2004 r32 3.2l BJS maps
Jef
HQ
Thursday,19,March,2015,19:16:26:47536
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WVWSR61J84W047451   License Plate:
Mileage: 155340km-96523mi   Repair Order:
          76
VIN: WVWSR61J84W047451   Mileage: 155340km-96523miles
Address 01: Engine        Labels: 022-906-032-BJS.lbl
   Part No SW: 022 906 032 EG    HW: 14. 4.0 3
   Component: MOTRONIC ME7.1.1G   5626
   Coding: 0000132
   Shop #: WSC 31414 000 00000
   VCID: D4EB7F1D76427F811A7-5184
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 P
   Component: ESP ALLRAD MK60     0101
   Coding: 0023049
   VCID: B7312891C7F4B4991F5-5184
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11200
   Shop #: WSC 31414
   VCID: A105E6C92970DA29C11-51CE
   Part No: 1C0 909 605 F
   Component: 17 AIRBAG VW61 0108 0003
   Coding: 12599
   Shop #: WSC 31414
   VCID: A711F8D1475424198F5-5160
   Part No: 1J0 920 927 A
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 15230
   VCID: A915FEE951401269991-5160
   WVWSR61J84W047451     VWZ7Z0C7769815
01176 - Key
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 31414
   VCID: F0A3D38DB21A23A11EF-5160
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 D
   Component: HALDEX LSC  ECC     0011
   VCID: A105E6C92970DA29C11-4B3C
End-------------------------(Elapsed Time: 06:53)--------------------------
Cold, engine off
;SW:022-906-032-EG   HW:14.-4.0-3 ---  Engine
;Component:MOTRONIC ME7.1.1G   5626, Coding:0000132
;Thursday,19,March,2015,19:05:43:47536
;VCDS Version: Release 14.10.2  Data version: 20150311
;VCID: D4EB7F1D76427F811A7-5184
1,0,Basic Functions,
1,1,Engine Speed,,
;0 /min,RPM,
1,2,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
1,3,Lambda Control,Bank 1,
;0.0 %,Lambda,
1,4,Lambda Control,Bank 2,
;0.0 %,Lambda,
2,0,Basic Functions (Mass Air Flow),
2,1,Engine Speed,,
;0 /min,RPM,
2,2,Engine Load,,
;100.0 %,Load,
2,3,Injection Timing,,
;0.00 ms,Inj. On Time,
2,4,Mass Air Flow,,
;0.00 g/s,Mass Flow,
3,0,Basic Functions (Mass Air Flow),
3,1,Engine Speed,,
;0 /min,RPM,
3,2,Mass Air Flow,,
3,3,Throttle Position,Sensor (G187),
;6.7 %,Load,
3,4,Ignition,Timing Angle,
;0.0 °BTDC,Ign. Timing,
4,0,Basic Functions,
4,1,Engine Speed,,
;0 /min,RPM,
4,2,Supply Voltage,,Specification: 12.0...15.0 V
;11.270 V,Voltage,
4,3,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
4,4,Intake Air,Temperature,
;9.0°C,Temperature,
5,0,Basic Functions,
5,1,Engine Speed,,
;0 /min,RPM,
5,2,Engine Load,,
;100.0 %,Load,
5,3,Vehicle Speed,,
;0.0 km/h,Speed,
5,4,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
;Idle, ,
6,0,Basic Functions,
6,1,Engine Speed,,
;0 /min,RPM,
6,2,Engine Load,,
;100.0 %,Load,
6,3,Intake Air,Temperature,
;9.0°C,Temperature,
6,4,Altitude,Correction Factor,
;-4.7 %,Lambda,
8,0,Basic Functions,
8,1,Brake Condition,,Display Range: Operated/Not Oper.
;Not Oper., ,
8,2,Vacuum Pump,Condition,Display Range: Pump ON/Pump OFF
;11.270 V,Voltage,
8,3,Brake Booster,Pressure,
;970.0 mbar,Absolute Pres.,
8,4,,,
9,0,,
9,1,,,
9,2,,,
9,3,,,
;800.0,(no units),
9,4,,,
10,0,Ignition,
10,1,Engine Speed,,
;0 /min,RPM,
10,2,Engine Load,,
;100.0 %,Load,
10,3,Throttle Position,Sensor (G187),
;6.7 %,Load,
10,4,Ignition,Timing Angle,
11,0,Ignition,
11,1,Engine Speed,,
;0 /min,RPM,
11,2,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
11,3,Intake Air,Temperature,
;9.0°C,Temperature,
11,4,Ignition,Timing Angle,
14,0,Ignition (Misfire Recognition - Total),
14,1,Engine Speed,,
;0 /min,RPM,
14,2,Engine Load,,
;100.0 %,Load,
14,3,Misfire,(total),Specification: 0
;0,Count,
14,4,Misfire,Recognition,Display Range: Disabled/Enabled
;Disabled, ,
15,0,Ignition (Misfire Recognition - Cylinder 1-3),
15,1,Misfire Counter,Cylinder 1,
;0,Count,
15,2,Misfire Counter,Cylinder 2,
;0,Count,
15,3,Misfire Counter,Cylinder 3,
;0,Count,
15,4,Misfire,Recognition,Display Range: Disabled/Enabled
;Disabled, ,
16,0,Ignition (Misfire Recognition - Cylinder 4-6),
16,1,Misfire Counter,Cylinder 4,
;0,Count,
16,2,Misfire Counter,Cylinder 5,
;0,Count,
16,3,Misfire Counter,Cylinder 6,
;0,Count,
16,4,Misfire,Recognition,Display Range: Disabled/Enabled
;Disabled, ,
18,0,RPM/Load Barriers,
18,1,Lower,RPM Barrier,
;0 /min,RPM,
18,2,Upper,RPM Barrier,
;0 /min,RPM,
18,3,Lower,Load Barrier,
;0.0 %,Load,
18,4,Upper,Load Barrier,
;0.0 %,Load,
20,0,Ignition (Timing Retardation Cylinder 1-4),
20,1,Timing Retardation,Cylinder 1,
;0.0°KW,Idle Stabilization,
20,2,Timing Retardation,Cylinder 2,
20,3,Timing Retardation,Cylinder 3,
20,4,Timing Retardation,Cylinder 4,
21,0,Ignition (Timing Retardation Cylinder 5-8),
21,1,Timing Retardation,Cylinder 5,
21,2,Timing Retardation,Cylinder 6,
21,3,,,
21,4,,,
22,0,Ignition (Timing Retardation Cylinder 1 && 2),
22,1,Engine Speed,,
;0 /min,RPM,
22,2,Engine Load,,
;100.0 %,Load,
22,3,Timing Retardation,Cylinder 1,
22,4,Timing Retardation,Cylinder 2,
23,0,Ignition (Timing Retardation Cylinder 3 && 4),
23,1,Engine Speed,,
;0 /min,RPM,
23,2,Engine Load,,
;100.0 %,Load,
23,3,Timing Retardation,Cylinder 3,
23,4,Timing Retardation,Cylinder 4,
24,0,Ignition (Timing Retardation Cylinder 5 && 6),
