2020 Audi A6 Energy Management issue.
net1vet
C?ID=2922
Vehicle had light hit in rear end bumper cover was repaired & RT rear tail lamp was replaced. Can not clear these faults. Tried using address 80 -basic setting reset of reversible crash shut off but security access is needed & not available. Not sure if this is the correct procedure for these faults anyway. Not sure if I should send this vehicle out with these faults. Any thoughts, insights, or suggestions would be greatly appreciated. Thank you
Wednesday,20,January,2021,15:18:06:64419
VCDS Version: 20.12.0.1 (x64)  HEX-NET CB: 0.4529.4
VIN: WAUE8AF28LN060996   License Plate:
Mileage: 6293km-3910mi   Repair Order:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 09 15 16 17 19 22 36 3C 42 44 46 47 52 5F 75 80 81
          A5 BB BC CA CF D6 D7 DE
VIN: WAUE8AF28LN060996   Mileage: 6293km-3910miles
80-Batt. reg. aux. accum. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DLHB)       Labels: None
   Part No SW: 4K0 906 259 A    HW: 06L 907 425 C
   Component: R4 2.0l TFSI  H15 0005
   Revision: --H15---
   Coding: 0A6500122326010E34282000000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0204K0906259A 001007
   ROD: EV_ECM20TFS0204K0906259A.rod
   VCID: AF2E7005F6E66FFC2B-80FA
Readiness: 1010 0101
   Part No SW: 4K0 927 153 G    HW: 0HK 927 156 B
   Component: 0CJ 20TFSINAR H01 0003
   Revision: --H01---    Serial number: 0000000075
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: B12A767DE0D2790C3D-80E4
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041200007001253
   Part No SW: 4K0 907 379 AA    HW: 4K0 907 379 F
   Component: ESP9 Plus     H06 0857
   Coding: 18AA41972CA80B9611A7489A228352D2F53988188234D08812444A4BAF9C11
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: F4A4BF695F400C2496-80A0
   Part No SW: 4N0 907 063 KE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0691
   Coding: 07000363C0291CCD070487081CEF9C2A130B37110406009701010A0019331C01086909024010000000000100000300180002000004010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: FBB69455721E435CD7-80AE
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001911180400448
   Coding: 7DC727
   Serial number: 24134021X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S05.12.1900690670
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00JB02
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE128101923311170
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AH    HW: 4K0 947 135 AH
   Component: Dachmodul  H42 0416
   Serial number: C00433809
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA140176000077815580
   Coding: 0A0700
405507 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [Function limitation due to energy management system]
                    Reset counter: 77
                    Mileage: 6293 km
                    Date: 2021.01.20
                    Time: 15:12:25
                    average_Voltage_terminals: 11.40 V
                    Outside air temperature sensor-Outside air temperature on CAN: 16.00 °C
                    interior_temperature: 15.00 °C
                    Vehicle speed: 0.00 km/h
   Part No SW: 4N0 959 655 K    HW: 4N0 959 655 K
   Component: AirbagVW31    H12 2720
   Serial number: 003YUM00ZKKZ
   Coding: BFCCF0C000C00000A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: C4C42FA94F60FCA4E6-8090
   Left seat belt tensioner:
   Serial number: 00AI2019343608600000
   Coding: 04F001
   Right seat belt tensioner:
   Serial number: 00AI2020004420600000
   Coding: 04F001
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000CNJ1G0B
   Coding: 303134
   Subsystem 4 - Part No SW: -----------    HW: 480 001 701 20
   Serial number: 35700000000FBB25E44
   Subsystem 5 - Part No SW: -----------    HW: 480 001 801 20
   Serial number: 35800000000FB4A4C44.
   Subsystem 6 - Part No SW: -----------    HW: 480 031 501 20
   Serial number: 351002C046FC86006936
   Subsystem 7 - Part No SW: -----------    HW: 480 031 501 20
   Serial number: 352002C046FB4D615DAQ
   Subsystem 8 - Part No SW: -----------    HW: 480 031 401 20
   Serial number: 355002C0471A49C14C5A
   Subsystem 9 - Part No SW: -----------    HW: 480 031 401 20
   Serial number: 356002C00F6AEDF0DD1%
   Part No SW: 4N0 907 129 M    HW: 4N0 907 129 M
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: BB365455329E835C97-80EE
   Part No SW: 4K0 920 890 B    HW: 4K0 920 890 B
   Component: FBenUSAACC--- H12 0210
   Coding: 8BE620C3E888D7050203E16098800B0008002000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: AD126A0DFCEA1DEC19-80F8
   Part No SW: 4K0 907 468 Q    HW: 4K0 907 468 C
   Component: Gateway       H06 0272
   Serial number: 1AF02118235501
   Coding: 020100050020064029870000005B0132CC38000710000000097D078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: C2C829B15574F294D4-8096
   Subsystem 1 - Part No SW: 4K0 951 523 J    HW: 4K0 951 523 J
   Component: E221__MFL  H06 0010
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 741863130020010301D1
8519683 - Energy Management Active
          U140B 00 [008] - -
                    Reset counter: 77
                    Mileage: 6293 km
                    Date: 2021.01.20
                    Time: 15:12:37
                    EM_vehicle_state: 22 1C
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 22: AWD (J492)       Labels:* None
   Part No SW: 4K0 927 755 A    HW: 0CJ 927 749 A
   Component: C8_DL3_N_SD1  H02 0007
   Serial number: 19310B6878
   Coding: 110C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: B3267C751ACE4B1C4F-80E6
   Serial number: 00000400708363
   Coding: 005C1A400000B4010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_AU38.rod
   VCID: F9BA8E5D7822714CC5-80AC
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: YE007SLD0321A
   Coding: 001FCB0052001480A001A032
   VCID: C6C035A1795CCEB4F8-8092
   Coding: 94002101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: B2287971E5D4421444-80E6
