3G0920790E - Passat
VAGParts
Denmark
C?ID=61241
Does anyone know if I can retrofit 3G0920790E instrument in my Passat from 2016 ...?
I've heard they have another immobilizer.
Bruce
Near Philadelphia, PA, USA
Your Passat has equipment. How can we know what equipment it has? Do you think that the electronics in all of these cars are the same? Why is a simple request for information a problem? Do you want help and suggestions? Then post the scan so others can know the context of your request. Else, I doubt any will be able to assist.
Tharkhold
Canada
C?ID=311665
interesting response...
You're asking the VCDS folks for advice and help on an electronic retrofit part... and wonder why they would ask for an autoscan on these forums where it's fairy obvious that starting posts mostly always have one.
If you're afraid about your car's vin appearing in a public forum, just edit it out. It's mostly only required for coding items such as an MK60EC1 ABS units anyways...
VAGParts
Denmark
C?ID=61241
Sorry, but I just do not see how an autoscan helps my question.
I ask if anyone knows if there is a difference between immobilizer in a Passat 2016 and instrument 3G0920791E.
You can not see my current immobilizer from an autoscan anyway.
siLc
Tallinn, Estonia
C?ID=330192
In regards to immo, cluster will need matching to the car anyway. This can't be done with VCDS.
CretuMD
Bucharest, Romania
Hi all,
I will continue Vagparts ideea :) recently I retrofit a GTE cluster without maps function. After some discussions with the guys who installed it I went even deeper :) next up is pACC with new radar and adaptations.
But after that I am very curios if someone did a retrofit from 2018+ cluster to pre-facelift.
Chassis Type  3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 55 5F 65
          6C 6D A5 BB BC CF
VIN: WVWZZZ3CZHE056504   Mileage: 713km-443miles
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H24 2011
   Revision: B4H24---
   Coding: 011D0032036405083000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
   ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
   VCID: 7BF542EBF2E5695E5E-802E
   Part No SW: 0D9 300 042 F    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4901
   Revision: 06354004    Serial number: TFK01607060311
   Shop #: WSC 05311 115 00066
   ROD: EV_TCMDQ250021.rod
   VCID: 1C37617717ABCE66F7-8048
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62266000001602
   Coding: 0FEC6A8F34250B72477C060041C749F0562CD0E2608292713862F0084AA902
   Shop #: WSC 00015 115 08193
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0412802615
   Coding: 0F2020070F
   Shop #: WSC 05311 115 00310
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3C7781F7B76BAE6617-8068
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8056408
   Part No SW: 5G0 907 044 BR    HW: 5G0 907 044 BR
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 12020104202410011115504E00101822
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 78FF5DE7C3D3424633-802C
   Air quality sensor:
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0224
   Revision: --------    Serial number: 8658070816007J
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 010930039009038E04-8054
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160606  042 0607
   Serial number:         160616105624
   Component: RLHS  042 0105
   Serial number: S7Y16M08D10H10M20S24
   Coding: 00A8EE
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 31 05 2016  10001624
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1618709YW
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035558175
   Seat Backrest Fan 1 Front Left:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0091440
   Seat Cushion Fan 1 Front Left:
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0154334
   Seat Backrest Fan 1 Front Right:
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0152325
   Seat Cushion Fan 1 Front Right:
   Subsystem 10 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0154339
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616206
   Coding: 0271167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   VCID: 0D111C33DC5157EE70-8058
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 320467535DFFC728949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3467A9D79F3B6626DF-8060
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STPGC65YT
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0DB6FBE6FD757E72-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 508 16
   Serial number: 3576U0000007D1557C1G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 508 16
   Serial number: 3586U000000521E01C12
   Subsystem 3 - Part No SW: -----------    HW: 454 800 308 16
   Serial number: 3516R2C32030C000000X
   Subsystem 4 - Part No SW: -----------    HW: 454 800 608 16
   Serial number: 3526R0B28020C000000Z
   Subsystem 5 - Part No SW: -----------    HW: 454 802 707 16
   Serial number: 3556V5FF31D0B000000R
   Part No SW: 3Q0 953 521 EK    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF034034    Serial number: 20160725500389
   Coding: 0C10
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7DF14CF3ECF1676E60-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Fault Frequency: 15