24,1,Engine Speed,,
;0 /min,RPM,
24,2,Engine Load,,
;100.0 %,Load,
24,3,Timing Retardation,Cylinder 5,
24,4,Timing Retardation,Cylinder 6,
26,0,Ignition (Knock Control Cylinder 1-4),
26,1,Voltage,Cylinder 1,
;3.510 V,Voltage,
26,2,Voltage,Cylinder 2,
;3.510 V,Voltage,
26,3,Voltage,Cylinder 3,
;3.510 V,Voltage,
26,4,Voltage,Cylinder 4,
;3.510 V,Voltage,
27,0,Ignition (Knock Control Cylinder 5-8),
27,1,Voltage,Cylinder 5,
;3.510 V,Voltage,
27,2,Voltage,Cylinder 6,
;3.510 V,Voltage,
27,3,,,
27,4,,,
28,0,Ignition (Knock Sensor Test - Short Trip),
28,1,Engine Speed,,
;0 /min,RPM,
28,2,Engine Load,,
;100.0 %,Load,
28,3,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
28,4,Result,,Display Range: Test ON/Test OFF/Sys. OK/Sys. not OK
Specification: Sys. OK
;Test OFF, ,
30,0,Lambda Control (Sensor Status),
30,1,Bank 1,Sensor 1,
;   00000,Bin. Bits,
30,2,Bank 1,Sensor 2,
;    0000,Bin. Bits,
30,3,Bank 2,Sensor 1,
;   00000,Bin. Bits,
30,4,Bank 2,Sensor 2,
;    0000,Bin. Bits,
31,0,Lambda Control (Lambda Sensor Voltages),
31,1,Lambda Sensor,B1-S1 (actual),
;1.000,Lambda Factor,
31,2,Lambda Sensor,B1-S1 (specified),
;0.797,Lambda Factor,
31,3,Lambda Sensor,B2-S1 (actual),
31,4,Lambda Sensor,B2-S1 (specified),
32,0,Lambda Control (Mixture Adaptation),
32,1,Adaptation (Idle),Bank 1 Sensor 1,
;0.8 %,Lambda,
32,2,Adaptation (Partial),Bank 1 Sensor 1,
;-0.8 %,Lambda,
32,3,Adaptation (Idle),Bank 2 Sensor 1,
;0.8 %,Lambda,
32,4,Adaptation (Partial),Bank 2 Sensor 1,
;-3.1 %,Lambda,
33,0,Lambda Control,
33,1,Lambda Control,Bank 1 Sensor 1,
;0.0 %,Lambda,
33,2,Sensor Voltage,Bank 1 Sensor 1,
;1.540 V,Voltage,
33,3,Lambda Control,Bank 2 Sensor 1,
;0.0 %,Lambda,
33,4,Sensor Voltage,Bank 2 Sensor 1,
;1.540 V,Voltage,
34,0,Lambda Control (Aging Check Bank 1),
34,1,Engine Speed,,
;0 /min,RPM,
34,2,Catalytic Converter,Temperature,
;55.0°C,Temperature,
34,3,Dynamic Factor,Bank 1 Sensor 1,
;2.06,(no units),
34,4,Result,Lambda Aging,Display Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK
Specification: B1-S1 OK
;Test OFF, ,
35,0,Lambda Control (Aging Check Bank 2),
35,1,Engine Speed,,
;0 /min,RPM,
35,2,Catalytic Converter,Temperature,
35,3,Dynamic Factor,Bank 2 Sensor 1,
;2.06,(no units),
35,4,Result,Lambda Aging,Display Range: Test ON/Test OFF/B2-S1 not OK/B2-S1 OK
Specification: B2-S1 OK
;Test OFF, ,
36,0,Lambda Control (Sensor Readiness - After Catalyst),
36,1,Sensor Voltage,Bank 1 Sensor 2,
;0.435 V,Voltage,
36,2,Result,Lambda Availability,Display Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK
Specification: B1-S2 OK
;Test OFF, ,
36,3,Sensor Voltage,Bank 2 Sensor 2,
;0.440 V,Voltage,
36,4,Result,Lambda Availability,Display Range: Test ON/Test OFF/B2-S2 not OK/B2-S2 OK
Specification: B2-S2 OK
;Test OFF, ,
37,0,Lambda Control (Delta Lambda Bank 1),
37,1,Engine Load,,
;100.0 %,Load,
37,2,Sensor Voltage,Bank 1 Sensor 2,
;0.435 V,Voltage,
37,3,Delta Lambda,Bank 1 Sensor 2,
;0.000,Difference,
37,4,Result,,Specification: Test ON/Test OFF/B1-S1 OK/B1-S1 n.OK
;Test OFF, ,
38,0,Lambda Control (Delta Lambda Bank 2),
38,1,Engine Load,,
;100.0 %,Load,
38,2,Sensor Voltage,Bank 2 Sensor 2,
;0.440 V,Voltage,
38,3,Delta Lambda,Bank 2 Sensor 2,
;0.000,Difference,
38,4,Result,,Specification: Test ON/Test OFF/B2-S1 OK/B2-S1 n.OK
;Test OFF, ,
39,0,Lambda Control (Sensor Exchange),
39,1,Mass Air Flow,,
39,2,Sensor Voltage,Bank 1 Sensor 2,
;0.435 V,Voltage,
39,3,Sensor Voltage,Bank 2 Sensor 2,
;0.440 V,Voltage,
39,4,Result,Sensor Exchange,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
Specification: Syst. OK
;00000000,Bin. Bits,
41,0,Lambda Sensor Heating Bank 1,
41,1,Resistance,Bank 1 Sensor 1,
;502 ohms,Resistance,
41,2,Heater Condition,,Display Range: Htg. S1 OFF/Htg. S1 ON
;Htg. S1 OFF, ,
41,3,,,
41,4,Heater Condition,,Display Range: Htg. S2 OFF/Htg. S2 ON
;Htg. S2 OFF, ,
42,0,Lambda Sensor Heating Bank 2,
42,1,Resistance,Bank 2 Sensor 1,
42,2,Heater Condition,,Display Range: Htg. S1 OFF/Htg. S1 ON
;Htg. S1 OFF, ,
42,3,,,
42,4,Heater Condition,,Display Range: Htg. S2 OFF/Htg. S2 ON
;Htg. S2 OFF, ,
43,0,Lambda Sensor Aging Bank 1,
43,1,Engine Speed,,
;0 /min,RPM,
43,2,Catalytic Converter,Temperature,
43,3,Lambda Voltage,Bank 1 Sensor 2,
;0.435 V,Voltage,
43,4,Result,Aging,Display Range: Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK
;Test OFF, ,
44,0,Lambda Sensor Aging Bank 2,
44,1,Engine Speed,,
;0 /min,RPM,
44,2,Catalytic Converter,Temperature,
44,3,Lambda Voltage,Bank 2 Sensor 1,
;0.435 V,Voltage,
44,4,Result,Aging,Display Range: Test ON/Test OFF/B2-S2 OK/B2-S2 n.OK
;Test OFF, ,
46,0,Catalytic Conversion Test Bank 1,
46,1,Engine Speed,,
;0 /min,RPM,
46,2,Catalytic Converter,Temperature,
46,3,Catalytic,Conversion,
;0.00,(no units),
46,4,Result,Cat. Conversion,Display Range: Test ON/Test OFF/CatB1 OK/CatB1 n.OK
Specification: CatB1 OK
;Test OFF, ,
47,0,Catalytic Conversion Test Bank 2,
47,1,Engine Speed,,
;0 /min,RPM,
47,2,Catalytic Converter,Temperature,
47,3,Catalytic,Conversion,
;0.00,(no units),
47,4,Result,Cat. Conversion,Display Range: Test ON/Test OFF/CatB2 OK/CatB2 n.OK
Specification: CatB2 OK
