2015 Seat Leon DPF fault
United Vehicles
C?ID=69882
Hi, I wondered if anyone could offer any advice to help resolve the problem on this car. It has the engine light on and coil light flashing. The fault codes are as per the auto scan I have attached. I cannot activate a dynamic regen because when I select the security section and hover over the box to enable adaption it says this function is blocked or not allowed.
Could anyone offer any advice to overcome this problem please
Wednesday,20,January,2021,16:11:29:18746
VCDS Version: 20.12.0.0
Data version: 20201124 DS322.0
VIN: VSSZZZ5FZGR020765   License Plate: KN65FWW
Mileage: 90214km-56056mi   Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZGR020765   Mileage: 90214km-56056miles
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CR    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2181
   Revision: 22004001
   Coding: 01254012432519090000
   Shop #: WSC 00049 770 00123
   ASAM Dataset: EV_ECM16TDI03004L906056CR 002004
   ROD: EV_ECM16TDI03004L906056CR_002_AU37.rod
   VCID: 7F06D2A5E6B4467C7A-802A
23902 - Diesel Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 90214 km
                    Date: 2021.01.19
                    Time: 07:08:01
                    Engine RPM: 0.00 /min
                    Coolant temperature: 62 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 12.671 V
                    Counter for regeneration time of particulate filter: 10801 s
                    Particle filter: kilometers since last regeneration: 1318.4
                    Particle filter: soot mass measured: 6.88 g
                    Particle filter: soot mass calculated: 60.00 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -7.5 mbar
                    Particle filter: field regeneration lock status: 0
23967 - Diesel Particulate Filter
          P2458 00 [175] - Regeneration Duration
                    Mileage: 90214 km
                    Date: 2021.01.19
                    Time: 07:08:01
Readiness: N/A
   Part No SW: 0CW 300 048 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0611
   Revision: 00005005    Serial number: CU501506107198
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW37.rod
   VCID: 438E9E55CADCE29C5E-8016
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 61555000000709
   Coding: 19EE8A922422096C007E060641C8249851249000608224F200410070C002
   VCID: 4B9EB675E28C2ADCA6-801E
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 124
                    Date: 2021.01.19
                    Time: 00:12:18
16412 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 124
                    Mileage: 90214 km
                    Date: 2021.01.19
                    Time: 00:12:30
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 124
                    Mileage: 90214 km
                    Date: 2021.01.19
                    Time: 00:12:30
   Part No SW: 5F0 907 426 M    HW: 5F0 907 426 M
   Component: AC Manuell    H02 1001
   Revision: 00001K09
   Coding: 02100104200100001000000000001000
   Shop #: WSC 00049 770 00102
   ASAM Dataset: EV_ACManueBHBVW37X 003017
   VCID: 346CCD899F725524D7-8060
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061516207586
   Coding: 0B001A424241005B03A04000B10403081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 09124C7DA87078CC54-805C
   Subsystem 1 - Part No SW: 5F2 955 119 A    HW: 5F2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150505  041 0574
   Serial number:         150519061402
   Coding: 0BC5FD
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150893HV5
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000032717936
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 84
                    Mileage: 90214 km
                    Date: 2021.01.19
                    Time: 00:25:54
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPC2X9AJ
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F266265D61456FC8A-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 206 15
   Serial number: 3576U00000054825C416
   Subsystem 2 - Part No SW: -----------    HW: 454 000 206 15
   Serial number: 3586U0000009875CA41M
   Subsystem 3 - Part No SW: -----------    HW: 454 801 006 15
   Serial number: 3516RC2982D070000009
   Subsystem 4 - Part No SW: -----------    HW: 454 801 006 15
   Serial number: 3526R458D2D070000009
   Subsystem 5 - Part No SW: -----------    HW: 454 802 705 15
   Serial number: 3556VB0D8E006000000G
   Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 15061504220998
   Coding: 1410
   ROD: EV_SMLSKLOMQB_018_SK37.rod
   VCID: 0A107371AD7673D45D-805E
   Part No SW: 5F0 920 973 A    HW: 5F0 920 973 A
   Component: KOMBI         303 6420
   Coding: 27A412082980260001086A001000000000000000
   VCID: 2A50D3F14DB613D47D-807E
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003629968
   Coding: 030100F40F087300EA000040140F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75EA308DD4880C2C20-8020
   Generator:
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000B0529180515
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001505234977
   Component: TSG FS        010 0031
   Serial number: 0000153756177
   Coding: 00100220C001040000001000
   VCID: 47968A45FEE4CEBC82-8012
   Serial number: 00000000000006331980
   Coding: 2D0000
                    Reset counter: 84
                    Mileage: 90214 km
                    Date: 2021.01.19
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 0103
   Component: TSG BFS       010 0031
   Serial number: 0000153644166
   VCID: 46888741F9EED7B479-8012
   Serial number: 00000000000006314728
   Coding: 350000
   Coding: 038C000009000000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 858     HW: 5QA 035 858
   Component: MU-S-ND-ER    H24 0241
   Serial number: SEZAZ2R0235354
   Coding: 04730301D70A000011111101008808002F0200860120010046
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SK25.rod
   VCID: 040C5D498F5225A427-8050
   Subsystem 1 - Part No SW: 5F0 919 604 A    HW: 5F0 919 604 A
   Component: ABTm_Std2_Nav  H43 1028
   Serial number: SEZ8Z9RFT003FZ
   Subsystem 2 - Part No SW: 6P0 919 866     HW: -----------
   Component: ECE 2015/16  --- 0430
End-------------------------(Elapsed Time: 04:19)--------------------------
DrPeter
16.4905° S, 151.7375° W
Have you tried the Basic Settings [Service regeneration of particle filter] or the Basic Settings [Service regeneration of particulate filter while driving]??
If these do not work, there maybe a software update for this Engine Controller. [04L 906 056 CR]
- Your software level is at (2181), there appears to be a newer version of (5813).
ref: http://wiki.ross-tech.com/wiki/inde...n#1.6l.2F2.0l_R4_.26_3.0l_V6_CR-TDI_.28UDS.29
Hope this helps,
drpeter
United Vehicles
C?ID=69882
Hi, Just to tidy this up and thank everyone who contributed. None of the basic settings worked either with the engine running or not. The vehicle was referred to the dealer for a software update which rectified the defect
