ABS Recoding after AWD swap "MK60EC1 H46 0166"
dahui9
Florida, USA
C?ID=107129
Hello all, first post here well because I've been searching for a bit and haven't been able to find anything that doesn't provide an "error 31" code for my specific my car. I had some friends try to help but they have older modules compared to mine as I have an extra 2 digits of code.
My stock coding is
A14B600C49250003850B06E5921F0041A118F06A
While also doing this I had to upgrade my rear brakes to mk6 golf r brakes to make things easier. SHOPDAP LINK to what I installed.
I'm not sure that it matters but I'm also using Passat B6 variant awd rear hubs w/abs sensors because they fit but the back side of the hub seems improper, it's what I had unfortunately (MK6 Golf R hubs in transit with proper ABS sensors). The wheel bearing and sensors appear to be the same/similar for both but I'm unsure because of the faults coming up (not sure if it's awd coding related or not).
I'm really looking to hopefully get the ABS coding issue resolved by laying everything out there that's changed that could affect the ABS coding. If there is anything additional you need please let me know. Below is a Full vehicle scan.
Thursday,21,January,2021,15:46:06:38452
VCDS Version: 20.12.0.1 (x64)  HEX-NET CB: 0.4529.4
[URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
Dealer/Shop Name: Devine Shop
VIN: 3VW4T7AJ8FM239016   License Plate:
Mileage: 87470km-54351mi   Repair Order: ABS Coding Diag
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 37 3C 42 44 46 47 4F
          52 55 56 5F 62 72 75 77
VIN: 3VW4T7AJ8FM239016   Mileage: 87470km-54351miles
22-AWD -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Not registered 0011
Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 997 071 J    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 9357
   Revision: --H13---
   Coding: 001D0012242400171000
   Shop #: WSC 00066 790 00186
   ASAM Dataset: EV_ECM20TFS02006K997071J 001003
   ROD: EV_ECM20TFS02006K997071J.rod
   VCID: 3C341203B7FD93641E-8068
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [039] - Malfunction / Open Circuit
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:41:27
                    Engine RPM: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 11.699 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 101 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 17.968750 %
                    VLS_DOWN_SAE[1]: 1.275 V
21352 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
          P2432 00 [039] - Short to Ground
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:41:23
                    Voltage terminal 30: 11.679 V
                    T_AST_SAE: 0 s
                    FUP_H_SAE: 11470.0 kPa
17178 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:41:23
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 1101
   Part No SW: 02E 300 062 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4006
   Revision: 05652104    Serial number: 00001407012296
   Shop #: WSC 44551 111 44551
   VCID: 2208CC7BFD59C59434-8076
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B600C49250003850B06E5921F0041A118F06A
   Shop #: WSC 00066 000 00000
   VCID: 0444AAE3878D2BA426-8050
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:36:20
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 41728
                    Count: 508
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:36:20
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 197
                    Count: 41728
                    Count: 508
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:36:20
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 87
                    Count: 41728
                    Count: 508
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:36:20
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 71
                    Count: 41728
                    Count: 508
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:36:20
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 8202
                    Count: 41728
                    Count: 508
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0345322843
   Coding: 030C0C
   Shop #: WSC 00066 000 00147
   VCID: 373E0D2F8EDBB03CF3-8062
   Part No SW: 1K8 907 044 N    HW: 1K8 907 044 N
   Component: Climatronic   H05 0102
   Revision: 00001K02
   Coding: 0010019002
   Shop #: WSC 00066 000 00119
   VCID: 3A38141BBDC9AD540C-806E
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0174
   Revision: BL122001
   Coding: EF200A3EF82F06D4018800812400894C0174000845A08DB0E4842000A040
   VCID: 78BCCE13CB457F443A-802C
   Component: RLS 270814 05  54  0403
   Coding: 02300A
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:43:14
                    Voltage: 11.60 V
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD02Y0F.
