Controller Not Responding
tommybenham
Southampton, UK
C?ID=408131
Hi All,
Im a new users and getting to grips with it all.
I continually get the controller not responding message when trying to enter engine and other menus what am I missing?
Thanks in advanced
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.12.0(x64) Data version: 20201125 DS322.1
Address 94: LT3 Airbag
Part No HW: 9069005701
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F784E6A58E6273704-8000
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,22,January,2021,12:15:58:62285
VIN: WV1ZZZ2EZD6022772 License Plate: HJ13TOH
Mileage: Repair Order:
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 95: LT3 ESP
Part No HW: 0009015901
Serial number: 000901590110851
ASAM Dataset: CRFT2_ESP 3
ROD: CRFT1_ESP.rod
No Faults Found
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
PartNoSW:2E0905843A HW:9069002702
Component: IMMO 0805 1246
Revision: 00805000 Serial number: VWXDZ0L1046391
VCID: 2517F426B9EE32F3204-8070
Self-Diagnosis Log
Page 2
Address 96: LT3 Instruments
Part No SW: 9069023301 HW: 9069019800
ASAM Dataset: 32 791
ROD: CRFT_KOMBI_32_791.rod
VCID: 015F80B601863ED37CC-8054
9102 - CAN drive train: Engine Control Module (ECM) (J623): Time out
Test Complete - Stored
Address 99: LT3 Ign. Switch
Part No HW: 9069002702
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 1246
Revision: 00805000 Serial number: 12345678901234
00172 - Key 2 not learned
Address 9B: LT3 Driver Door
Part No HW: 9068204126
ASAM Dataset: 33 773
ROD: CRFT_FTUHR_33_773.rod (*)
No fault code found. -------------------------------------------------------------------------------
Test Complete - Active/Stored
Self-Diagnosis Log
Page 3
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BA3F25E636A5403260-802E
9092 - Interior Monitoring Sensor (G273)/ Interior Monitoring Sensor (G592): Comm. error
Address B4: LT3 Central Elec.
Part No SW: 9069022001 HW: 9069013100
ASAM Dataset: 33 833
ROD: CRFT_EZE_33_1088.rod (*)
VCID: 7DA7FC467D7E5A33184-8028
End----------(Elapsed Time: 01:03, VBatt start/end: 12.1V/12.1V)-----------
tommybenham
Southampton, UK
C?ID=408131
Dealer/Shop Name:
Self-Diagnosis Log
Wednesday,20,January,2021,16:13:33:62285
Mileage: 152726 Repair Order:
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Self-Diagnosis Log
Address 01: Engine (J623-CKTB) Labels:. 03L-906-012-CKT.clb
PartNoSW:03L906012Q HW:03L906012A
Component: R4 2,0L EDC H26 2859
Revision: 72H26--- Serial number: VWXDZ0L1046391
Coding: 0119401020040C080000
Shop #: WSC 00000 555 00117
ASAM Dataset: EV_ECM20TDI01103L906012Q 002011
ROD: EV_ECM20TDI01103L906012Q_002.rod
VCID: 323D1F7AF4A0554BB56-8066
5188 - Diesel Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
Mileage: 45794 km
Date: 2047.15.31
Time: 31:63:63
Engine RPM: 0.00 /min
Coolant temperature: 43 °C
Intake air temperature: 11 °C
Voltage terminal 30: 12.380 V
Counter for regeneration time of particulate filter: 0.00 s
Particle filter: kilometers since last regeneration: 6544684 m
Particle filter: soot mass measured: 34.35 g
Particle filter: soot mass calculated: 50.00 g
Particle filter: differential pressure: dynamic offset: 0 hPa
4900 - EGR Sensor 1
Page 2
P0405 00 [175] - Signal too Low
Mileage: 45794 km
Date: 2047.15.31
Time: 31:63:63
Intake air temperature: 10 °C
Readiness: 1 3 0 0 1
Self-Diagnosis Log
Voltage terminal 30: 12.360 V
Air mass: actual value (mg/stroke): 0.0 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 100.00 %
EGR valve: offset closed: -2.71 %
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 2
High press EGR actuator: actual unconditioned volt val: 4.8 mV
Address 95: LT3 ESP
ROD: CRFT1_ESP.rod
No Faults Found
Page 3
Self-Diagnosis Log
Page 4
Self-Diagnosis Log
Page 5
ASAM Dataset: 21 3
End----------(Elapsed Time: 00:49, VBatt start/end: 12.4V/12.4V)-----------
01-Engine is there in your second scan, but not your first... :confused:
PS: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
tommybenham
Southampton, UK
C?ID=408131
It is very intermittent, I can have access one minute then I can't get back into it.
I managed to get through on two occasions by selecting B1 Upper Console then exit that and then enter 01 Engine. But this also seems intermittent.
I am very rarely able to get a complete autoscan done.
I am baffled