;Test OFF, ,
50,0,Engine Speed Increase,
50,1,Engine Speed,(actual),
;0 /min,RPM,
50,2,Engine Speed,(specified),
;800 /min,RPM,
50,3,A/C Readiness,,Display Range: A/C-Low / A/C-High
;A/C-Low, ,
50,4,A/C Compressor,,Display Range: Compr.OFF/Compr.ON
;Compr.OFF, ,
51,0,Engine Speed Increase (Gear shifts),
51,1,Engine Speed,(actual),
;0 /min,RPM,
51,2,Engine Speed,(specified),
;800 /min,RPM,
51,3,Selected Gear,,Display Range: P or N = 0/Gear = 1 - 6/R = 7
;0,Count,
51,4,Supply Voltage,,Specification: 12.0...15.0 V
;11.270 V,Voltage,
52,0,Engine Speed Increase,
52,1,Engine Speed,(actual),Specification (Idle): 640...740 RPM
Specification (Load): 3000...3500 RPM
Display Range: 640...6800 RPM
;0 /min,RPM,
52,2,Engine Speed,(specified),
;800 /min,RPM,
52,3,A/C Readiness,,Display Range: A/C-Low / A/C-High
;A/C-Low, ,
52,4,,,
53,0,Engine Speed Increase (Generator Load),
53,1,Engine Speed,(actual),
;0 /min,RPM,
53,2,Engine Speed,(specified),
;800 /min,RPM,
53,3,Supply Voltage,,Specification: 12.0...15.0 V
;11.270 V,Voltage,
53,4,,,
54,0,Idle Speed Stabilization,
54,1,Engine Speed,,
;0 /min,RPM,
54,2,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
;Idle, ,
54,3,Throttle Position,Sensor (G79),
;0.0 %,Load,
54,4,Throttle Position,Sensor (G187),
;6.7 %,Load,
55,0,Idle Speed Stabilization,
55,1,Engine Speed,,
;0 /min,RPM,
55,2,Idle Regulator,,
;0.0 %,Lambda,
55,3,Idle Stabilization,Self-Adaptation,
;0.6 %,Lambda,
55,4,Operating,Condition,00xxx1 = A/C Compressor ON
00xx1x = Gear engaged
00x1xx = A/C Readiness ON
001xxx = Rear Window Heater ON
;  000000,Bin. Bits,
56,0,Idle Speed Stabilization,
56,1,Engine Speed,(actual),
;0 /min,RPM,
56,2,Engine Speed,(specified),
;800 /min,RPM,
56,3,Idle Regulator,,
;0.0 %,Lambda,
56,4,Operating,Condition,00xxx1 = A/C Compressor ON
;  000000,Bin. Bits,
57,0,Idle Speed Stabilization (Air Condition),
57,1,Engine Speed,(actual),
;0 /min,RPM,
57,2,Engine Speed,(specified),
;800 /min,RPM,
57,3,A/C Compressor,,Display Range: Compr.OFF/Compr.ON
;Compr.OFF, ,
57,4,A/C Compressor,Pressure,
58,0,Engine Mounting,
58,1,Engine Speed,,
;0 /min,RPM,
58,2,Engine Load,,
;100.0 %,Load,
58,3,,,
58,4,,,
60,0,Electronic Throttle Adaptation,
60,1,Throttle Position,Sensor (G187),
;15.6 %,Duty Cycle,
60,2,Throttle Position,Sensor (G188),
;84.4 %,Duty Cycle,
60,3,Adaptation,Steps Counter,Specification: 0
;0,Count,
60,4,Result,Throttle Valve Adp.,Display Range: ADP RUN/ADP OK/ADP ERROR
Specification: ADP OK
;ADP. O.K., ,
61,0,Electronic Throttle,
61,1,Engine Speed,,
;0 /min,RPM,
61,2,Supply Voltage,,Specification: 12.0...15.0 V
;11.270 V,Voltage,
61,3,Throttle Position,Sensor (G187),
;6.7 %,Load,
61,4,Operating,Condition,00xxx1 = A/C Compressor ON
;  000000,Bin. Bits,
62,0,Electronic Throttle,
62,1,Throttle Position,Sensor (G187),
;15.6 %,Duty Cycle,
62,2,Throttle Position,Sensor (G188),
;84.4 %,Duty Cycle,
62,3,Throttle Position,Sensor (G79),
;14.5 %,Duty Cycle,
62,4,Accelerator Pedal,Position  (G185),
;7.0 %,Duty Cycle,
63,0,Electronic Throttle (Kick-Down Adaptation),
63,1,Throttle Position,Sensor (G79),
;14.5 %,Duty Cycle,
63,2,Kick-Down,Adaptation Value,
63,3,Kick-Down,Switch,Display Range: Kick Down
63,4,Kick-Down,Adaptation,Display Range: ADP RUN/ADP OK/ADP ERROR
64,0,Throttle Valve Potentiometer Adaption Values,
64,1,Potentiometer 1,Lower Adaptation,
;0.520 V,Voltage,
64,2,Potentiometer 2,Lower Adaptation,
;4.580 V,Voltage,
64,3,Emergency Air Gap,Potentiometer 1,
;0.800 V,Voltage,
64,4,Emergency Air Gap,Potentiometer 2,
;4.320 V,Voltage,
66,0,Cruise Control System,
66,1,Vehicle Speed,(current),
;0.0 km/h,Speed,
66,2,Pedal Settings,,
;00001000,Bin. Bits,
66,3,Vehicle Speed,(specified),
;0.0 km/h,Speed,
66,4,Switch Settings,,
;00000011,Bin. Bits,
70,0,Emission Reduction (TEV - Basic Setting),
70,1,Evap. Emissions,Sol. Valve (Open),Specification: 0...100 %
;0.0 %,Load,
70,2,Lambda Control,,
;0.0 %,Lambda,
70,3,Evap. Emissions,Sol. Valve (Flow),
70,4,Result,,Display Range: Test ON/Test OFF/TEV OK/TEV not OK
;Test OFF, ,
71,0,Exhaust Reduction (Basic Setting: Leak Diagnostic System),
71,1,Reed Contact,Condition,Display Range: Reed Open/Reed Closed
;Reed Open, ,
71,2,Malfunction Display,,Display Range: minor leak/significant leak/Open circuit
;Abort, ,
71,3,Diagnostic Status,,Display Range: System test/Measurement end
71,4,Result,Leak Test,Display Range: Test ON/Test OFF/Syst. OK/Syst. not OK
;Test OFF, ,
72,0,,
72,1,Reed Contact,Condition,
;Reed Open, ,
72,2,Malfunction,Message,
;Abort, ,
72,3,,,
72,4,Result,,
;Test OFF, ,
73,0,,
73,1,Opening angle,of TVV,
;0.0 %,Load,
73,2,Flush rate,,
;0.0 %,Load,
73,3,Load factor,,
;0.0 %,Lambda,
73,4,TE-Fuel portion,,
;0.0 %,Lambda,
77,0,Emission Reduction (Bank 1),
77,1,Engine Speed,,
;0 /min,RPM,
77,2,Mass Air Flow,,
77,3,Air Mass from,Sec. Air Inj. Bank 1,
;0.0 %,Lambda,
77,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
;Test OFF, ,
78,0,Emission Reduction (Bank 2),
78,1,Engine Speed,,
;0 /min,RPM,
78,2,Mass Air Flow,,
78,3,Air Mass from,Sec. Air Inj. Bank 2,
;0.0 %,Lambda,
78,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
