Change over from HBA to DLA
Dick.T
C?ID=350787
Hi,
Had an accident, both front lights damaged, on short notice I could obtain two COMPLETE units 5G1 941 033 and 034 wit ALL original modules on it.
Changed some coding in 09 central electronics ( Byte 02, le hex0B = 0000 1011 in hex0E = 0000 1110 and byte 06 bit 5-6 00 xenon-shutter (PR-8ID / 8IT) NOT installed). Found this info here.
When I start up the calibration of the lights goes well. Operating the High beam stalk does not produce an error message, however the high beam is also NOT coming up.
Also above 40kph error message AFS fault is displayed in the MFA.
When I operate in module 55, Actuator diagnose - 03, I can command the lenses up (High beam) and also horizontally.
What am I missing?
Auto scan and ad map in following two posts
Dick.T
C?ID=350787
Saturday,16,January,2021,16:22:37:54550
VCDS Version: 20.12.0.0
Data version: 20201124 DS322.0
Dealer/Shop Name: MyOwnWorkshop
Workshop Code: 052 82536 013366
VIN: WVWZZZAUZDW146901   License Plate: 2-KJK-16
Mileage: 257868km-160231mi   Repair Order: 20210116
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 13 15 16 17 19 2B 42 44 52 55 5F 65 69 A5
VIN: WVWZZZAUZDW146901   Mileage: 257868km-160231miles
65-Tire Pressure -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 01190012045405083000
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_002_VW37.rod
   VCID: 79F3CD98F80C444C44-802C
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 01FA62A120240A720380060001C42980460450C0608094F3F4685024C0
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7DFBD988EC24786C68-8028
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0211838523
   Coding: 030C0C
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020104202100011105004000101000
   Shop #: WSC 13366 006 82536
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 366906A489926B34E9-8062
327941 - Motor for Left Temperature Flap
          B108C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 149
                    Mileage: 255738 km
                    Date: 2020.11.29
                    Time: 20:20:42
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0132
   Serial number: 01011320000113
   Coding: 00070F46C24102FB4BE44080B11C07081802000000000000000000000000
   Shop #: WSC 82536 052 13366
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0005A07C9BD6158403-8054
   Component: WWS    130409  042 0551
   Serial number:         130412185811
   Coding: 0F4DF5
   Component: RLFS  024 0042
   Serial number: Y13M04D10H14M17S23S1
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1306406DM
   Serial number: 00000000000056282587
7690 - Reflector Actuator for Left Low Beam Headlamp
          B121B 15 [009] - Open or Short to Plus
                    Reset counter: 180
                    Mileage: 257837 km
                    Date: 2021.01.15
                    Time: 17:52:49
7946 - Reflector Actuator for Right Low Beam Headlamp
          B121C 15 [009] - Open or Short to Plus
                    Reset counter: 180
                    Mileage: 257837 km
                    Date: 2021.01.15
                    Time: 17:52:49
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 181
                    Mileage: 257773 km
                    Date: 2021.01.12
                    Time: 12:20:06
463104 - Seat Heating; Front Left
          B1398 F0 [008] - Safety Shut-Off Active
                    Reset counter: 221
                    Mileage: 257856 km
                    Date: 2021.01.15
                    Time: 21:11:11
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 08041303030914
   Coding: 00000D00FE0309
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3F876380A6A8AA7C3A-806A
1107 - ROD - Unknown Error Code
          - 00 [040]
                    Fault Priority: 9
                    Reset counter: 221
                    Mileage: 257628 km
                    Date: 2021.01.07
                    Time: 23:05:28
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 14.7 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R02EXZ8
   Coding: 98FCC0C0000000005C5400CF004800000065
   VCID: 4A914254ED6A1FD49D-801E
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667A15041370013
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668A12041340737
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 304 13
   Serial number: 3576700000088CE8CC0G
   Subsystem 4 - Part No SW: -----------    HW: 480 000 504 13
   Serial number: 358670000008B458CC03
   Subsystem 5 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3516502AF0FBDE32B1A+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3526502AD0FBDE31720Q
   Subsystem 7 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 3556502C30FEA21260CH
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 27031308491370
   Coding: 0C00
   Shop #: WSC 40195 333 37120
   VCID: 0201AA7495DA079415-8056
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G0 920 870 A    HW: 5G0 920 870 A
   Component: KOMBI         336 0580
   Coding: 07A501106F84100C0D8FFE03040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 2757DBE05E3802BC62-8072
