I recently attempted to have a dealer install a GLI cluster on my car [MK6 Jetta S Facelift]. Most of the cluster works, it shows what doors (trunk and hood as well) are open, what the current fuel level is, and what the coolant temp is. Some things that don't work on the cluster are: Turn signals don't show up on it (works outside), the cluster doesn't know if the lights are on so it blacks out the cluster at night, and the high beam indicator doesn't work either. It also comes up with an ESC fault message on startup.
Was this just not installed correctly, or was my car never able to run this cluster in the first place? (I'm assuming it may be the latter but I just want to confirm.)
Thanks in advance.
Thanks in advance.
Tuesday,19,January,2021,18:26:17:06520
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: 3VW167AJ2HM295417 License Plate:
Mileage: 52620km-32696mi Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 44 5F
VIN: 3VW167AJ2HM295417 Mileage: 52620km-32696miles
25-Immobilizer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CZTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AK HW: 04E 907 309 AP
Component: R4 1.4l TFS H22 3670
Revision: X5H22---
Coding: 01110012232400000000
ASAM Dataset: EV_ECM14TFS01104E906023AK 005003
ROD: EV_ECM14TFS01104E906023AK_005.rod
VCID: 698FB67E29F875C3C4C-803C
Readiness: 0000 0100
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A14B400C492B00FF850F02E59220004024100012
Shop #: WSC 12345 123 61029
VCID: 75B7EA0E75C0A123504-8020
03391 - Coding Not Possible
Reset counter: 25
Mileage: 52611 km
Count: 2
Count: 12800
Count: 8254
Count: 49664
Count: 62720
Count: 254
Reset counter: 25
Mileage: 52611 km
Count: 2
Count: 12800
Count: 8211
Count: 49664
Count: 62720
Count: 254
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CT HW: 5C0 820 047 CT
Component: J301 Klimaanlage 0211
Revision: 2001401S Serial number: 00000003672202
Shop #: WSC 00066 790 00184
VCID: 74B1D70A72BAB82B67A-8020
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 189 A HW: 7E0 937 189
Component: BCM PQ25 MMI3 H81 0744
Revision: BA081001 Serial number: 91007328166032
Coding: 7B994B3808AB0F00003926803CDA94D54BC6722E600151F0B00010032844
VCID: 323D1112C42EF61BB56-8066
Subsystem 1 - Part No SW: 6R0 959 801 DF HW: 6R0 959 801 DF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 022 1467
Serial number: 14202743161101224115
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 DJ HW: 6R0 959 802 DJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 022 1467
Serial number: 14202742161101094131
Coding: 820000
Subsystem 3 - Part No SW: 6C0 959 442 G HW: 6C0 959 442 G
Serial number: 2941612142301271BE2B
Coding: 280000
Subsystem 4 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1467
Serial number: 14102745161104142033
Subsystem 5 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1467
Serial number: 14102744161031174326
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 008 0210
Serial number: 003RXM09K2ZM
Coding: 8CCCF000000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 6393A456CBD42F930E0-8036
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000062Y608
Coding: 303141
Subsystem 2 - Part No SW: ----------- HW: 480 002 009 16
Serial number: 35700000000D96107E1N
Subsystem 3 - Part No SW: ----------- HW: 480 002 009 16
Serial number: 358000000009E12D5E1W
Subsystem 4 - Part No SW: ----------- HW: 480 022 010 16
Component: SideSensor_Dr 000 0148
Serial number: 35100019B23204C285C.
Subsystem 5 - Part No SW: ----------- HW: 480 022 010 16
Component: SideSensor_Pr 000 0148
Serial number: 35200019B23204C4759-
Subsystem 6 - Part No SW: ----------- HW: 480 021 910 16
Component: FrontSensor_D 000 0189
Serial number: 35500019922AFFC6462K
Subsystem 7 - Part No SW: ----------- HW: 480 021 910 16
Component: FrontSensor_P 000 0189
Serial number: 35600019B22AFFC4D6D+
12674816 - Immobilizer Control Module
U0167 00 [009] - No Communications
[Lost Comminication with Immobilizer]
Reset counter: 25
Mileage: 52580 km
Date: 2021.01.15
Time: 00:51:39
Part No SW: 5C6 920 986 CX HW: 5C6 920 986 CX
Component: KOMBI H02 1109
Coding: 020A090000
VCID: 0B43ACF603C4C7D3160-805E
12666368 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Diagnose Interface: keine Kommunikation]
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 189
Component: GW-K-CAN TP20 H81 0744
Revision: BA081001
Coding: 102201
VCID: 6889B37A32724CCBDB2-803C
Reset counter: 25
Mileage: 52580 km
Date: 2021.01.15
Time: 00:51:40
Component: IMMO H02 1109
VCID: 6A8DC9722CFE7EDBCD6-803E
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 304 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F263E1558054374C-806C
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 561 035 150 A HW: 561 035 150 A
Component: MU-E--US 055 7085
Serial number: 03101600010056
Coding: 02630100AA00000041220001001000009F0000D40000010000
ROD: EV_MUEnt4CGen2LGE_VW32.rod
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6100)]
Reset counter: 25
Mileage: 52603 km
Date: 2021.01.15
Time: 14:19:57
Voltage terminal 30: 14.1 V
6714 - Databus
[VIN: no communication]
Reset counter: 25
Mileage: 52580 km
Date: 2021.01.15
Time: 00:51:36
Voltage terminal 30: 12.3 V
Network diagnosis-Status: Not available
End----------(Elapsed Time: 01:05, VBatt start/end: 12.2V/12.2V)-----------