   Coding: 00004B33
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72A8FC3BA539151404-8026
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001CG7F0Z
   Coding: 303355
   Serial number: 3572MSME7E2F3E48ZZZH
   Serial number: 3582MSME7B2F3E48ZZZF
   Serial number: 3516KSME36736030ZZZH
   Serial number: 3526KSME27556030ZZZI
   Serial number: 3556LSME5D174D30ZZZ/
   Serial number: 3566LSME09294D30ZZZZ
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:38:52
   Part No SW: 1K5 953 521 CA    HW: 5K0 953 569 AG
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20140813100274
   Coding: 0012440008
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 6E90E84BB10131F4E0-803A
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H01 0102
   Serial number: 27140001462150014246
   Coding: B1FFFF
   Part No SW: 5C6 920 974 B    HW: 5C6 920 974 B
   Component: KOMBI         H04 0906
   Coding: 271E01
   VCID: 2F2E354F768B78FCAB-807A
   Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1653
   Revision:   H56       Serial number: 11071403000809
   Coding: 351002
   VCID: 014AA3F7989F3E8C0D-8054
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:36:20
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:36:20
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45C277E70C37D2AC71-8010
   Component: IMMO          H04 0906
   Coding: 000007
   VCID: 6A98E45B8DE9DDD4BC-803E
   Revision: 00000000    Serial number: 14000228855002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 302C36336BB56704B2-8064
Address 37: Navigation
   Part No SW: 5Q0 907 686 A    HW: 5Q0 907 686 A
   Component: HRE_Master    H11 0066
   Serial number: 0342846611
   Coding: 01011102
   Shop #: WSC 00066 790 00182
   ASAM Dataset: EV_HREntryHella 001024
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3B36111FB2F3945C17-806E
   Subsystem 1 - Part No SW: 5Q0 907 685 A    HW: 5Q0 907 685 A
   Component: HRE_Slave  H11 0066
   Serial number: 0342285099
   Coding: 010111
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0008934495
   Coding: 0404BD
   VCID: 5BF6B19F52B3B45C37-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587140919220902
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 393A0B1770CFA64C05-806C
                    Fault Status: 11101101
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 03:43:27
                    Voltage: 11.63 V
                        DD
                    Temperature: 22.0°C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0005088
   ROD: EV_AudioVerst10KanalSTT3_VW36.rod
   VCID: 281CDE5353652FC46A-807C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1653
   Coding: 01030100
   VCID: 6FAEF54FBE0B38FCEB-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH000BX9N3
   Coding: 180000
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0008925718
   Coding: 0404BC
   VCID: 5CF4B28357BDB3643E-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14102586140926060634
   Coding: 800000
   Component: AFS-ECU       H04 0111
   Coding: 081200010B000200
   Shop #: WSC 01383 790 50316
   Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
5256725 - Rear Left Ride-Height Sensor
          C1036 15 [137] - Open or Short to Plus
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:36:20
13705985 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HL]
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:39:19
13705987 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HR]
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:39:19
Address 56: Radio
   Part No SW: 5C0 035 682 G    HW: 5C0 035 682 E
   Component: MU-S-N-CN     H31 0472
   Serial number: VWZAZ2S5231703
   Coding: 02730102FF00000011220003001028001F0700D400200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 271EDD6F5E7B20BC63-8072
          B201A 00 [009] - -
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:40:54
                    Voltage terminal 30: 11.6 V
                    Status_Software_Version_Management-module_name:
15360768 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:40:54
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140527
   Coding: 02630102C2423A107F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53E659BF3A637C1CEF-8006
9457171 - Audio signal output 1
          B14F1 13 [009] - Open Circuit
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:36:20
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 03:44:28
Address 77: Telephone
End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
-Charles
jettarv
Canada
C?ID=345286
Hi! Jetta GLI 4motion swap ? what year?
Try to code the ecm CPPA to AWD, if it is accepted, the abs error should go away.
if it's rejected (error 31!).... You have to code your abs module in Skoda yeti 4x4.
Byte 6 = 01
Byte 14 = 80
So:
To:
A14B600C49250103850B06E5921F8041A118F06A
And dont' forget to select AWD in the CAN gateway
Mike
dahui9
Florida, USA
C?ID=107129
Update, I spoke with the
Byte 6 = 01
Byte 14 = 80
So:
To:
Mike
Hi Mike, thanks for the quick reply. It is a 2015 GLI SEL with adaptive headlights.
I totally forgot I had the VE Haldex controller installed in the car, and Haldex broadcast was turned to off by default. They contacted me and recommended turning broadcast on through the app then rescan. They said the coding looks correct, it appears that the coding corrects itself when you add AWD to the CAN Gateway, which was already completed (thank you for recommending to check it though).
Ok to update you on your information, I attempted to code the ECM (address 01) to AWD by looking at specific bytes. There was a checkbox for AWD, checked the box, close, Do it. Error 31 as you predicted.