;Test OFF, ,
79,0,,
79,1,Engine Speed,,
;0 /min,RPM,
79,2,Engine Load,,
;100.0 %,Load,
79,3,Flap Bank 1,,
;OFF, ,
79,4,Flap Bank 2,,
80,0,Advanced Control Module Identification I,
80,1,,,
;   <>   09.01.04    <>     <>  0245,RPM,
81,0,Advanced Control Module Identification II,
81,1,VIN & IMMO-ID,,
;WVWSR61J84W047451 VWZ7Z0C7769815   <>   ,VIN & IMMO-ID,
82,0,Advanced Control Module Identification III,
82,1,,,
;0000000000000    <>    000 00 <>  <>,VIN & IMMO-ID,
86,0,Readiness Code I,
86,1,Readiness Bits,,
86,2,Cycle Flags,,
;11111111,Bin. Bits,
86,3,Cycle Flags,,
;01101011,Bin. Bits,
86,4,Cycle Flags,,
;00001011,Bin. Bits,
87,0,Readiness Code II,
87,1,Readiness Bits,,
87,2,Error Flags,,
87,3,Error Flags,,
87,4,Error Flags,,
88,0,Readiness Code III,
88,1,Cycle Flags,,
;11111010,Bin. Bits,
88,2,Cycle Flags,,
;11101111,Bin. Bits,
88,3,Cycle Flags,,
;11001100,Bin. Bits,
88,4,,,
89,0,,
89,1,Distance Driven,with MIL on,
;0,Count,
89,2,Tank Condition,,Display Range: OK/too low
;OK, ,
89,3,,,
89,4,,,
90,0,Continuous Camshaft Adjustment (Bank 1 - Exhaust),
90,1,Engine Speed,,
;0 /min,RPM,
90,2,Duty Cycle,,
;20.0 %,Load,
90,3,Adjustment Bank 1,(specified),
90,4,Adjustment Bank 1,(actual),
91,0,Continuous Camshaft Adjustment (Bank 1 - Intake),
91,1,Engine Speed,,
;0 /min,RPM,
91,2,Duty Cycle,,
;14.9 %,Load,
91,3,Adjustment Bank 1,(specified),
91,4,Adjustment Bank 1,(actual),
93,0,Continuous Camshaft Adjustment (Bank 2 - Intake),
93,1,Engine Speed,,
;0 /min,RPM,
93,2,Duty Cycle,,
;100.0 %,Load,
93,3,Adjustment,(specified),
;-2.0°KW,Idle Stabilization,
93,4,Adjustment,(actual),
;-3.0°KW,Idle Stabilization,
94,0,Continuous Camshaft Adjustment (Intake),
94,1,Adjustment,Bank 1,
94,2,Adjustment,Bank 2,
94,3,Result Bank 1,,Display Range: Test OFF/Test ON/System OK/System Not OK
;Test OFF, ,
94,4,Result Bank 2,,Display Range: Test OFF/Test ON/System OK/System Not OK
95,0,Performance Increase (Intake Manifold Change Over),
95,1,Engine Speed,,Specification: 650...6500 RPM
;0 /min,RPM,
95,2,Engine Load,,Specification: 0...100 %
;100.0 %,Load,
95,3,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
95,4,Switch-Over,Staus,Display Range: IMC-V ON/IMC-V OFF
;IMC-V OFF, ,
96,0,Continuous Camshaft Adjustment (Exhaust),
96,1,Adjustment,Bank 1,
96,2,Adjustment,Bank 2,
96,3,Result Bank 1,,Display Range: Test ON/Test OFF/System OK/System Not OK
Specification: System OK
;Test OFF, ,
96,4,Result Bank 2,,Display Range: Test ON/Test OFF/System OK/System Not OK
98,0,Continuous Camshaft Adjustment (Exhaust - Bank 2),
98,1,Engine Speed,,
;0 /min,RPM,
98,2,Engine Load,,
;20.0 %,Load,
98,3,Adjustment,(specified),
98,4,Adjustment,(actual),
99,0,Lambda Control Shut-Off (Basic Setting),
99,1,Engine Speed,,
;0 /min,RPM,
99,2,Lambda Control,Bank 1,
99,3,Lambda Control,Bank 2,
99,4,Lambda Control,Status,Display Range: O2-Reg.OFF/O2-Reg.ON
;O2-Reg.OFF, ,
100,0,Readiness Code,
100,1,Readiness Bits,,see labelfile
100,2,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
100,3,Time since,Engine Start,
;0.00 s,Time,
100,4,OBD-Status,,see labelfile
;10000000,Bin. Bits,
101,0,Fuel Injection,
101,1,Engine Speed,,
;0 /min,RPM,
101,2,Engine Load,,
;100.0 %,Load,
101,3,Injection Timing,,
101,4,Mass Air Flow,,
102,0,Fuel Injection,
102,1,Engine Speed,,
;0 /min,RPM,
102,2,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
102,3,Intake Air,Temperature,
;9.0°C,Temperature,
102,4,Injection Timing,,
104,0,Start Adaption Values,
104,1,Start Engine,Temperature,
;7.0°C,Temperature,
104,2,Temperature,Adaptation Factor 1,
;28.9 %,Lambda,
104,3,Temperature,Adaptation Factor 2,
;28.9 %,Lambda,
104,4,Temperature,Adaptation Factor 3,
;28.9 %,Lambda,
105,0,Cylinder Shut-Off,
105,1,Engine Speed,,
;0 /min,RPM,
105,2,Engine Load,,
;100.0 %,Load,
105,3,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
105,4,Status,Cylinder Shut-Off,Display Range: ON/OFF
;OFF, ,
107,0,Lambda Control,
107,1,Engine Speed,,
;0 /min,RPM,
107,2,Lambda Control,Bank 1 (average),
;0.0 %,Lambda,
107,3,Lambda Control,Bank 2 (average),
;0.0 %,Lambda,
107,4,Result,Lambda Control,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
;Test OFF, ,
110,0,Load/Full Throttle Enrichment,
110,1,Engine Speed,,
;0 /min,RPM,
110,2,Coolant,Temperature,Specification: 80.0...110.0 °C
;7.0°C,Temperature,
110,3,Injection Timing,,
110,4,Throttle Position,Sensor (G187),
;6.7 %,Load,
112,0,Exhaust Gas Temperature,
112,1,Exhaust Gas,Temperature Bank 1,
112,2,,,
112,3,Exhaust Gas,Temperature Bank 2,
112,4,,,
113,0,Load/Full Throttle Enrichment,
113,1,Engine Speed,,
;0 /min,RPM,
113,2,Engine Load,,
;100.0 %,Load,
113,3,Throttle Position,Sensor (G187),
;6.7 %,Load,
113,4,Athmospheric,Pressure,
120,0,Traction Control (ASR),
120,1,Engine Speed,,
;0 /min,RPM,
120,2,Engine Load,(specified),
;408.0 Nm,Torque,
120,3,Engine Load,(actual),
;246.0 Nm,Torque,
120,4,Status,,Specification: ASR OFF/ASR ON
;ASR OFF, ,
122,0,Transmission,
122,1,Engine Speed,,
;0 /min,RPM,
122,2,Engine Load,(specified),
;408.0 Nm,Torque,
122,3,Engine Load,(actual),
;246.0 Nm,Torque,
122,4,Status,,Display Range: Engine interv./No engine interv.