          U1014 00 [008] - -
                    Fault Frequency: 23
                    Reset counter: 212
                    Mileage: 257006 km
                    Date: 2020.12.29
                    Time: 17:05:17
16777026 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 172
                    Mileage: 257334 km
                    Date: 2021.01.02
                    Time: 15:40:45
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000282345
   Coding: 030100340B087300EF00065E080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 346D3CAC9FEE7924D7-8060
   Generator:
H14 0035
   Serial number: 23130000438170060291
   Coding: 2C0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 1898680103
131595 - Tire Pressure Monitoring Module
          U0127 00 [009] - No Communications
                    Reset counter: 172
                    Mileage: 257006 km
                    Date: 2020.12.29
                    Time: 16:46:33
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: On
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000027319002
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73EFFFB0DA603E1C0E-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 06041301100132
   Coding: 003B1320D000048000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001185799
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 11
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D7B1988ACA4B86C28-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 28031306070861
   Coding: 003B1120DE00048000801000
   VCID: 3E791E84A1A2A37431-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001168150
   Coding: 090000
   Coding: 029A01000B000000
   VCID: 4085607CDB56D58443-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 044 B    HW: 5G0 035 044
   Component: MU-H-TN-EU    H41 0388
   Serial number: A329Z0DB000984
   Coding: 02730001FF00000011110001000800101F0202D401000100FF
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1E39FE040162C37411-804A
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9N2300PBP
   Subsystem 2 - Part No SW: V03 959 806 MR    HW: -----------
   Component: ECE 2021  --- 0189
   Compact disc data bank:
   Component: Gracenote  --- 1008
          B201A 00 [009] - -
                    Fault Frequency: 38
                    Reset counter: 180
                    Mileage: 255738 km
                    Date: 2020.11.29
                    Time: 20:00:32
                    Voltage terminal 30: 14.4 V
                    Status_Software_Version_Management-SW_VersMgtInfo: MDUV101/ABT
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
                    Reset counter: 148
                    Mileage: 255738 km
                    Date: 2020.11.29
                    Time: 20:00:31
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 222
                    Mileage: 257723 km
                    Date: 2021.01.09
                    Time: 16:27:20
                    Voltage terminal 30: 14.7 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 148
                    Mileage: 255738 km
                    Date: 2020.11.29
                    Time: 20:00:33
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 148
                    Mileage: 255738 km
                    Date: 2020.11.29
                    Time: 20:00:33
Address 65: Tire Pressure
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000193339620
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 356B01A89494602CE0-8060
649998 - Voltage Supply for Pin 9 in Socket
          C10EA 01 [008] - Electrical Failure
                    Reset counter: 205
                    Mileage: 256766 km
                    Date: 2020.12.22
                    Time: 08:03:07
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [008] - Open or Short to Plus
                    Reset counter: 207
                    Mileage: 256940 km
                    Date: 2020.12.28
                    Time: 13:03:21
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0050
   Serial number: 00000048235
   Coding: 0101010001020304000300000100000101
   ROD: EV_MFKBoschAU370.rod
   VCID: 3A711294BD8A8F540D-806E
End-------------------------(Elapsed Time: 05:06)--------------------------
Address 55,7P6 907 357 D,recoded (Long Coding),from,029A01000B000000,to,029A01000B000200,(82536/052/13366),
Address 55: DTCs cleared
According to your auto-scan above, the long-code string on the BCM reports Byte 02 = hex0F (Binary=0000 1111)
What have I missed?
Dick.T
C?ID=350787
What have I missed?
My bad, copy paste thing, just checked 09, BCM byte 02 is truly hex0F (Binary = 0000 1111)
@Dick.T: hmm......... OK - so clearly from the DTC s in your auto-scan - as currently coded, the BCM is expecting that the headlight fittings have reflector actuators for the low-beam function (operated by low-beam screen motors - I assume). Is this in fact true of the new fittings - or is this a relic of the old fittings?
Dick.T
C?ID=350787
Hmmmm..... Don't know, but when I perform the " Actuator diagnose - 03" I can manually command the reflectors separately up, so I assume they are standard in the low position.