With that said, I still attempted the ABS (address 03) code you provided as I'm still receiving 03842 & 03841 as you can see below in the new autoscan. I can only assume this is due to the 2 rear Passat hubs/abs sensors in the rear of the car). The code for Control Module for Tire Pressure Monitoring is most likely caused by the incorrect coding (or incorrect sensors?) what are your thoughts?
Also found out I should be using
 instead of [TABLE] whoops.
[CODE]Thursday,21,January,2021,16:56:50:38452
Mileage: 87470km-54351mi   Repair Order: ABS Diag
   Revision: --H13---
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:53
                    Coolant temperature: 18 °C
                    Voltage terminal 30: 11.640 V
                    T_AST_SAE: 0 s
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:49
                    T_AST_SAE: 0 s
                    FUP_H_SAE: 11880.0 kPa
17178 - Databus
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:49
   Revision: 00H46001
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 04:52:47
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 41216
                    Count: 256
            P1647 - 000 -
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 04:52:47
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 197
                    Count: 41216
                    Count: 256
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 04:52:46
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 87
                    Count: 41472
                    Count: 508
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 04:52:46
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 71
                    Count: 41472
                    Count: 508
   Coding: 030C0C
   Revision: 00001K02
   Coding: 0010019002
   Revision: BL122001
   Coding: 02300A
   Coding: 00004B33
   Coding: 303355
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 137
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:53:04
   Coding: 0012440008
   Coding: B1FFFF
   Coding: 271E01
   Coding: 351002
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 04:52:46
   Coding: 0000005
   Coding: 000007
   Coding: 01011102
   Coding: 010111
   Coding: 0404BD
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2015.06.14
                    Time: 04:54:03
                    Voltage: 11.63 V
                        DD
                    Temperature: 22.0°C
   Coding: 01030100
   Coding: 180000
   Coding: 0404BC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:47
13705985 - Databus
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:53:31
13705987 - Databus
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:53:31
Address 56: Radio
          B201A 00 [009] - -
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:45
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:46
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:46
                    Fault Priority: 8
                    Reset counter: 97
                    Mileage: 87478 km
                    Date: 2021.01.21
                    Time: 04:52:46
End----(Elapsed Time: 01:24, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
-Charles
jettarv
Canada
C?ID=345286
it looks like you didn't code your module well, you have to code with this
jettarv
Canada
C?ID=345286
I still see the code 18055, the other codes are indeed the wrong rear sensors and the tpms can also be removed
dahui9
Florida, USA
C?ID=107129
So the ABS module wouldn't accept this coding, it's the same code my friend David and I tried, but I tried it again anyway haha. Error code 31 pops up, so I think we are missing something else with my specific year maybe?. That seems to work in the older revisions though.
Got it. So is the code 18055 because of the ABS module being incorrect?
-Charles
jettarv
Canada
C?ID=345286
The abs MK60EC1 module is coded from the serial number of the vehicle, so it is impossible to copy from one car to another, it will always be rejected. It takes the coding of your abs module from the car in question that worked before the modification, then we modify it.
For the abs sensors, I imagine that the rear axle of the passat is from around 2009? Since you have the lane asssit on the jetta, I'm pretty sure you need active ABS sensors. For passat b6 4motion, it doesn't exist. But you can take those from mk7, # WHT003856B and WHT003857B. (those on the jetta are probably WHT003858A or B and WHT003859A or B).
for code 18055, probably yes... that's the reason.
jettarv
Canada
C?ID=345286
if it doesn't work
try this one
A14B600C49250503850B06E5921FA041A118F06A
jettarv
Canada
C?ID=345286
I made this modification on a gti mk6, possible that on a jetta it is different since it never exists in awd. At this point, I can't help anymore..
dahui9
Florida, USA
C?ID=107129
I appreciate all of the assistance you have provided, I will try the adjusted codes and see if I can get something to work.
The new 6R knuckles I have coming tomorrow have their active sensors in them, I'll double check to see if they work. If the 6R ones don't work I'll order the 7R versions.
Cheers again!
-Charles
dahui9
Florida, USA
C?ID=107129
Update!
Coding finally accepted. IDK if copying the text from outside of VCDS and pasting back into VCDS causes issues, but the above code didn't work. I finally tried to copy my original VCDS code above, pasted below, changed the bits noted in this post directly, and it worked! Coding is the exact same as mentioned by Mike for AWD.
