Hi, I have a 2008 Audi tt Roadster convertible. I have the below codes and any help in fixing these would be appreciated.
I had the same codes about 6 months ago when by battery was dead. I replaced the battery. Should I do anything like a reset or any adaption after replacing the battery, as most seem to be low voltage related errors? Apart from the error codes, Car is working perfectly except the convertible roof not operating.
Here is some info regarding my roof:
From the error codes, I see there is some issue with the hydraulic pump. I also had servo motor fault codes before. I recently cleaned the servo motors based on instructions from TT UK forum and ran the adaption. Now the servo motor fault codes are no longer there but the hydraulic pump code appeared. When I try to open the roof by pulling the switch I get the motor sound but nothing happens. Even If I manually open the roof and then when I try to close the roof with the switch, the flaps open and I get the motor sound but the roof does not close.
Below are all the fault codes .
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AJ HW: 8J0 820 043 AJ
Component: J255 Klima 1 Zone 0080
Revision: 00H07003 Serial number: 00000001050044
Coding: 1573156
Shop #: WSC 01236 785 00200
VCID: 6E85CAEC4C9CCD5B91E-803A
Reset counter: 182
Mileage: 207258 km
Date: 2020.08.10
Time: 00:09:32
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 K HW: 8E0 035 593 K
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0098910
Coding: 0000100
VCID: 313F11909D2292A3CCC-8064
Reset counter: 146
Mileage: 207297 km
Date: 2021.01.03
Time: 22:14:53
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 B
Component: 256 VSG TT H14 0110
VCID: 3E253AAC5C7C7DDB41E-806A
01983 - Hydraulic Pump Relay 2 for Convertible Top (J588)
Reset counter: 3
Mileage: 207444 km
Date: 2021.01.13
Time: 02:44:13
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8J7 959 801 C
Component: Tuer-SG H02 0060
Coding: 0001077
VCID: 3C2130A44A606FCB6FA-8068
00913 - Window Regulator Switch; Front Right Driver (E81)
End----------(Elapsed Time: 01:16, VBatt start/end: 13.6V/13.5V)-----------