                    Reset counter: 17
                    Mileage: 697 km
                    Date: 2021.01.07
                    Time: 13:36:27
                    Ubat 30 Voltage: 12.40 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 245
                    Slope: 134
                    kp: 13
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 39.00 °C
                    p_t_soll_1: 43.00 °C
                    p_t_soll_2: 47.00 °C
   Part No SW: 3G0 920 794 D    HW: 3G0 920 794 D
   Component: KOMBI         402 4191
   Coding: 07AD19986E8C000801807F2F1401000000000000
   Shop #: WSC 00046 123 12345
   VCID: 2D51BCB37C1137EE90-8078
16776990 - Databus
                    Reset counter: 232
                    Mileage: 705 km
                    Date: 2021.01.07
                    Time: 16:25:15
16776997 - Databus
                    Reset counter: 232
                    Mileage: 705 km
                    Date: 2021.01.07
                    Time: 16:25:15
16776999 - Databus
                    Reset counter: 232
                    Mileage: 705 km
                    Date: 2021.01.07
                    Time: 16:25:15
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 07081610801732
   Coding: 0B0300045F087300FB00025A1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CF741F7F7EB6E6657-8028
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160001235680076266
   Coding: 2FFFFF
   Serial number: 75410803001608104105
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0264919
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 16000181048014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E960C3A0A9130EF4-8024
   Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0310
   Revision: --------
   Coding: 04C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   VCID: 387F9DE783538246F3-806C
   Serial number: 190516EEG17873
   Coding: 003F1A20D000020000001000
   VCID: 4385FA0BCA95D19E56-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000994608
   Coding: 01010011005000
   Shop #: WSC 00015 115 00310
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3D718CF3AC71A76E20-8068
   Serial number: 220716EGJ23539
   Coding: 003F1020DE00020000001000
   VCID: 428BFF0FD58FD8965D-8016
   Component: AFS-ECU       H01 0120
   Coding: 039A00004F200200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3F8DF6FBA67DB57E32-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3G0 035 043 D    HW: 3G0 035 043
   Component: MU-H-N-EU     H51 1187
   Serial number: A683I0GB042276
   Coding: 02840201FF0000005111000100080A001F0100E401200000DF
   Shop #: WSC 00028 028 00025
   VCID: 1D316C730CB1C76E00-8048
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H51 8130
   Serial number: VWZ6ZJV0675650
   Subsystem 2 - Part No SW: V03 959 806 NB    HW: -----------
   Component: ECE 2021  --- 0189
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
   Serial number: 30000000025206
   ROD: EV_RDKBERU30_006_VW37.rod
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020162002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
   VCID: 77FD5EDBCECD4D3E3A-8022
   Part No SW: 5Q0 959 107 C    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0260
   Revision: --------    Serial number: 30891595000000
   Coding: 0228
   ASAM Dataset: EV_DeckLidCONTIAU736 001013
   Part No SW: 3Q0 980 653 E    HW: 3Q0 980 653
   Component: MQB_B_MFK     H11 0121
   Serial number: 10081611K21331
   Coding: 00040802000004010026134EC040A100980084300040
   Serial number: 080816DH707568
   Coding: 000E10200100020000001000
   VCID: 4581E413C4A1EFAE78-8010
   Serial number: 080816BH703917
Address CF: Lane Chge Asst 2
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
End-------------------------(Elapsed Time: 06:01)--------------------------
downtime
Finland
C?ID=280813
Hi all,
Are you sure GTE cluster does not have maps? As per my understanding there's only one type of cluster for hybrid Passat's and that has maps support.
What comes to new style cluster to pre-fl, not possible. Different IMMO generation which cannot be online matched. There are some corner cases. For Tiguan there's a new style 10" AID 790D which is still previous IMMO gen but is from 2019 car already.
CretuMD
Bucharest, Romania
There is a long list of AID clusters that support maps or don`t.
Here is an example from etka:
30.05.2016›› _28.05.2017 :
3G0 920 791 B
3G0 920 790 B ( without nav )
3G0 920 794 B ( without nav. hybrid )
3G0 920 795 B ( nav + hybrid )
Also there is 3G1.xxx for GTE. I tried new fiber, upgraded from MIB2STD to MIB2HIGH, tested MIB on other car, I have station logo, cover art etc but no maps.
As for 790D I don`t know if Tiguan Cluster fits in Passat Dashboard.
If it fits can I have the full code so I can start hunting online.
downtime
Finland
C?ID=280813
Most likely it fits, but different thing is that if it works :D
On the older style clusters Tiguan vs other models differentiated so that Tiguan had 2 fuel level sensors whereas other models have only 1. That caused issues. I don't know if that is one thing that is still the same
Full code is 5NA920790D
