Hello to the forum!
I am about to replace my G450 sensor after getting the following errors recently:
I am now checking that everthing is in place before proceeding, but when I try to check the steps for adaptation after replacing the sensor, I noticed that Coding II button is greyed out.
I would like to ask:
1. Is adapatation of the new sensor necessary?
2. Should I follow the follow procedure for adaptation for my car? Or is there any other way for my case?:
UDS Protocol (G450) procedure
Key ON, Engine OFF
[Basic Settings]
Select Adaptation of diff. pressure sensor particulate filter
[Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
Select Resetting of learned values of difference pressure sensor
[Done, Go Back]
Thanks!
Monday,18,January,2021,19:08:16:46225
VIN: WVWZZZ6RZBY056090 License Plate:
Mileage: 133350km-82859mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZBY056090 Mileage: 133350km-82859miles
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BC HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 6909
Revision: -------- Serial number:
Coding: 00114014000500080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023BC 003005
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 6889BA3D92F8925BFA3-803C
7397 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [032] - Short to GND
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 8 °C
Intake air temperature: 10 °C
Voltage terminal 30: 11.181 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 9.04 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 8.30 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 2 km
Zähler der Regenerationszeit des Partikelfilters-T_INT_RGN_ACT_INI_PF_ENVD_H: 0.0000 s
Particle filter: difference pressure-DIP_PF: 0.00 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
Sensor for temp after charge air cooler: raw value-TBA_MES: 10 °C
7347 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [101] - Implausible Signal
Mileage: 133344 km
Date: 2021.01.16
Time: 15:43:13
Engine speed: 889.50 /min
Normed load value: 7.5 %
Coolant temperature: 71 °C
Intake air temperature: 22 °C
Voltage terminal 30: 13.779 V
Particle filter: offset for differential press.-DIP_PF_AD[0]: 80.02 hPa
Outside air temperature-Ambient temperature: 9.00 °C
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 10.06 g
Air mass: actual value:: 8.43 g/s
7346 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
Coolant temperature: 69 °C
Intake air temperature: 19 °C
Voltage terminal 30: 13.101 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 4.33 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 10.42 g
Air mass: actual value:: 5.62 g/s
Readiness: 0100 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 230228E3417200B8C42514EB82D100821300
Shop #: WSC 02069 000 00000
VCID: 06559485B86C642B68F-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 35372349954A3FB3B15-8060
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0345 196101793
Coding: 25B029BF08E12400922000003D2B0CD00000410F60060000200000000000
Shop #: WSC 00631 210 91765
VCID: 42DD4895D484980B047-8016
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0912
Serial number: KU0-KU030.06.1011032
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0912
Serial number: KU0-KU001.07.1011838
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H11 9004
Subsystem 5 - Part No: 1K8 951 171 A
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag00A H09 0020
Revision: -------- Serial number: 003GX004AVS$
Coding: 003041
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD60B5EC34404BCC7-801E
Serial number: 3572SRB40000C31D41F7
Serial number: 3582SRB40000C291419/
Serial number: 3515RRB40696Q5E6BGS
Serial number: 3525RRB405D6R0C291RE
Part No SW: 6R0 920 961 F HW: 6R0 920 961 F
Component: KOMBI H04 0304
Coding: 440A00
VCID: 392F2F79B9D2DBD355D-806C
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 002100
VCID: 70B9D25DAAA85A9BA23-8024
Component: IMMO H04 0304
VCID: 6A8DC0358CF4A04BEC7-803E
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668265792
VCID: 270BF9015FE65D23339-8072
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F3B11217E560563FB9-807A
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5516
Revision: -------- Serial number: VWZZZ4J6278413
Coding: 16000400040005
Shop #: WSC 127395 840 08317
VCID: 46D55485F8ACA42B28F-8012
Fault Status: 00110100
Reset counter: 100
Mileage: 133289 km
Date: 2015.06.01
Time: 01:59:50
End----(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
Monday,18,January,2021,19:11:24:46225
P2453 00 [036] - Implausible Signal
Coolant temperature: 64 °C
Intake air temperature: 18 °C
Voltage terminal 30: 11.972 V
Air mass: actual value:: 0.64 g/s
Readiness: 1110 1000
Revision: --------
Revision: 00 11 25
Coding: 08BC30
Coding: 08BC30
Coding: 003041
Coding: 440A00
Coding: 002100
Coding: 11230
Shop #: WSC 00788
Reset counter: 104
Mileage: 133355 km
Date: 2015.06.11
Time: 19:08:18
00877 - Treble Speaker Rear Right (R16)
Reset counter: 104
Mileage: 133355 km
Date: 2015.06.11
Time: 19:08:18
End----------(Elapsed Time: 01:32, VBatt start/end: 14.0V/14.1V)-----------
Key ON, Engine OFF
[Basic Settings]
[Done, Go Back]
Thanks!
