DRL Fault
Trilux
United Kingdom
C?ID=385513
Hi,
Can you help please. I have a DRL problem with my Skoda Yeti 2016 L&K 2.0tdi 150hp 4x4.
The lights Mil is illuminated and the BCM is showing faults as in the scan. Sometimes it will show the fault with just the DRLs and sometimes the same fault with rear lights and or brake lights as well.
The rear and brake lights are working as they should. The DRLs work as sidelights and come on with the headlights when switched manually. When switched to AUTO, the Xenons work as they should with daylights sensing on/off, however, no lights are on at the front in good daylight. The DRLs do not come on in the OFF position with the ignition on.
The original problem I had with the car was that in good daylight, both the DRLs and Xenons would be on when switched to AUTO. Everything else, including DRLs were working fine with no DTCs shown. It could well be that that I altered something but I have put all the codes and adaptions back as per the original fault free scans.
If I clear the DTCs, the next scan comes up free of faults until I switch the lights on, in any combination and then the error code returns. If I code the DRLs off, the DTC and Mil disappear but then, I lose the LED sidelights too.
This is driving me bonkers as I have spent days on it. Hope you can help.
Wednesday,20,January,2021,16:22:23:33401
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: TMBMD75LXG6028445   License Plate:
Mileage: 46740km-29042mi   Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 4F 52 55 5F 61 62
          69 72
VIN: TMBMD75LXG6028445   Mileage: 46740km-29042miles
Address 01: Engine (J623-CUUB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 J    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1186
   Revision: 8AH20---
   Coding: 01190032042701090000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906016J 001003
   ROD: EV_ECM20TDI01104L906016F_001.rod
   VCID: 303917A91AAB741BC32-8064
   Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
   Component: ESP MK60EC1   H46 0174
   Revision: 00H46001
   Coding: 933F400E09240102C90F02E8901E809AA1015021
   VCID: 74B1DBB9AEB3083B67A-8020
   Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
   Component: Climatronic   H19 0709
   Revision: 00001009
   Coding: 0010000003
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CA1F3998663407B2FA-8028
   Part No SW: 1K0 937 087 AR    HW: 1K0 937 087 AR
   Component: BCM PQ35  H   112 0903
   Revision: AC112903
   Coding: 4E000ABFE01BF1C0440800C0110089E44B7000AE626D87608081C7240041
   VCID: 015F826DE1012D937CC-8054
   Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
   Component: SK356  26  0610
   Coding: 00F7B5
   Component: RLS 080915 05  54  0403
   Coding: 063021
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 165
                    Mileage: 46743 km
                    Date: 2021.01.20
                    Time: 15:54:53
                    Voltage: 12.55 V
                        Term 50 On
                    Reset counter: 165
                    Mileage: 46743 km
                    Date: 2021.01.20
                    Time: 15:54:53
                    Voltage: 12.55 V
                        Term 50 On
                    Reset counter: 165
                    Mileage: 46743 km
                    Date: 2021.01.20
                    Time: 15:56:18
                    Voltage: 12.00 V
                        Term 50 On
                    Reset counter: 165
                    Mileage: 46743 km
                    Date: 2021.01.20
                    Time: 15:56:20
                    Voltage: 12.30 V
                        Term 50 On
Address 10: Park/Steer Assist (J791)       Labels:| 3T0-919-475-V2.clb
   Part No SW: 3T0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0013
   Revision: --------    Serial number: 56261524000228
   Coding: 159207
   ASAM Dataset: EV_EPHVA2CAS46X0000 003001
   ROD: EV_EPHVA2CAS46X0000_002_SK46.rod
   VCID: 41DF426DA101ED933CC-8014
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    014 0613
   Serial number: 003G5RAV25KX
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 313F12AD11A17D13CCC-8064
   Serial number: 3572MSME536F0B54ZZZ%
   Serial number: 3582MSME7B730B54ZZZ%
   Serial number: 3516KSME0B5A4839ZZZ$
   Serial number: 3526KSME1E6E0739ZZZ1
   Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150904200265
   Coding: 1082140000
   Shop #: WSC 73430 790 00063
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EA5F991907F526B01E-802A
   Subsystem 1 - Part No SW: 5E0 919 719 L    HW: 5E0 919 719 L
