Trying to clear fault codes on my mate's VW Crafter and I'm getting 'No Response from Gateway' or 'Gateway did not Respond' error (apologies, I'm posting this after arriving home so can't quite remember the error message).
I've included the output of the scan below - any help in resolving this issue so I can clear fault code would be appreciated.
The specific fault I'm trying to clear is as follows - we believe the fault code was caused because the seat belt tensioner plug was accidentally disconnected - nothing wrong (as far as we know) with the seat belt tensioner igniter:
Address 94: LT3 Airbag
Part No HW: 9069005701
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F78638F5873DC3704-8001
9391 - Safety Belt Tensioner Igniter (N294): resistance too low
Test Complete - Stored
9390 - Safety Belt Tensioner Igniter (N294): resistance too high
Cheers, Nick.
Cheers, Nick.
Thursday,21,January,2021,14:22:53:26294
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
VCDS Version 20.12.0.1 HEX-V2 CB: 0.4529.4
VIN: WV1ZZZ2EZF6023579 License Plate: XXX XXX
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB) Labels:. 03L-906-012-CKT.clb
Part No SW: 03L 906 012 A HW: 03L 906 012 A
Component: R4 2,0L EDC H26 5298
Revision: 72H26--- Serial number: VWXDZ0N1047351
Coding: 0119401020440C080000
Shop #: WSC 00000 555 00117
ASAM Dataset: EV_ECM20TDI01103L906012A 002012
ROD: EV_ECM20TDI01103L906012A_002.rod
VCID: 221DEDE4F4499A7B456-8077
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 843 C HW: 906 900 590 2
Component: IMMO 1231 1322
Revision: 00231000 Serial number: VWXDZ0N1047351
VCID: 270BFCF093EB7F53128-8073
01176 - Key
Address 95: LT3 ESP
Part No HW: 0009013202
Serial number: 000901320210851
ASAM Dataset: CRFT2_ESP 3
ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
Part No SW: 9069026601 HW: 9069014501
ASAM Dataset: 32 1056
ROD: CRFT_KOMBI_32_1056.rod
VCID: 074B9C707FAB5F53328-8053
9128 - Voltage: Lower limit not reached
Address 99: LT3 Ign. Switch
Part No HW: 9069005902
ASAM Dataset: 67 259
ROD: CRFT_EZS_67_259.rod
9001 - Voltage: Lower limit not reached
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 1231 1322
Revision: 00231000 Serial number: 12345678901234
00172 - Key 2 not learned
Address 9B: LT3 Driver Door
Part No HW: 9069000501
ASAM Dataset: 33 263
ROD: CRFT_FTUHR_33_263.rod
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BA3F08033630BB3260-802F
909B - Alarm Horn (H12): No communication
9097 - Interior monitoring: Self-test malfunction towing protection
9001 - Terminal 30: Lower limit not reached
9094 - Interior Monitoring Sensor (G273): Self-test malfunction
Address B4: LT3 Central Elec.
Part No SW: 9069024301 HW: 9069014500
ASAM Dataset: 33 852
ROD: CRFT_EZE_33_851.rod (*)
VCID: 025D8D6454897A7B656-8057
9017 - Right side-marker lights: Open circuit
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
Address B6: LT3 Steering Wheel
Part No SW: 9065402545 HW: 9065402545
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 08499F4C72B5502B3B2-805D
End----(Elapsed Time: 00:50, VBatt start/end: 11.1V/11.6V. VIgn 11.6V)-----