   Part No SW: 4N0 907 064 DD    HW: 4N0 907 064 D
   Component: BCM2 MLBevo H15 0202
   Coding: 013400004FB000C0650FA0006C01000203034000810026502F0400000B04823F001E0101000011
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_VW53.rod
   ID - sensor:
   Serial number: 000000000ZY193400WFM
   Serial number: 00000000000048021390
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14327427
   Rear spoiler control module:
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D03BLC0
   Coding: 0185010000AAAA2FAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: A4048F29AF20DCA4C6-80F0
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: YE007SKJ24233
   Coding: 001FCB005E001480A001A030
   VCID: C5C232AD445AC5ACF1-8090
   Part No SW: 4K0 035 084 D    HW: 4K0 035 084 A
   Component: MU-H-LNS-US   056 2711
   Coding: 0185010200000000C1220002061C00302F0001E403F00804CE
   VCID: A71E9825DE1637BCE3-80F2
   Subsystem 1 - Part No: V03 959 804 CD
   Component: MIB2P_NA_Q119  0366
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4K1 919 605 H    HW: 4K1 919 605 F
   Component: DU AU58x Top  H71 0171
   Serial number: BHB00120012003200637
   Compact disc data bank:
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000141593053
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4K1 919 603     HW: 4K1 919 603
   Component: DU AU58x Bot  H42 0137
   Serial number: BHB00129101903200522
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900775731007
          B201A 00 [009] - -
                    Reset counter: 37
                    Mileage: 6293 km
                    Date: 2021.01.20
                    Time: 15:13:03
                    Voltage terminal 30: 11.5 V
                    Status_Software_Version_Management-module_name: DUB2L58x.HSW.app
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F121120
   Coding: 01C020FE4040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: A81C9B19D30838C4EA-80FC
458759 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Reset counter: 77
                    Mileage: 6293 km
                    Date: 2021.01.20
                    Time: 15:13:38
Address 80: Batt. reg. aux. accum. (A1)       Labels: None
   Part No SW: 4K0 915 101     HW: 4K0 915 101
   Component: MQ-BMS        H20 0127
   Serial number: 19000172002002
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: E08CC339FBB88084E2-80B4
   Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 20.009 40314
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Coding: 02018600000000000033D60000F00504139D560000000000000000000096D401019BA80000000000000000800000000000000000000000000000800000000000000078180080009000000000000000000080400000F0
   ASAM Dataset: EV_ZFASAU516 001007
   ROD: EV_ZFASAU516_001.rod
   VCID: 8F6ED08556A64FFC0B-80DA
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0425
   Serial number: YE007SKD02863
   Coding: 000FCB0000001480E000A020
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
   VCID: C8DC3B997348D8C40A-809C
   Component: TSG HBFS004 0425
   Serial number: YE007SL809679
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
   Coding: 268040058101
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: F5A2826D543A152CA1-80A0
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H06 0031
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: F2A8B9712554021484-80A6
Address D7: Light Ctrl Right 2 (A27)       Labels: None
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
   VCID: A00C8339BB38C084A2-80F4
End----------(Elapsed Time: 01:55, VBatt start/end: 15.0V/15.0V)-----------
Those look like nuisance faults to me.
Did you have the hood up when you tried to clear them?
FandaTDI
Czech Republic
C?ID=204559
There are many clues... For example - what is internal resistance of battery? Any units replaced or ... ?
I would check battery history, SOC, etc. about the battery mgmt...
net1vet
C?ID=2922
I don't believe any doors or hood were open. The faults would clear but come back as key was cycled. I was thinking maybe just low battery voltage caused these faults. I appreciate the replies. Thank you
net1vet
C?ID=2922
I will ,should post results tomorrow
net1vet
C?ID=2922
I attempted what UWE suggested clearing faults with hood open. Low & behold the faults cleared.
Little bit of explanation would be great
Thank You
Dan
Thursday,21,January,2021,08:15:24:64419
   Revision: --H15---
Readiness: 1110 0101
   MTF pump:
   Coding: 250000
   Coding: 04F001
   Coding: 04F001
   Coding: 303134
   Coding: 110C0000
   Coding: 0FDC00
   ID - sensor:
   Volume Control 1:
   Media socket:
          B201A 00 [009] - -
                    Reset counter: 37
                    Mileage: 6293 km
                    Date: 2021.01.21
                    Time: 08:11:42
                    Voltage terminal 30: 12.2 V
   Coding: 0FDC00
   Coding: 800000
End----------(Elapsed Time: 01:51, VBatt start/end: 15.2V/15.2V)-----------
Bruce
Near Philadelphia, PA, USA
In the newer vehicles, the hood latch switch acts as a security device so others cannot hack your car while it is in motion. The assumption by VAG is that in order to drive, the hood latch must be closed. So, my guess, and it seems spot on, Uwe suspected this was blocking the control modules ability to make and record changes.
net1vet
C?ID=2922
Great information
Any thoughts on if I tried to clear faults with ODIS or do you think results would be the same?
FandaTDI
Czech Republic
C?ID=204559
Will be the same result. What about the SVM? Was display unit changed? Wondering if XOR method in installation change channel will still work here...
net1vet
C?ID=2922
I don't know about SVM I thought that was strange for this new of a car. This I think would be taken care of through warranty by dealer if need be.
Yes, you would also have to do so with the hood open.
net1vet
C?ID=2922
Bruce reported
Thank You All
Dan
