Hi. I have a fault on a 2010 car with the 1.2tdi greenline engine. It's been to a main dealer who simply cleared the code and said they had no test steps given to them. Of course it has come back.
Any idea what the code means, and why VCDS doesn't know what it is? Could it be missing from the .rod file for the ECU? The only references I've found in searches is to people who have never found out what the code was. The car is playing up on almost every drive cycle now so I'd like to have VCDS give me some clues.
It's an odd little fault: Glowplug lights starts flashing. Engine speed won't drop below 1500 RPM until you get off the brake pedal which means an odd dance where you have to press the clutch so the high revs aren't puliing you along against the brakes, then get off the brakes and back on again, and the engine speed drops off.
Anyhow, here's the log:
Thursday,21,January,2021,15:25:43:49572
VCDS Version: 20.12.0.1 (x64)
VIN: TMBKK25J5B3135251 License Plate: BF60SYH
Mileage: 29970km-18622mi Repair Order:
Chassis Type: 5J-SK25 (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 61
VIN: TMBKK25J5B3135251 Mileage: 29970km-18622miles
Address 01: Engine (J0000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 L HW: 03P 906 021 K
Component: R3 1.2 DCM3.7 H03 7882
Revision: 12004001 Serial number:
Coding: 00114014032501080000
Shop #: WSC 13765 031 00051
ASAM Dataset: EV_ECM12TDI03103P906021L 001005
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 3169295260E8FE0CBD-8064
15604 - ROD - Unknown Error Code
- 00 [008]
Engine RPM: 0.00 /min
Coolant temperature: 0 ∞C
Intake air temperature: 0 ∞C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Unlearning counter according OBD: 1
Crankshaft speed (RPM): 0 /min
Ambient air pressure: 0 kPa
Voltage terminal 30 stabilized: 0.0 V
Engine status: Engine stopped
OBD Driver demand indicated torque: 0 %
Mean injection quantity: 0.0 mg/stroke
Exhaust gas temperature sensor 1: 0 ∞C
Outside temperature: 0 ∞C
Sensor for engine block temperature: raw value: 0 ∞C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AA HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0003
Revision: --------
Coding: 430124DB417000B7C22724E782D200921300
Shop #: WSC 13765 790 00051
VCID: 7DF1C562E030CA6C69-8028
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 5J0 820 045 C HW: 5J0 820 045 C
Component: Man AC 02 0101
Revision: 0003S 02
VCID: 2541CD022C20A2AC51-8070
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 D HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0322
Revision: BU046001 Serial number: 0379 265100704
Coding: 25980B3808C92400922001303E0B08C00E80420F7E000040000000000000
VCID: 3F8D7F6AAEBC187C3B-806A
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3210
Coding: 430000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3210
Coding: 420000
Subsystem 3 - Part No: 5J0 951 172
Component: DWA-Sensor 03 03 1109
Component: LIN BACKUP HO H11 9004
Subsystem 5 - Part No: 5J0 951 172
03080 - Activation for interior lights
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 24
Mileage: 29898 km
Date: 2015.05.30
Time: 16:07:13
Reset counter: 25
Mileage: 29932 km
Date: 2015.06.13
Time: 12:25:10
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagT2C H09 0020
Revision: -------- Serial number: 003GX00BSA5K
Coding: 003243
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4A9B5EBEED7EADD49C-801E
Serial number: 3495RRB405F0974OLHEY
Serial number: 3505RRB405H0974O78H8
Part No SW: 5J0 920 910 J HW: 5J0 920 910 J
Component: KOMBI H07 0114
Serial number: 00000004588827
Coding: 420A00
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01013
ROD: EV_DashBoardUDSJCIPQ25_A01.rod
VCID: 2E53322E71D6E1F4A0-807A
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 201010F2001973
Coding: 2523C3
VCID: 3365235A92F4CC1CCF-8066
Address 25: Immobilizer (J285) Labels: 5J0-920-xxx-25.clb
Component: IMMO H07 0012
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25_VW25.rod
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Revision: A1001003 Serial number: 7669032363
VCID: 285FC4365B32BFC46A-807C
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11210
Shop #: WSC 13765
VCID: 2F6D2F2AEADCE8FCAB-807A
Part No SW: 5J0 035 161 C HW: 5J0 035 161 C
Component: Radio-SWING 009 0034
Revision: -----09S Serial number: SKZ4Z2K1415676
Coding: 010004000006
VCID: 224BD61E3D0E559434-8076
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 030B1A5A
VCID: 74E7E046D77A8B2416-8020
Component: J367-BDM H07 0125
Serial number: 00000000002790318614
End-------------------------(Elapsed Time: 02:57)--------------------------