;No Torq Red, ,
125,0,CAN-Databus Powertrain (Communication),
125,1,Transmission,,Display Range: Transm. 1/Transm. 0
125,2,Brake Electronics,,Specification: ABS 1
Display Range: ABS 1/ABS 0
;ABS 1, ,
125,3,Instrument Cluster,,Specification: Instruments 1
Display Range: Instruments 1/Instruments 0
;Instruments 1, ,
125,4,,,
126,0,CAN-Databus Powertrain (Communication),
126,1,,,
126,2,,,
126,3,Airbag,,Specification: Airbag 1
Display Range: Airbag 1/Airbag 0
;Airbag 1, ,
126,4,,,
130,0,Map Cooling,
130,1,Engine Outlet,Temperature,
;7.0°C,Temperature,
130,2,,,
130,3,,,
130,4,,,
131,0,Map Cooling,
131,1,Engine Outlet,Temperature,
;7.0°C,Temperature,
131,2,,,
131,3,,,
131,4,,,
134,0,Temperatures,
134,1,Oil Temperature,,
;-60.0°C,Temperature,
134,2,Ambient,Temperature,
;7.0°C,Temperature,
134,3,Intake Air,Temperature,
;9.0°C,Temperature,
134,4,Engine Outlet,Temperature,
;7.0°C,Temperature,
137,0,Air Condition Requirements,
137,1,A/C Readiness,,Display Range: A/C-Low / A/C-High
;A/C-Low, ,
137,2,A/C Compressor,,Display Range: Compr.OFF/Compr.ON
;Compr.OFF, ,
137,3,,,
137,4,,,
138,0,,
138,1,,,
;7.0°C,Temperature,
138,2,,,
;113.33 g/s,Mass Flow,
138,3,,,
;224.4 km/h,Speed,
138,4,,,
;Test OFF, ,
139,0,,
139,1,,,
;7.0°C,Temperature,
139,2,,,
;0.0 kg,Mass/Weight,
139,3,,,
;8.4 kg,Mass/Weight,
139,4,,,
;Test OFF, ,
201,0,,
201,1,,,
;0.0 %,Lambda,
201,2,,,
;0.0 %,Lambda,
201,3,,,
201,4,,,
202,0,,
202,1,,,
;0.00 s,Time,
202,2,,,
;0.00 s,Time,
202,3,,,
;Abort, ,
202,4,,,
203,0,,
203,1,,,
;0 /min,RPM,
203,2,,,
;100.0 %,Load,
203,3,,,
;7.0°C,Temperature,
203,4,,,
204,0,,
204,1,,,
;0 /min,RPM,
204,2,,,
;0.0 km/h,Speed,
204,3,,,
204,4,,,
205,0,,
205,1,,,
205,2,,,
;0.0 %,Load,
205,3,,,
;-1.0,(no units),
205,4,,,
206,0,,
206,1,,,
206,2,,,
;0.0 %,Load,
206,3,,,
;-2.0,(no units),
206,4,,,
207,0,,
207,1,,,
;0.00 s,Time,
207,2,,,
;0.00 s,Time,
207,3,,,
;0,Count,
207,4,,,
208,0,,
208,1,,,
;0 /min,RPM,
208,2,,,
;123,Count,
208,3,,,
208,4,,,
;00100000,Bin. Bits,
209,0,,
209,1,,,
;0 /min,RPM,
209,2,,,
;123,Count,
209,3,,,
209,4,,,
210,0,,
210,1,,,
210,2,,,
210,3,,,
;1,Count,
210,4,,,
211,0,,
211,1,,,
211,2,,,
211,3,,,
;1,Count,
211,4,,,
212,0,,
212,1,,,
;0.000,Difference,
212,2,,,
;0,Count,
212,3,,,
;2.06,(no units),
212,4,,,
213,0,,
213,1,,,
;0.000,Difference,
213,2,,,
;0,Count,
213,3,,,
;2.06,(no units),
213,4,,,
215,0,,
215,1,,,
215,2,,,
215,3,,,
215,4,,,
216,0,,
216,1,,,
;1.016,Lambda Factor,
216,2,,,
;0.992,Lambda Factor,
216,3,,,
;0.8 %,Lambda,
216,4,,,
;01100000,Bin. Bits,
217,0,,
217,1,,,
217,2,,,
;0.969,Lambda Factor,
217,3,,,
;0.8 %,Lambda,
217,4,,,
218,0,,
218,1,,,
;-0.020,Difference,
218,2,,,
;1.00,(no units),
218,3,,,
;0.94,(no units),
218,4,,,
220,0,,
220,1,,,
;25.50 kOhm,Resistance,
220,2,,,
220,3,,,
;54.0°C,Temperature,
220,4,,,
221,0,,
221,1,,,
221,2,,,
221,3,,,
221,4,,,
222,0,,
222,1,,,
;0.435 V,Voltage,
222,2,,,
222,3,,,
222,4,,,
223,0,,
223,1,,,
;0.440 V,Voltage,
223,2,,,
223,3,,,
223,4,,,
224,0,,
224,1,,,
;0.435 V,Voltage,
224,2,,,
;0.440 V,Voltage,
224,3,,,
;0.00 s,Time,
224,4,,,
225,0,,
225,1,,,
;0.435 V,Voltage,
225,2,,,
225,3,,,
;0.00 s,Time,
225,4,,,
226,0,,
226,1,,,
;0.440 V,Voltage,
226,2,,,
226,3,,,
;0.00 s,Time,
226,4,,,
227,0,,
227,1,,,
;0.00,(no units),
227,2,,,
227,3,,,
;1.00 s,Time,
227,4,,,
;01110000,Bin. Bits,
228,0,,
228,1,,,
;0.00,(no units),
228,2,,,
228,3,,,
;1.00 s,Time,
228,4,,,
229,0,,
229,1,,,
;0.0 %,Load,
229,2,,,
;0.0 %,Lambda,
229,3,,,
;0.0 %,Load,
229,4,,,
231,0,,
231,1,,,
;0.0 %,Lambda,
231,2,,,
231,3,,,
;0.000,Difference,
231,4,,,
232,0,,
232,1,,,
;0.0 %,Lambda,
232,2,,,
232,3,,,
;0.000,Difference,
232,4,,,
233,0,,
233,1,,,
;0.0 %,Lambda,
233,2,,,
233,3,,,
;0.8 %,Lambda,
233,4,,,
234,0,,
234,1,,,
;0.0 %,Lambda,
234,2,,,
234,3,,,
;0.8 %,Lambda,
234,4,,,
237,0,,
237,1,,,
;2543,Count,
237,2,,,
;1539,Count,
237,3,,,
;4123,Count,
237,4,,,
238,0,,
238,1,,,
;1527,Count,
