Wednesday,20,January,2021,23:34:53:12015
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 20.12.0.1 (x64)
VIN: WAUF2AFC6DN059099 License Plate: GADAPOO
Mileage: 190094km-118118mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 72 8F 90 A9 BA
VIN: WAUF2AFC6DN059099 Mileage: 190094km-118118miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H61 0009
Revision: NCH61---
Coding: 0A2500326526000E1000
Shop #: 59304 001 1048576
Dataset: EV_ECM40TFS0114G0906014B 001009
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 2149AEC130E7058C2D-8074
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
4007 - Idle Control System RPM
P0507 00 [096] - Higher than Expected.
Part No SW: 4G1 927 156 S HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H06 0014
Revision: --H06---
Shop #: 04742 780 00200
Dataset: EV_TCMDL501021 001025
ROD: EV_TCMDL501021.rod
VCID: 3D7172B1AC5F416C29-8068
20363 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
[New feature! Extended fault detail is only supported by current gen. interfaces]
Fault Frequency: 0
Reset counter: 0
Engine RPM: 0 /min
Transmission input speed: 0 /min
Engine torque: -100 Nm
ATF temperature: -40 °C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
Address 03: Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 65B64F01A66DF2804B00
Shop #: 02391 785 00200
Dataset: EV_ESPPremiAU57X 004028
VCID: 36636D9D89699234E8-8062
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 HW: 4H0 907 064
Component: BCM2 2.0 H32 0421
Coding: 0D882006000000000000
VCID: 7BF5BCA9FACB8F5C57-802E
Component: J764 ELV H40 0046
Serial number: 2312000185265007
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0076
Serial number: 09091200040082
Coding: 688120B849
Dataset: EV_AirCondiComfoUDS 002036
VCID: 62CBE1CD75615E9474-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001436682
Coding: 09072091073C9FE0A90008C7A0003800CF9CD208A20802218001085C7B00
VCID: 6FED98F9BEB3E3FCEB-803A
Component: WWS57X 120807 H36 0080
Serial number: 120818043950
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20548839
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - H07 0044
Serial number: 07 09 2012 00000756
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02F60AE0
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000007081200010014
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000023081200010063
Coding: 110000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103989000001773479
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 5E384646000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE H01 0072
Revision: 11001001 Serial number: 61061225700425
Coding: A8C10A
Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77FDA099CEE3AB3C33-8022
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D8002DW6Y
Coding: 303234373131303030314A55304C34473053
Dataset: EV_AirbaAU10BPAAU64X 001014
VCID: 336554899A1B871CCF-8066
Serial number: 6940000Y120000HSYH0N
Serial number: 3575HRB40651G7FGEH6A
Serial number: 3585HRB405V1G7FGFGPC
Serial number: 3515JRB40691D2ASFOOZ
Serial number: 3525JRB40691D2ASD8D7
Serial number: 3554VRB400E4UIV47991
Serial number: 3564VRB400E4UIV4GGFO
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LI7001IJ
Coding: 000434
VCID: 387F63A58B7D6444FA-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 11 06 2012 D0070551
Part No SW: 4G0 920 981 K HW: 4G0 920 981 K
Component: TBenUsa Nv H76 0515
Revision: 28460207 Serial number: 658160812596027
Coding: 0BEF09059B41D705020200
Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000676423
Coding: 00E1034800
Dataset: EV_GatewPkoUDS 001016
VCID: 71E99E81A087F50CFD-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790140998
U140B 00 [008] - -
Reset counter: 233
Mileage: 190056 km
Date: 2021.01.20
Time: 16:45:03
Voltage terminal 30: 11.0 V
Voltage terminal 15: 11.2 V
Control Module temperature: 19 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 1
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H15 0013
Serial number: 002808120001249
Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 275DB0D95EC3FBBC63-8072
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0076
Serial number: 07091200040558
Coding: 20
Dataset: EV_ClimaContrUnitRearUDS 002018
VCID: 377D60998E636B3CF3-8062
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [009] - Signal Amplitude Too High
Reset counter: 195
Mileage: 178765 km
Date: 2020.04.02
Time: 09:31:27
Voltage terminal 30: 11.65 V
Outside temperature: 16.0 °C
Right Rear Upper Body Vent Motor-Act.val.: 11701
Right Rear Upper Body Vent Motor-Target value: 11701
Right Rear Upper Body Vent Motor-Stop open: 11608
Right Rear Upper Body Vent Motor-Stop closed: 10000
