent
Address 46: Central Conv.       Labels: 1J0-959-799.LBL
   Controller: 1J0 959 799 AJ
   Component: 6W Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 04940
   VCID: 867FD746B13F
15 Faults Found:
01329 -  Convenience System Data Bus in Emergency Mode
            35-10 -   - - Intermittent
01334 -  Door Control Module; Rear Right (J398)
            49-10 -  No Communications - Intermittent
01333 -  Door Control Module; Rear Left (J388)
01332 -  Door Control Module; Passenger Side (J387)
01331 -  Door Control Module; Driver Side (J386)
            53-10 -  Supply Voltage Too Low - Intermittent
00928 -  Locking Module for Central Locking; Front Driver Side (F220)
            27-10 -  Implausible Signal - Intermittent
00943 -  Heated Exterior Mirror; Driver Side (Z4)
            35-00 -   -
01358 -  Internal Central Locking Switch; Driver Side (E150)
00914 -  Window Regulator Switch; Rear Left; Driver (E53)
00915 -  Window Regulator Switch; Rear Right; Driver (E55)
00929 -  Locking Module for Central Locking; Front Passenger Side (F221)
00944 -  Heated Exterior Mirror; Passenger Side (Z5)
            35-00 -   -
00930 -  Locking Module for Central Locking; Rear Left (F222)
00931 -  Locking Module for Central Locking; Rear Right (F223)
Address 56: Radio       Labels: 1J0-035-18x-56.LBL
   Controller: 1J0 035 180 C
   Component:  RADIO             0002
   Coding: 00401
   Shop #: WSC 05311
   VCID: 1F3122228EA5
End   --------------------------------------------------------------------------------------------------
Have you verified the wiring between the Shift Selector Locking Solenoid and the TCM?
rhodebump
Pittsburgh, PA, USA
C?ID=424511
I put a voltmeter on the wires going to the solenoid.
There is always 12V running to the shift selector solenoid when ignition on (14v when engine running).
The voltage drops down to zero when I hit the brake pedal.
I thought since this was the expected behavior, the wiring would be good. Do you think I should investigate this wiring more?
thank you @Uwe
At the solenoid, it might be. But note the fault says "Open or Short to Ground". So you need to verify that the TCM is seeing that. A break in the wire between there and the TCM would prevent it, right?
rhodebump
Pittsburgh, PA, USA
C?ID=424511
Thanks for explaining that. Time to buy some kerosene and get back to work. Thanks again
rhodebump
Pittsburgh, PA, USA
C?ID=424511
Is the schematic for the TCM pins documented anywhere? There's a lot of wires!