238,2,,,
;1607,Count,
238,3,,,
;637,Count,
238,4,,,
239,0,,
239,1,,,
;00111111,Bin. Bits,
239,2,,,
;01111111,Bin. Bits,
239,3,,,
239,4,,,
;0,Count,
240,0,,
240,1,,,
240,2,,,
240,3,,,
;4,Count,
240,4,,,
241,0,,
241,1,,,
;6.0°C,Temperature,
241,2,,,
;7.0°C,Temperature,
241,3,,,
;27.0°C,Temperature,
241,4,,,
;9.0°C,Temperature,
242,0,,
242,1,,,
;0,Count,
242,2,,,
;0,Count,
242,3,,,
;9.0°C,Temperature,
242,4,,,
;00010000,Bin. Bits,
243,0,,
243,1,,,
;9.0°C,Temperature,
243,2,,,
;22.0°C,Temperature,
243,3,,,
;0,Count,
243,4,,,
;9.0°C,Temperature,
244,0,,
244,1,,,
;1.5°KW,Idle Stabilization,
244,2,,,
244,3,,,
244,4,,,
;0.8°KW,Idle Stabilization,
245,0,,
245,1,,,
245,2,,,
245,3,,,
;100.0 %,Load,
245,4,,,
;First Map, ,
246,0,,
246,1,,,
;1.05,(no units),
246,2,,,
;1.11,(no units),
246,3,,,
;1.08,(no units),
246,4,,,
;0.80,(no units),
247,0,,
247,1,,,
;0.6 %,Lambda,
247,2,,,
;0.0 %,Lambda,
247,3,,,
;7.0°C,Temperature,
247,4,,,
248,0,,
248,1,,,
;0.6 %,Lambda,
248,2,,,
;-1.6 %,Lambda,
248,3,,,
;0.0 %,Lambda,
248,4,,,
;0.0 %,Lambda,
249,0,,
249,1,,,
;1.00,(no units),
249,2,,,
;0.94,(no units),
249,3,,,
;0.56 g/s,Mass Flow,
249,4,,,
250,0,,
250,1,,,
250,2,,,
250,3,,,
;83.33 g/s,Mass Flow,
250,4,,,
251,0,,
251,1,,,
251,2,,,
251,3,,,
251,4,,,
252,0,,
252,1,,,
;0.0°,Steering Angle,
252,2,,,
252,3,,,
252,4,,,
253,0,,
253,1,,,
;100.0 %,Load,
253,2,,,
;IMC-V OFF, ,
253,3,,,
253,4,,,
code, engine at idle
;Thursday,19,March,2015,19:07:47:47536
1,1,Engine Speed,,
;1160 /min,RPM,
;9.0°C,Temperature,
;-25.0 %,Lambda,
;-23.4 %,Lambda,
2,1,Engine Speed,,
;1160 /min,RPM,
2,2,Engine Load,,
;32.3 %,Load,
;4.16 ms,Inj. On Time,
2,4,Mass Air Flow,,
;12.78 g/s,Mass Flow,
3,1,Engine Speed,,
;1160 /min,RPM,
3,2,Mass Air Flow,,
;12.58 g/s,Mass Flow,
;6.7 %,Load,
;5.3 °ATDC,Ign. Timing,
4,1,Engine Speed,,
;1160 /min,RPM,
;14.070 V,Voltage,
;9.0°C,Temperature,
;10.0°C,Temperature,
5,1,Engine Speed,,
;1160 /min,RPM,
5,2,Engine Load,,
;30.8 %,Load,
5,3,Vehicle Speed,,
;0.0 km/h,Speed,
;Idle, ,
6,1,Engine Speed,,
;1120 /min,RPM,
6,2,Engine Load,,
;30.8 %,Load,
;11.0°C,Temperature,
;-4.7 %,Lambda,
;Not Oper., ,
;14.210 V,Voltage,
;460.0 mbar,Absolute Pres.,
8,4,,,
;410.0 mbar,Absolute Pres.,
9,0,,
9,1,,,
9,2,,,
9,3,,,
;800.0,(no units),
9,4,,,
10,0,Ignition,
10,1,Engine Speed,,
;1160 /min,RPM,
10,2,Engine Load,,
;30.1 %,Load,
;6.3 %,Load,
;3.8 °ATDC,Ign. Timing,
11,0,Ignition,
11,1,Engine Speed,,
;1160 /min,RPM,
;9.0°C,Temperature,
;2.3 °ATDC,Ign. Timing,
14,1,Engine Speed,,
;1160 /min,RPM,
14,2,Engine Load,,
;28.6 %,Load,
;0,Count,
;Enabled, ,
;0,Count,
;0,Count,
;0,Count,
;Enabled, ,
;0,Count,
;0,Count,
;0,Count,
;Enabled, ,
;0 /min,RPM,
;0 /min,RPM,
;0.0 %,Load,
;0.0 %,Load,
21,3,,,
21,4,,,
22,1,Engine Speed,,
;1160 /min,RPM,
22,2,Engine Load,,
;26.3 %,Load,
23,1,Engine Speed,,
;1160 /min,RPM,
23,2,Engine Load,,
;26.3 %,Load,
24,1,Engine Speed,,
;1160 /min,RPM,
24,2,Engine Load,,
;25.6 %,Load,
;1.989 V,Voltage,
;2.106 V,Voltage,
;1.872 V,Voltage,
;2.808 V,Voltage,
;3.276 V,Voltage,
;2.925 V,Voltage,
27,3,,,
27,4,,,
28,1,Engine Speed,,
;1160 /min,RPM,
28,2,Engine Load,,
;24.8 %,Load,
;Test OFF, ,
;   00111,Bin. Bits,
;    0000,Bin. Bits,
;   00111,Bin. Bits,
;    0000,Bin. Bits,
;1.601,Lambda Factor,
;1.671,Lambda Factor,
;1.632,Lambda Factor,
;0.8 %,Lambda,
;-0.8 %,Lambda,
;0.8 %,Lambda,
;-3.1 %,Lambda,
;-25.0 %,Lambda,
;2.480 V,Voltage,
;-25.0 %,Lambda,
;2.540 V,Voltage,
34,1,Engine Speed,,
;1160 /min,RPM,
;330.0°C,Temperature,
;2.06,(no units),
;Test OFF, ,
35,1,Engine Speed,,
;1160 /min,RPM,
;320.0°C,Temperature,
;2.06,(no units),
;Test OFF, ,
;0.440 V,Voltage,
;Test OFF, ,
;0.440 V,Voltage,
;Test OFF, ,
37,1,Engine Load,,
;24.1 %,Load,
;0.440 V,Voltage,
;0.000,Difference,
;Test OFF, ,
38,1,Engine Load,,
;23.3 %,Load,
;0.445 V,Voltage,
;0.000,Difference,
;Test OFF, ,
;9.56 g/s,Mass Flow,
;0.415 V,Voltage,
;0.430 V,Voltage,