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008000
Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E5345FD7139AAF4A0-807A
367877 - Ride Height Not Learned
C1044 00 [009] - -
Reset counter: 193
Mileage: 190056 km
Date: 2021.01.20
Time: 17:06:06
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000038552092
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77FDA099C6E3AB3C33-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0053
Revision: -------- Serial number: EJ1BPA7E0050U7
Shop #: 00000 000 00000
Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 306F5B85A30DBC04B2-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 Slave H01 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F07.09.1200H01000AMS16524ÿ
Subsystem 4 - Serial number: S16524ÿ
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: FA H03 0506
Coding: 011F17005E00628002000012
VCID: 479D1059F6831BBC83-8012
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0027835350
Coding: 101000010000
Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326B518D65018E14C4-8066
Revision: 00002001 Serial number: 0183164424
Coding: 0106063A00FA408580B00880020503000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000106060
Component: BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1797634B
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00001930199
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000004271
Coding: 030000
VCID: 1C379F351F852864FE-8048
Component: BF H03 0506
Coding: 011F17005E00628002000002
VCID: 46831D5DF18902B478-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: -4 H03 0013
Revision: -------- Serial number: 00000000469933
Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B554CE9422BDFDC87-807E
131584 - Switch for Electric Parking Brake
C100C 07 [008] - Mechanical Failure
Reset counter: 75
Mileage: 185995 km
Date: 2020.10.19
Time: 16:51:58
Voltage terminal 30: 11.8 V
Internal Fault ID: 11
Function light in parking brake button: OFF
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: OFF
: not active
: not active
HTR: active
: not active
requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: No enabling
Status of parking brake button: Open
Status ParkingBrake left: applied
Status ParkingBrake right: applied
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 120910-0002-053
Coding: 12216F601002A400
Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5142F17C3FD1EC99-8078
120589 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Fault Frequency: 32
Reset counter: 193
Mileage: 184793 km
Date: 2020.09.20
Time: 11:53:22
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156I00C7634257
Coding: 020007010000000001
VCID: 2149AEC138E7058C2D-8074
Part No SW: 4G0 035 746 B HW: 4G0 035 746 B
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 194I%0C7512655
Coding: 060200000203F1EF55128B1E00000003100001000000000000
VCID: 2643BDDD51C9E2B458-8072
Subsystem 1 - Part No: 8R0 060 884 AM
Component: 2012 0605
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC9402DXRG
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349LIA0007Q
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
00658 - Control Head
Fault Frequency: 31
Reset counter: 231
Time Indication: 15
Voltage: 11.50 V
02244 - Button in Control Head is Stuck
Fault Frequency: 31
Reset counter: 235
Mileage: 189980 km
Date: 2021.01.19
Time: 15:27:30
Voltage: 11.40 V
Hex Value: 0x0005
not available
03389 - Data Set Implausible
Reset counter: 95
Mileage: 186595 km
Date: 2020.10.29
Time: 14:29:30
Voltage: 11.40 V
Bin. Bits: 010
01524 - Antenna for Telephone
Fault Frequency: 60
Reset counter: 195
Mileage: 179047 km
Date: 2020.04.15
Time: 06:29:03
Voltage: 12.20 V
Component: HL H03 0506
Coding: 010F17004000628002000002
VCID: 49991661E097EDCC95-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J28G1UJ
Coding: 1080004
VCID: 2643BDDD91C9E2B458-8072
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: HR H03 0511
Shop #: 05229 002 1048576
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31695E816007B50CBD-8064
Component: RGS-VR H13 0080
Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 120711200007
Dataset: EV_SoundActuaGen2AU64X 003010
VCID: 2C574FF54725D8E48E-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804000701504
Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 66C3FDDD994922B498-8032
0554 - No Basic Setting
B2010 00 [009] - -
Reset counter: 38
Mileage: 184793 km
Date: 2020.09.20
Time: 11:40:54
1632 - invalid data record
B2005 00 [009] - -
Reset counter: 38
Mileage: 184793 km
Date: 2020.09.20
Time: 11:40:54
End-------------------------(Elapsed Time: 06:16)--------------------------
