After fitting an instrument cluster not coded to my car, the ABS module lost it's long coding i was given superb help from those here on the Ross-Tech forum, special thanks to Uwe and iichel. thanks guys
Here is the CLEAR full scan after fix, hope it helps someone.
Tuesday,19,January,2021,14:01:47:51226
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: VSSZZZ6JZBR010255 License Plate: DG60OKN
Mileage: 179850km-111753mi Repair Order: 0004
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZBR010255 Mileage: 179850km-111753miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BF HW: 03L 906 023 S
Component: R4 1.6l TDI H13 9979
Revision: --H13--- Serial number:
Coding: 00114016002500080000
ASAM Dataset: EV_ECM16TDI02103L906023BF 003015
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 6B83C200A30971F3B60-803E
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AB HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 100200DB006E00B2082700E700D600000000
Shop #: WSC 04941 123 12345
VCID: 7EA5FB54C0BBF45B01E-802A
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000547492-
VCID: 6393AA20475939B30E0-8036
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 150101417
Coding: 24882BE888612500923000007E0B1CC80080400F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 40D945ACFA8F42AB332-8014
Subsystem 1 - Part No SW: 6R0 959 802 N HW: 6R0 959 802 N Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 3110
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 Q HW: 6R0 959 801 Q Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 3110
Coding: 020000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H11 9004
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3110
Subsystem 7 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3110
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA0D H09 0018
Revision: -------- Serial number: 003DW00FYK3Y
Coding: 003044
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 42DD4FA4F40350BB256-8016
Serial number: 3496GRB401PAGVMR0C3C
Serial number: 3506GRB401PAGVMR23SM
Part No SW: 6J0 920 902 H HW: 6J0 920 902 H
Component: KOMBI H05 0404
Coding: 410A00
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2E050B14509BC4DBD1E-807A
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 022300
VCID: 70B9D56C8AAF922B832-8024
Component: IMMO H05 0404
VCID: 6A8DC704ACF368FBCD6-803E
Address 44: Steering Assist Labels: None
VCID: 55F784F81C4DD703704-8000
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70B9D56C86AF922B832-8024
Address 56: Radio (J503) Labels: None
Part No SW: 6J2 035 153 C HW: 6J2 035 153 C
Component: Radio H05 0107
Revision: R0000000 Serial number: SEZAZ2K9504061
Coding: 0503040002
Shop #: WSC 04941 000 00000
VCID: 2615F33478EB8C9B29E-8072
End----------(Elapsed Time: 01:39, VBatt start/end: 12.2V/12.1V)-----------