;79 ohms,Resistance,
;Htg. S1 ON, ,
41,3,,,
;Htg. S2 OFF, ,
;77 ohms,Resistance,
;Htg. S1 OFF, ,
42,3,,,
;Htg. S2 OFF, ,
43,1,Engine Speed,,
;1160 /min,RPM,
;315.0°C,Temperature,
;0.445 V,Voltage,
;Test OFF, ,
44,1,Engine Speed,,
;1160 /min,RPM,
;305.0°C,Temperature,
;0.450 V,Voltage,
;Test OFF, ,
46,1,Engine Speed,,
;1160 /min,RPM,
;5.0°C,Temperature,
;0.00,(no units),
;Test OFF, ,
47,1,Engine Speed,,
;1160 /min,RPM,
;5.0°C,Temperature,
;0.00,(no units),
;Test OFF, ,
;1180 /min,RPM,
;1180 /min,RPM,
;A/C-Low, ,
;Compr.OFF, ,
;1180 /min,RPM,
;1180 /min,RPM,
;0,Count,
;14.210 V,Voltage,
;1180 /min,RPM,
;1180 /min,RPM,
;A/C-Low, ,
52,4,,,
;1180 /min,RPM,
;1180 /min,RPM,
;14.280 V,Voltage,
53,4,,,
54,1,Engine Speed,,
;1160 /min,RPM,
;Idle, ,
;0.0 %,Load,
;4.3 %,Load,
55,1,Engine Speed,,
;1170 /min,RPM,
;-1.8 %,Lambda,
;0.6 %,Lambda,
;  000000,Bin. Bits,
;1170 /min,RPM,
;1180 /min,RPM,
;-1.8 %,Lambda,
;  000000,Bin. Bits,
;1170 /min,RPM,
;1180 /min,RPM,
;Compr.OFF, ,
58,1,Engine Speed,,
;1160 /min,RPM,
58,2,Engine Load,,
;19.5 %,Load,
58,3,,,
58,4,,,
;13.7 %,Duty Cycle,
;86.3 %,Duty Cycle,
;0,Count,
;ADP. O.K., ,
61,1,Engine Speed,,
;1120 /min,RPM,
;14.140 V,Voltage,
;4.3 %,Load,
;  000000,Bin. Bits,
;13.7 %,Duty Cycle,
;85.9 %,Duty Cycle,
;14.5 %,Duty Cycle,
;7.4 %,Duty Cycle,
;14.5 %,Duty Cycle,
;0.520 V,Voltage,
;4.580 V,Voltage,
;0.800 V,Voltage,
;4.320 V,Voltage,
;0.0 km/h,Speed,
;0.0 km/h,Speed,
;0.0 %,Load,
;-21.9 %,Lambda,
;Test OFF, ,
;Reed Closed, ,
;Abort, ,
;Test OFF, ,
72,0,,
;Reed Closed, ,
;Abort, ,
72,3,,,
72,4,Result,,
;Test OFF, ,
73,0,,
;0.0 %,Load,
73,2,Flush rate,,
;0.0 %,Load,
73,3,Load factor,,
;0.0 %,Lambda,
;0.0 %,Lambda,
77,1,Engine Speed,,
;1120 /min,RPM,
;7.69 g/s,Mass Flow,
;0.0 %,Lambda,
;Test OFF, ,
78,1,Engine Speed,,
;1120 /min,RPM,
;7.61 g/s,Mass Flow,
;0.0 %,Lambda,
;Test OFF, ,
79,0,,
79,1,Engine Speed,,
;1080 /min,RPM,
79,2,Engine Load,,
;18.8 %,Load,
79,3,Flap Bank 1,,
;ON, ,
79,4,Flap Bank 2,,
80,1,,,
82,1,,,
86,2,Cycle Flags,,
86,3,Cycle Flags,,
86,4,Cycle Flags,,
87,2,Error Flags,,
87,3,Error Flags,,
87,4,Error Flags,,
88,1,Cycle Flags,,
88,2,Cycle Flags,,
;10101111,Bin. Bits,
88,3,Cycle Flags,,
88,4,,,
89,0,,
;0,Count,
;OK, ,
89,3,,,
89,4,,,
90,1,Engine Speed,,
;920 /min,RPM,
90,2,Duty Cycle,,
;29.4 %,Load,
;22.0°KW,Idle Stabilization,
91,1,Engine Speed,,
;920 /min,RPM,
91,2,Duty Cycle,,
;30.2 %,Load,
;3.0°KW,Idle Stabilization,
93,1,Engine Speed,,
;920 /min,RPM,
93,2,Duty Cycle,,
;18.8 %,Load,
;2.0°KW,Idle Stabilization,
;Test OFF, ,
;880 /min,RPM,
;18.8 %,Load,
;15.0°C,Temperature,
;IMC-V OFF, ,
;21.5°KW,Idle Stabilization,
;Test OFF, ,
98,1,Engine Speed,,
;840 /min,RPM,
98,2,Engine Load,,
;31.0 %,Load,
99,1,Engine Speed,,
;840 /min,RPM,
;O2-Reg.ON, ,
;48.46 s,Time,
;01000000,Bin. Bits,
;800 /min,RPM,
101,2,Engine Load,,
;18.0 %,Load,
;2.08 ms,Inj. On Time,
;5.11 g/s,Mass Flow,
;800 /min,RPM,
;7.0°C,Temperature,
;28.9 %,Lambda,
;28.9 %,Lambda,
;28.9 %,Lambda,
;760 /min,RPM,
105,2,Engine Load,,
;18.0 %,Load,
;16.0°C,Temperature,
;OFF, ,
;760 /min,RPM,
;-19.5 %,Lambda,
;-18.0 %,Lambda,
;Test OFF, ,
;760 /min,RPM,
;2.60 ms,Inj. On Time,
;2.7 %,Load,
;230.0°C,Temperature,
112,2,,,
;225.0°C,Temperature,
112,4,,,
;760 /min,RPM,
113,2,Engine Load,,
;18.8 %,Load,
;3.1 %,Load,
;760 /min,RPM,
;408.0 Nm,Torque,
;0.0 Nm,Torque,
;ASR OFF, ,
122,0,Transmission,
;760 /min,RPM,
;408.0 Nm,Torque,
;0.0 Nm,Torque,
;No Torq Red, ,
;ABS 1, ,
;Instruments 1, ,
125,4,,,
126,1,,,
126,2,,,
;Airbag 1, ,
126,4,,,
130,0,Map Cooling,
;18.0°C,Temperature,
130,2,,,
130,3,,,
130,4,,,
131,0,Map Cooling,
131,2,,,
131,3,,,
131,4,,,
134,0,Temperatures,
;7.0°C,Temperature,
;A/C-Low, ,
;Compr.OFF, ,
137,3,,,
137,4,,,
138,0,,
138,1,,,
;7.0°C,Temperature,
138,2,,,
138,3,,,
;224.4 km/h,Speed,
138,4,,,
;Test OFF, ,
139,0,,
139,1,,,
139,2,,,
139,3,,,
139,4,,,
;Test OFF, ,
201,0,,
201,1,,,