-Charles
jettarv
Canada
C?ID=345286
I'm glad i could helped you!
iichel
Eindhoven, NB, NL
C?ID=284912
if you don't mind sharing a full scan, that would be great
dahui9
Florida, USA
C?ID=107129
Well I finally got the chance to drive the car, barely before it popped back up. Here is the latest full autoscan, I'm getting rear abs sensor codes now, I'm using Bosch model "OE" items. I hope they aren't the cause.
Wednesday,03,February,2021,21:22:47:38452
VIN: 3VW4T7AJ8FM239016   Mileage: 87480km-54357miles
22-AWD -- Status: Sporadic communication error 1000
   Revision: --H13---
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:26:02
                    Coolant temperature: 45 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 11.464 V
                    T_AST_SAE: 0 s
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:58
                    T_AST_SAE: 0 s
                    FUP_H_SAE: 14310.0 kPa
21428 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
          P2431 00 [039] - Implausible Signal
                    Mileage: 87482 km
                    Vehicle speed: 255 km/h
                    Coolant temperature: 21 °C
                    Intake air temperature: 21 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 11.660 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 0 kPa
                    FAC_TPS_1_SAE: 17.578125 %
                    FUP_H_SAE: 1490.0 kPa
17178 - Databus
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:58
   Revision: 00H46001
   Coding: A14B600C49250103850B06E5921F8041A118F06A
   Shop #: WSC 00066 123 12345
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2015.06.27
                    Time: 09:48:18
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 44544
                    Count: 65280
                    Count: 252
            P1647 - 000 -
                    Reset counter: 97
                    Date: 2015.06.27
                    Time: 09:48:31
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 197
                    Count: 44544
                    Count: 65280
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2015.06.27
                    Time: 09:48:09
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 87
                    Count: 44800
                    Count: 65280
                    Count: 252
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2015.06.27
                    Time: 09:48:09
                    Count: 7
                    Count: 14
                    Count: 20480
                    Count: 71
                    Count: 44800
                    Count: 65280
                    Count: 252
   Coding: 030C0C
   Revision: 00001K02
   Coding: 0010019002
   Revision: BL122001
   Coding: 02300A
   Coding: 00004B33
   Coding: 303355
                    Reset counter: 137
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:26:13
   Coding: 0012440008
   Coding: B1FFFF
   Coding: 271E01
   Coding: 351002
                    Fault Status: 00110100
                    Reset counter: 137
                    Mileage: 87482 km
                    Date: 2015.06.27
                    Time: 04:26:24
                    Mileage: 87482 km
                    Date: 2015.06.27
                    Time: 04:25:57
   Coding: 0000005
   Coding: 000007
   Coding: 01011102
   Coding: 010111
   Coding: 0404BD
   Slave Driver:
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:57
   Revision: 00H22000
                    Fault Frequency: 15
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2015.06.27
                    Time: 09:52:44
                    Voltage: 12.38 V
                        DD
                    Temperature: 21.0°C
   Coding: 01030100
   Coding: 180000
   Coding: 0404BC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:57
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:57
13705985 - Databus
                    Fault Frequency: 8
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:26:42
13705987 - Databus
                    Fault Frequency: 8
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:26:42
Address 56: Radio
          B201A 00 [009] - -
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:56
                    Voltage terminal 30: 11.4 V
          B2000 87 [009] - Missing message
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 09:35:33
                    Voltage terminal 30: 11.5 V
                    System_Software_Error-SW_Status_Consistency: 01 9C 01
                    System_Software_Error-SW_Status_Device: a
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:56
2562 - Navigation System
          B126C F0 [009] - Navigation Database Faulty
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:42:10
                    Voltage terminal 30: 11.7 V
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 04:25:57
                    Fault Priority: 8
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.03
                    Time: 09:53:45
End----------(Elapsed Time: 01:24, VBatt start/end: 12.5V/12.4V)-----------
I car still wont shift, but 1st and reverse engagement is fine so I am still assuming its ABS sensor related. I'm about to bite the bullet on official VW MK6R OEM rear ABS sensors. I did read though that typically if you get faults for both it's a coding concern, I'm not sure if it applies here though. This has become fun at this point aka frustrating, but the joys of being a pioneer right?
Edit: On another note, tomorrow I will log the sensors using measuring block 1 tomorrow on a quick jaunt down the road, I should have probably done this today. If I'm getting the codes above though for 03841-2 I can only assume I wont have the correct speeds.
