- Jan 21, 2021
- 1
- 0
- Jacksonville, FL, USA
- C?ID=208939
Hello...I just completed a BHW diesel swap into my 2001 Audi allroad using a 2004 Passat donor car. It is running well but I am having trouble with the ABS module (5.3) as it still thinks the car is automatic. The car is currently displaying the three warning lights on the dash for suspension, abs, and esp. I did try replacing the brake light switch just to be sure that wasn't the cause but no change. Also, I can't seem to get the car to do the ESP function test. When I try to do the test, VCDS loses communication with the module as soon as I turn the wheel (I am assuming this is related to the powertrain error). I am hoping some can point in the right direction. Below is the scan for the car.
The car was originally an automatic 01V tiptronic, but I swapped that out several years ago for a 6spd 01E. During that swap, I was able to recode the ABS module and had no issues with it. Below is the last scan I had taken before the engine jumped timing.
Below is the scan I took of the donor car before removing the engine.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389
Component: ABS/ESP allrad D47
Coding: 06355
VCID: 091997A1337294CC55-5140
01486 - System Function Test Activated
35-00 - -
18263 - Powertrain Data Bus
P1855 - 35-00 - Software Version Monitoring
Coding: 06395
VCID: 091997A133729407F2-5140
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04257
Shop #: WSC 00028
VCID: 2541FB11BFAAD06ED9-5122
37-00 - Faulty
27-00 - Implausible Signal