;-12.5 %,Lambda,
201,2,,,
;-10.2 %,Lambda,
201,3,,,
201,4,,,
;01111100,Bin. Bits,
202,0,,
202,1,,,
;0.00 s,Time,
202,2,,,
;0.00 s,Time,
202,3,,,
;Abort, ,
202,4,,,
;01010000,Bin. Bits,
203,0,,
203,1,,,
;720 /min,RPM,
203,2,,,
;18.0 %,Load,
203,3,,,
;21.0°C,Temperature,
203,4,,,
204,0,,
204,1,,,
;720 /min,RPM,
204,2,,,
;0.0 km/h,Speed,
204,3,,,
;5.0°C,Temperature,
204,4,,,
205,0,,
205,1,,,
;78 ohms,Resistance,
205,2,,,
;40.6 %,Load,
205,3,,,
;0.0,(no units),
205,4,,,
206,0,,
206,1,,,
206,2,,,
;46.1 %,Load,
206,3,,,
;-1.0,(no units),
206,4,,,
207,0,,
207,1,,,
;0.00 s,Time,
207,2,,,
;0.00 s,Time,
207,3,,,
;0,Count,
207,4,,,
208,0,,
208,1,,,
;720 /min,RPM,
208,2,,,
;123,Count,
208,3,,,
208,4,,,
209,0,,
209,1,,,
;720 /min,RPM,
209,2,,,
;123,Count,
209,3,,,
209,4,,,
210,0,,
210,1,,,
210,2,,,
;3.5°KW,Idle Stabilization,
210,3,,,
;1,Count,
210,4,,,
211,0,,
211,1,,,
211,2,,,
211,3,,,
;1,Count,
211,4,,,
212,0,,
212,1,,,
;0.000,Difference,
212,2,,,
;0,Count,
212,3,,,
;2.06,(no units),
212,4,,,
213,0,,
213,1,,,
;0.000,Difference,
213,2,,,
;0,Count,
213,3,,,
;2.06,(no units),
213,4,,,
215,0,,
215,1,,,
215,2,,,
215,3,,,
215,4,,,
;11000000,Bin. Bits,
216,0,,
216,1,,,
216,2,,,
216,3,,,
;0.8 %,Lambda,
216,4,,,
217,0,,
217,1,,,
217,2,,,
217,3,,,
;0.8 %,Lambda,
217,4,,,
218,0,,
218,1,,,
;-0.020,Difference,
218,2,,,
;0.97,(no units),
218,3,,,
;0.94,(no units),
218,4,,,
220,0,,
220,1,,,
220,2,,,
220,3,,,
;0.0°C,Temperature,
220,4,,,
221,0,,
221,1,,,
221,2,,,
221,3,,,
;0.0°C,Temperature,
221,4,,,
222,0,,
222,1,,,
;0.460 V,Voltage,
222,2,,,
222,3,,,
;5.0°C,Temperature,
222,4,,,
223,0,,
223,1,,,
;0.450 V,Voltage,
223,2,,,
223,3,,,
;5.0°C,Temperature,
223,4,,,
224,0,,
224,1,,,
;0.480 V,Voltage,
224,2,,,
;0.455 V,Voltage,
224,3,,,
;0.00 s,Time,
224,4,,,
225,0,,
225,1,,,
;0.460 V,Voltage,
225,2,,,
225,3,,,
;0.00 s,Time,
225,4,,,
226,0,,
226,1,,,
;0.445 V,Voltage,
226,2,,,
226,3,,,
;0.00 s,Time,
226,4,,,
227,0,,
227,1,,,
;0.00,(no units),
227,2,,,
;5.0°C,Temperature,
227,3,,,
;1.00 s,Time,
227,4,,,
228,0,,
228,1,,,
;0.00,(no units),
228,2,,,
;5.0°C,Temperature,
228,3,,,
;1.00 s,Time,
228,4,,,
229,0,,
229,1,,,
;0.0 %,Load,
229,2,,,
;0.0 %,Lambda,
229,3,,,
;0.0 %,Load,
229,4,,,
231,0,,
231,1,,,
;0.0 %,Lambda,
231,2,,,
231,3,,,
;0.000,Difference,
231,4,,,
232,0,,
232,1,,,
;0.0 %,Lambda,
232,2,,,
232,3,,,
;0.000,Difference,
232,4,,,
233,0,,
233,1,,,
;-11.7 %,Lambda,
233,2,,,
233,3,,,
;0.8 %,Lambda,
233,4,,,
234,0,,
234,1,,,
;-10.2 %,Lambda,
234,2,,,
234,3,,,
;0.8 %,Lambda,
234,4,,,
237,0,,
237,1,,,
;2543,Count,
237,2,,,
;1539,Count,
237,3,,,
;4123,Count,
237,4,,,
238,0,,
238,1,,,
;1527,Count,
238,2,,,
;1607,Count,
238,3,,,
;637,Count,
238,4,,,
239,0,,
239,1,,,
239,2,,,
239,3,,,
239,4,,,
;0,Count,
240,0,,
240,1,,,
240,2,,,
240,3,,,
;4,Count,
240,4,,,
241,0,,
241,1,,,
;12.0°C,Temperature,
241,2,,,
241,3,,,
241,4,,,
242,0,,
242,1,,,
;0,Count,
242,2,,,
;0,Count,
242,3,,,
242,4,,,
243,0,,
243,1,,,
;9.0°C,Temperature,
243,2,,,
243,3,,,
;0,Count,
243,4,,,
244,0,,
244,1,,,
244,2,,,
244,3,,,
244,4,,,
245,0,,
245,1,,,
245,2,,,
245,3,,,
;17.3 %,Load,
245,4,,,
;First Map, ,
246,0,,
246,1,,,
;1.05,(no units),
246,2,,,
;1.11,(no units),
246,3,,,
;1.08,(no units),
246,4,,,
;0.80,(no units),
247,0,,
247,1,,,
;0.6 %,Lambda,
247,2,,,
;0.4 %,Lambda,
247,3,,,
;23.0°C,Temperature,
247,4,,,
248,0,,
248,1,,,
;0.6 %,Lambda,
248,2,,,
;-1.6 %,Lambda,
248,3,,,
;0.0 %,Lambda,
248,4,,,
;0.0 %,Lambda,
249,0,,
249,1,,,
;0.97,(no units),
249,2,,,
;0.94,(no units),
249,3,,,
249,4,,,
250,0,,
250,1,,,
;4.64 g/s,Mass Flow,
250,2,,,
;1.72 g/s,Mass Flow,
250,3,,,
;14.06 g/s,Mass Flow,
250,4,,,
251,0,,
251,1,,,
251,2,,,
;2.5°KW,Idle Stabilization,
251,3,,,
251,4,,,
;20.5°KW,Idle Stabilization,
252,0,,
252,1,,,
;255.0°,Steering Angle,
252,2,,,
252,3,,,
252,4,,,
;21.0°KW,Idle Stabilization,
253,0,,
253,1,,,
;17.3 %,Load,
253,2,,,
;IMC-V OFF, ,
253,3,,,
253,4,,,