-Charles
jettarv
Canada
C?ID=345286
Hi , you have several problems. I will start by solving the problem of the rear abs sensors.
if you have r mk6 golf rear knuckle installed, you need the most accurate sensors for blind spot detection. but the mk6 did not originally have this type of sensor. the resistance in ohms is not the same, which explains the error. you need a sensor with the number WHT003856B and 857B (the A also works, it is replaced by B now). if you want to confirm before buying, try to plug in your gli sensors without inserting them in the knuckle , error should disappear.
the more precise sensors that you need should be gray plastic instead of black
dahui9
Florida, USA
C?ID=107129
Thank you Mike, I will order these because the originals are gone unfortunately, hind site on my part. All else fails they will make good spares for my father in laws Atlas. I'll report back one I have them plugged in and can test them.
-Charles
dahui9
Florida, USA
C?ID=107129
Long awaited update. The vehicle is no longer alerting me to an ABS fault when turning the car on to AUX, this is progress. I do still have a new intermittent code for rear sensors 00287 & 00290, 008 - Implausible Signal - Intermittent. In attempt to look up the code, this specific saying is not in the Wiki, but I'm sure it probably falls under "00290 - ABS Wheel Speed Sensor Rear Left (G46): Signal Outside Specifications" if anything. I did attempt to drive the vehicle and the sensors are all reading properly from what I can tell, below is an annotated chart of my ABS sensor log.
Attached is my latest autoscan, my main concern of coding the car with proper ABS for AWD has been resolved along with the thought that ABS may be the cause of the vehicle not properly shifting for some odd reason. I believe a lot of the codes are a result of needing to clear stored codes at this point, but I'm going to do that once the car is fixed..... See below for the continuation if you'd like.
Saturday,20,February,2021,10:39:25:38452
VIN: 3VW4T7AJ8FM239016   License Plate: 210220
Mileage: 87480km-54357mi   Repair Order: Devine
22-AWD -- Status: Malfunction 1010
   Revision: --H13---
8 Faults Found:
          P0036 00 [175] - Malfunction / Open Circuit
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:39:12
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 11.933 V
                    T_AST_SAE: 0 s
          P2432 00 [175] - Short to Ground
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:39:08
                    T_AST_SAE: 0 s
                    FUP_H_SAE: 6140.0 kPa
          P2431 00 [175] - Implausible Signal
                    Mileage: 87482 km
                    Coolant temperature: 19 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 11.992 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 0 kPa
                    FUP_H_SAE: 7170.0 kPa
15255 - Secondary Air Injection System Valve (N112)
          P0413 00 [237] - Open Circuit
                    Mileage: 87482 km
                    Date: 2021.02.10
                    Time: 00:48:31
                    Engine RPM: 1492.50 /min
                    Normed load value: 29.0 %
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 66 kPa
                    FAC_TPS_1_SAE: 14.453125 %
                    FUP_H_SAE: 11800.0 kPa
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:39:08
26384 - Databus
          U1123 00 [109] - Received Error Message
                    Mileage: 87482 km
                    Date: 2021.02.10
                    Time: 00:49:24
                    Engine RPM: 1873.00 /min
                    Normed load value: 16.9 %
                    Vehicle speed: 16 km/h
                    Coolant temperature: 39 °C
                    Voltage terminal 30: 14.335 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 52 s
                    MAP_MES_SAE: 45 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.002 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 11910.0 kPa
21323 - Implausible Data Received from ABS Control Module
          U0415 00 [040] - -
                    Mileage: 87482 km
                    Voltage terminal 30: 11.835 V
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 18.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 2880 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    Cruise control switch actuation-Control component verified: No
                    STATE_ERR_ABC_PRED: 0
23131 - Implausible Data Received from ABS Control Module
          U0415 00 [040] - -
                    Mileage: 87482 km
                    T_AST_SAE: 0 s
                    FAC_TPS_1_SAE: 23.046875 %
                    FUP_H_SAE: 7200.0 kPa
Readiness: 1010 1101
17116 - Gear 2
            P0732 - 000 - Incorrect Ratio - Intermittent
                    Reset counter: 8
                    Mileage: 87484 km
                    Date: 2015.07.04
                    Time: 01:46:15
   Revision: 00H46001
                    Reset counter: 137
                    Mileage: 87483 km
                    Date: 2015.07.04
                    Time: 01:09:34
                    Count: 16386
                    Count: 4
                    Count: 12800
                    Count: 86
                    Count: 49156
                    Count: 62979
                    Count: 258
                    Count: 2304
