- Jan 20, 2021
- 3
- 3
- Spanish Fort, AL, USA
- C?ID=426516
Dash error ABS/stabilization. I was getting no speed reading in my right rear wheel when logging data. I assumed it was a wheel speed sensor so i replaced it and attempted to clear faults. I am still not getting a reading on the right rear wheel and have the following ? I have gone through the fuse boxes and see no fuses out. Any ideas which way to go next? Thanks in advance.
Wednesday,20,January,2021,12:33:05:42906
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: 3VWB67AJ1HM200639 License Plate:
Mileage: 81880km-50877mi Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 03 04 05 08 09 15 17 19 25 2B 3C 44 5F 75
VIN: 3VWB67AJ1HM200639 Mileage: 81880km-50877miles
Address 01: Engine (J623-CZTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AK HW: 04E 907 309 AP
Component: R4 1.4l TFS H22 3532
Revision: X5H22---
Coding: 01110012232400001000
Shop #: WSC 00066 790 00015
ASAM Dataset: EV_ECM14TFS01104E906023AK 004003
ROD: EV_ECM14TFS_004_VW32.rod
VCID: 698FB6D2E9F39BE3C4D-803C
4674 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
[ABS brake control moduleRead out DTC]
Mileage: 81884 km
Date: 2021.01.20
Time: 17:25:30
Engine RPM: 0.00 /min
Coolant temperature: 52 °C
Intake air temperature: 19 °C
Voltage terminal 30: 12.180 V
Outside temperature: 20 °C
Absolute intake pressure: 102 kPa abs
Engine torque: 0.0 Nm
Fuel level: 37.00 l
Electric drive torque: actual value: 0.0 Nm
Readiness: 0110 0101
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A14B400C492200FA851102E7922200402110F01A
Shop #: WSC 00066 000 00000
VCID: 75B7EAA2B5CB4F03505-8020
Reset counter: 177
Mileage: 81884 km
Date: 2021.01.20
Time: 17:25:25
Count: 16391
Count: 12288
Count: 16390
Count: 44032
Count: 256
Count: 512
Count: 9472
03842 - RPM Sensor Rear Right: Incorrect Signal
Reset counter: 177
Mileage: 81884 km
Date: 2021.01.20
Time: 17:25:25
Count: 16387
Count: 12288
Count: 87
Count: 44032
Count: 256
Count: 512
Count: 9472
Part No SW: 5K0 959 434 G HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1305
Revision: 00092000 Serial number: 0406609428
Coding: 032C0C
Shop #: WSC 00066 000 00295
VCID: 392F2692D9D3EB6374D-806C
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 DA HW: 5C0 820 047 DA
Component: J301 Klimaanlage 0211
Revision: 2001401S Serial number: 00000003349543
VCID: 629DA1FE1845C8BB057-8036
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 190 B HW: 7E0 937 190
Component: BCM PQ25 Max3 H81 0744
Revision: B8081001 Serial number: 88003180160011
Coding: 7B994B9A08AB0B0008392080240884C54BC6722E600151F0B0A050032844
VCID: 2B030CDA230F49F3F61-807E
Subsystem 1 - Part No SW: 6R0 959 801 DF HW: 6R0 959 801 DF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 022 1467
Serial number: 14102743160603003442
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 DJ HW: 6R0 959 802 DJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 022 1467
Serial number: 14102742160529131637
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 A HW: 6R0 959 591 D
Component: J245 PS41.402 H03 0004
Serial number: 0000FST000XCMVQ00000
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Serial number: 1521614105501442AD1B
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1467
Serial number: 14102745160531014339
Subsystem 6 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1467
Serial number: 14102744160528095724
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 001 0207
Serial number: 003RXM06GAH5
Coding: 8CCCF000000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 6393A4FA0BDFC1B30E1-8036
Component: BF-Gewichtss. H12 0021
Serial number: IBH0000000000059BW9Q
Coding: 303146
Subsystem 2 - Part No SW: ----------- HW: 480 000 705 16
Serial number: 357000000003EC982B1W
Subsystem 3 - Part No SW: ----------- HW: 480 000 705 16
Serial number: 358000000002EC982B1W
Subsystem 4 - Part No SW: ----------- HW: 480 021 005 16
Component: SideSensor_Dr 000 0148
Serial number: 3510001B52100D43284K
Subsystem 5 - Part No SW: ----------- HW: 480 021 005 16
Component: SideSensor_Pr 000 0148
Serial number: 3520001B52100D43669S
Subsystem 6 - Part No SW: ----------- HW: 480 020 305 16
Component: FrontSensor_D 000 0189
Serial number: 3550001C51ECD9D664E.
Subsystem 7 - Part No SW: ----------- HW: 480 020 305 16
Component: FrontSensor_P 000 0189
Serial number: 3560001A31F2140517AV
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Reset counter: 178
Mileage: 81884 km
Date: 2021.01.20
Time: 17:25:59
Part No SW: 5C6 920 976 D HW: 5C6 920 976 D
Component: KOMBI H02 1104
Coding: 221A010000
Shop #: WSC 00066 790 00318
VCID: 333314BAFBBF1133BE1-8066
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 190
Component: GW-K-CAN TP20 H81 0744
Revision: B8081001
Coding: 102201
VCID: 6889B3D6F279A2EBDB3-803C
Component: IMMO H02 1104
Coding: 000007
VCID: 6A8DC9DEECF590FBCD7-803E
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000079310008
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X_VW01.rod
VCID: 313F1EB201A32323CCD-8064
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0400936001
Coding: 01011101
Shop #: WSC 01383 790 50316
ROD: EV_HREntryHella_VW32.rod
VCID: 3C213F86D6E1DE4B6FB-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0401161118
Coding: 010111
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 304 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F2692D553EB6374D-806C
Fault Status: 11101101
Reset counter: 178
Mileage: 81886 km
Date: 2021.01.20
Time: 17:29:19
Voltage: 14.25 V
DU
Temperature: 24.0°C
RPM: 819 /min
Part No SW: 5C0 035 200 B HW: 5C0 035 200 B
Component: MU-S-S-US H30 0357
Serial number: VWZAZ2S0249483
Coding: 02630100AA00000051220001001808009F0100D40020010002
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 1471B7269EF1F60BC7B-8040
0524 - Connections to Front Left Loudspeakers
B1109 11 [009] - Short to Ground
Reset counter: 177
Mileage: 81884 km
Date: 2021.01.20
Time: 17:25:27
Voltage terminal 30: 12.0 V
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0158
Serial number: 000003554140550
Coding: 02630102C21632107F1606C00000
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
End----------(Elapsed Time: 01:23, VBatt start/end: 14.2V/14.2V)-----------