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000C0819140815
   Coding: 820000
   Part No SW: 5L0 920 940 T    HW: 5L0 920 940 T
   Component: KOMBI         H03 1007
   Coding: 420E010100
   ROD: EV_Kombi_UDS_VDD_RM09_005_SK35.rod
   VCID: 3D273E9DDDF98973584-8068
   Part No SW: 7N0 907 530 BF    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1673
   Revision:   H55       Serial number: 310815F1001282
   Coding: 356333
   Shop #: WSC 45340 001 104857
   VCID: 75B7E6BDA5C91133504-8020
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7531
   Serial number: HA1-00017.06.15
   Coding: 0301
   VCID: 52FD7D217467660B956-8006
   Component: IMMO          H03 1007
   VCID: 6A8DC5C1FCF7CECBCD6-803E
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H04 0561
   Revision:             Serial number: 0000165595552
   Coding: 01150220D001231004
   VCID: 49CF5A4D99B125D3E4C-801C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 71     3501
   Revision: 00H22000
   VCID: 392F2A8DC551B55374C-806C
   Component: EZE_2         H55 1673
   Coding: 050B0500
   VCID: 6FBBD4D5C7952BE39A8-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H04 0561
   Revision:             Serial number: 0000165607515
   Coding: 01150020D001231004
   VCID: 48C95F4982BBDCDBFB2-801C
   Component: AFS-ECU       H05 0111
   Coding: 03DE00003F000000
   VCID: 372B2CB5FFC5A323828-8062
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Part No SW: 5L0 035 680 C    HW: 5L0 035 680 C
   Component: MU-S-ND-ER    H22 0245
   Serial number: SKZAZ2R8841581
   Coding: 03130601FF00000011111201008900002F0000C60120810046
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 2A0D05C13C770ECB0D6-807E
   Subsystem 1 - Part No SW: 5L0 051 236 BR    HW: -----------
   Component: ECE AS 20/21  --- 1410
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1673
   Coding: 030F1873
   VCID: 71BFD2ADD1A13D138CC-8024
   Component: J367-BDM  H07 0180
   Serial number: 32243G30361491603587
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
   Component: TSG HL        H04 0561
   Revision:             Serial number: 0000165956479
   Coding: 010000200001531004
   VCID: 47CB5C758FA5D3A3F28-8012
   Component: Towbar module H09 0100
   Revision: 3A001001    Serial number: ÀÁ006789323536
   Coding: 0100000100000000
   VCID: 303917A91A2B741BC32-8064
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
   Component: TSG HR        H04 0561
   Revision:             Serial number: 0000165956472
End----------(Elapsed Time: 01:33, VBatt start/end: 12.4V/12.4V)-----------
Jef
HQ
A quick look at this, nothing stands out as a single point of failure beyond the J519 itself..... :confused: I'm not saying you have a J519 at this time.
Verify fuses for J519 are to factory design, and that they the sockets for those fuses have a good bite on the legs of said fuses. On the J519, unplug and verify good clean electrical contacts. The bulbs in question are on T52a and T52c of the J519.
@Trilux: Hi. I'm not familiar with MY16 Yeti (I've never really understood PQ35 platform cars) and certainly try @Jef suggestion first. However, in reading your post, I note that the DRLs are operational in some modes and (if I understand your post above correctly) I also note that there has been some coding intervention in the past directly related to the DRLs.
Now, while I acknowledge your belief that the changes have been reverted to their original settings, and without intending any offense in my suggestion - perhaps there may be value in confirming your belief. Again without meaning to be rude, it just may be possible that the cause for the fault could be a missed channel setting, or a wrongly chosen value - I'm just hypothesizing.
You may not be aware that VCDS keeps a record of ALL the changes that you make including the old and new values. So, if @Jef suggested checks proves OK -on the laptop that you use to run VCDS, go to the the directory C:\Ross-Tech\VCDS\Debug and open the files AdpLog.CSV and CodingLog.CSV with a reader like MS Notepad, or MS Excel. Confirm that each of the DRL related changes have indeed been correctly reverted to their original values.
Trilux
United Kingdom
C?ID=385513
Hi Don, thanks for your message. I‘m always appreciative for any suggestions and would in no way be offended.
I have now done as Jef suggested and sadly that has made no difference. As I mentioned in my post, I did reset all the codes and adaptions to the original but should have mentioned that this was done with reference to the AdpLog and CodingLog files. I should also have mentioned that the car is completely standard and unmodified.
Jim