                    Reset counter: 137
                    Mileage: 87483 km
                    Date: 2015.07.04
                    Time: 01:09:33
                    Count: 16386
                    Count: 4
                    Count: 12800
                    Count: 70
                    Count: 49412
                    Count: 63490
                    Count: 256
                    Count: 2048
            P1647 - 000 -
                    Reset counter: 97
                    Date: 2015.07.04
                    Time: 01:07:46
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 197
                    Count: 43520
                    Count: 65280
   Coding: 030C0C
   Revision: 00001K02
   Coding: 0010019002
   Revision: BL122001
   Coding: 02300A
   Coding: 00004B33
   Coding: 303355
                    Reset counter: 137
                    Mileage: 87482 km
                    Date: 2021.02.10
                    Time: 00:48:49
   Coding: 0012440008
   Coding: B1FFFF
   Coding: 271E01
   Coding: 351002
                    Reset counter: 137
                    Mileage: 87482 km
                    Date: 2015.06.28
                    Time: 04:26:24
                    Fault Frequency: 95
                    Mileage: 87482 km
                    Date: 2015.06.28
                    Time: 04:25:57
   Coding: 0000005
                    Fault Status: 01101000
                    Reset counter: 138
                    Mileage: 87483 km
                    Date: 2015.07.04
                    Time: 01:40:06
   Coding: 000007
   Coding: 01011102
   Coding: 010111
337904 - Databus
          [mBremse_10::B10_QB_Wegimp_HR - Ersatz_Init_oder_Fehlerwert]
                    Reset counter: 137
   Coding: 0404BD
   Slave Driver:
   Coding: 800000
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:36:11
   Revision: 00H22000
                    Fault Status: 00101101
                    Reset counter: 137
                    Mileage: 87482 km
                    Date: 2015.07.04
                    Time: 00:48:35
                    Voltage: 14.13 V
                        DU
                    Temperature: 21.0°C
                    RPM: 1331 /min
   Coding: 01030100
   Coding: 180000
   Coding: 0404BC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:36:32
                    Fault Frequency: 26
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.04
                    Time: 04:25:57
13705985 - Databus
                    Fault Frequency: 11
                    Reset counter: 137
                    Mileage: 87482 km
                    Date: 2021.02.04
                    Time: 04:26:42
13705987 - Databus
                    Fault Frequency: 14
                    Reset counter: 137
                    Mileage: 87482 km
                    Date: 2021.02.04
                    Time: 04:26:42
Address 56: Radio
          B201A 00 [009] - -
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:36:46
                    Voltage terminal 30: 11.9 V
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.10
                    Time: 00:49:30
                    Voltage terminal 30: 14.4 V
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:36:46
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:53:53
                    Voltage terminal 30: 12.2 V
                    Reset counter: 97
                    Mileage: 87482 km
                    Date: 2021.02.09
                    Time: 00:37:03
                    Fault Priority: 8
                    Reset counter: 97
                    Mileage: 87484 km
                    Date: 2021.02.20
                    Time: 23:09:51
End----(Elapsed Time: 01:26, VBatt start/end: 11.1V/11.1V. VIgn 11.0V)-----
For anyone interested in following along, I believe I have finally verified the culprit to my not-shifting issue. The photo shown (top) is my gearbox and the sensor jumping around "hitching" if you will, and a normal (bottom) working vehicle. Keep an eye on the blue/purple line of the top graph (as nothing was properly labeled). That jagged edge I believe is small amounts of clutch slip, which is causing a incorrect ratio code as it cannot properly determine when to go into second gear.
Mine
Properly working gearbox
Both gearboxes in the above image have had the same work done, Mechatronics from the original vehicle, put into the new transmission, and software matched to the proper gearset inside the new transmission. This was done as both gearboxes are MK7 gearboxes with component protection, so to get around that we verified internal hardware and completed the mechatronics swap. The difference being the bottom working gearbox in the graph was a drop in with no work done, mine was not. I had to transfer my clutch pack after verifying they were the same part number, and retaining clip as the original owner of my AWD transmission was going to do a clutch upgrade but decided to go DQ500 instead. I never wound up receiving the clutches. Well it turns out those retaining clips are shimmed like a differential and using an improperly sized one can cause the exact scenario I'm having.
My resolution is going to be taking the gearbox out myself, building the transmission since it is out with LSD and new clutch pack properly following protocol, re-installing and going from there.
-Charles
