Friday,22,January,2021,10:14:05:31491
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 20.12.0.1 (x64) HEX-V2 : 0.4529.4
VIN: WVGFK9BPXBD005152 License Plate:
Mileage: 215433km-133863mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 69 6C 6D 72
VIN: WVGFK9BPXBD005152 Mileage: 215433km-133863miles
03- Brakes -- Status: OK 0000
04-Steering Angle -- Status: Cannot be reached 0100
05-/Start Auth. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI FSA H17 0008
Revision: 56H17---
Coding: 292A4012233600050000
Shop #: 04938 444 00000
Dataset: EV_ECM30TDI0117P0907401J 002007
ROD: EV_ECM30TDI0117P0907401J_002.rod
VCID: 3635209428C0CD8B99E-8062
16871 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [096] - Implausible Signal
Mileage: 215081 km
Date: 2021.01.10
Time: 13:00:01
Engine RPM: 1706.00 /min
Normed load value: 89.4 %
Vehicle speed: 103 km/h
Coolant temperature: 93 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.560 V
Unlearning counter according OBD: 34
Exhaust gas jet volume in particle filter: 429.3 m³/h
Particle filter: difference pressure: 72 hPa
Particle filter: soot mass measured: 7.56 g
Particle filter: soot mass calculated: 5.39 g
Exhaust gas temperature sensor 3: 450.2 °C
Exhaust gas temperature sensor 4: 545.4 °C
9690 - Sensor for NOx (G295)
P1032 00 [096] - Signal too High
5523 - Engine Start Blocked by Immobilizer
P1570 00 [096] - -
Mileage: 214837 km
Date: 2020.12.30
Time: 19:20:12
Engine RPM: 1080.50 /min
Normed load value: 23.9 %
Coolant temperature: 11 °C
Intake air temperature: 12 °C
Voltage terminal 30: 10.940 V
Unlearning counter according OBD: 25
Address 02: Auto Trans
Address 03: Brakes
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H24 0217
Coding: 0D860000000000000000
Shop #: 31414 790 00001
VCID: 72BDDC8404A891AB756-8026
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV H38 0044
Serial number: 2311000016905004
02811 - Control Module for Electronic Steering Column Lock (J764)
014 - Defective - MIL ON
Fault Status: 11101110
Reset counter: 2
Mileage: 215433 km
Date: 2021.01.19
Time: 09:19:18
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 2
Mileage: 215433 km
Date: 2021.01.19
Time: 14:06:49
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: B686200A80
Dataset: EV_AirCondiFront 004001
VCID: 79AFEBA8595EE2F334C-802C
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 54
Reset counter: 39
Mileage: 214211 km
Date: 2020.12.03
Time: 10:46:04
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000798690
Coding: 26005092973C5D010020180300005D0C431C660882010261000000020000
Shop #: 12345 123 61029
VCID: 313F1388C12EEAB3CCC-8064
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110220 31 0020
Serial number: 90243400110226073912
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: H09 0011
Serial number: 10128277
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - H04 0031
Serial number: 00000000001702110581
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Fault Status: 00101100
Fault Frequency: 55
Reset counter: 39
Mileage: 214211 km
Date: 2020.12.03
Time: 10:46:00
Address 10: Park/Steer Assist
Address 15: Airbags
Part No SW: 4H0 953 568 B HW: 7P6 953 507 A
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KBN00007
Coding: 000C15
VCID: 323D1C84C428D1ABB56-8066
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0059348
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H12 0239
Revision: 10240061 Serial number: 658060211593013
Coding: 8B7733022B00CF05020004
Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 47CB5D505F2A4403F28-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000102335
Coding: 0001037500
Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 38292EAC22D43BFB8B2-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650659521
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002321445
Coding: 00581B0000004001000001010101202020202121202020
VCID: 34311A9C3E3CDF9BA7A-8060
Revision: 00002001 Serial number: 0144290043
Coding: 0186123A28B9509580A00620210000000000000000000000000000000000
Component: BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO11346672
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO1133311U
Coding: 191100
Fault Status: 11101100
Fault Frequency: 39
Reset counter: 2
Mileage: 208013 km
Date: 2020.02.17
Time: 09:14:34
Address 47: Sound System
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
Address 56: Radio
Address 62: Door, Rear Left
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000023299
Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDB45B007FA0CC34A8-806A
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001001 Serial number: 00000143312417
Coding: 020D000000000000
VCID: 372B2D902F4A3483828-8062
Address 6C: Back-up Cam.
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 047100204
Coding: 0533314003
Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
VCID: 7CA1F2BC566CD7DB2FA-8028
0028 - Motor 1 for rear lid
B11D9 13 [008] - Open Circuit
Fault Frequency: 114
Reset counter: 25
Mileage: 208212 km
Date: 2020.02.29
Time: 20:49:39
Voltage terminal 30: 12.34 V
Address 72: Door, Rear Right
End----(Elapsed Time: 01:31, VBatt start/end: 11.9V/12.3V. VIgn 0.0V)------
