p2177. smoke test showed upper timing cover leak. repaired, rechecked no visible signs of leaks. same code. no oil leak near rear crankseal. tried to add supplemental fuel up into bell housing no change in data .pcv has been replaced. thanks for your help.
Tuesday,19,January,2021,14:02:31:57428
VCDS Version: 20.12.0.0 HEX-NET CB: 0.4529.4
Data version: 20201124 DS322.0
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Dealer/Shop Name: MC Auto Tech
VIN: WA1LFAFP6CA049976 License Plate:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 6C 6D 72
VIN: WA1LFAFP6CA049976 Mileage: 160360km-99643miles
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0002
Revision: E1H20---
Coding: 0121010A290F0160
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: C1CAD34B50691E8CCC-8094
2821 - Bank 1; System Too Lean off Idle
P2177 00 [101] - -
Mileage: 160349 km
Date: 2021.01.19
Time: 13:23:54
Engine RPM: 2162.00 /min
Normed load value: 33.7 %
Vehicle speed: 46 km/h
Coolant temperature: 94 °C
Intake air temperature: 21 °C
Voltage terminal 30: 14.418 V
Unlearning counter according OBD: 80
Readiness: 0000 0101
Part No SW: 8R0 927 158 T HW: 0BK 927 156 R
Component: 0BK 20TFSIUSA H17 1003
Revision: --H17---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: CED0F8779137F1F441-809A
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0110
Coding: 121D18
VCID: C5C2C75B4C4132ACF0-8090
Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS
Component: BCM2 2.0 H05 0435
Coding: 090500
Shop #: WSC 06335 000 00000
VCID: 8346194302F5CC9C9E-80D6
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0511000053439020
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000220333009
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Revision: C1000000 Serial number: 01051020111910
Coding: 64112000
VCID: 804C164F13E3D78483-80D4
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001238343
Coding: 26001091063CAF010000080300001D0D0F1C460802010161000000
VCID: BC34A2BF3F8B73649F-80E8
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 110926 H11 0050
Serial number: 90243014110921222503
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11706736
Coding: 024D25
Component: E1 - LDS H03 0031
Serial number: 00000000002909110543
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0081
Revision: 11001001 Serial number: 12501127400170
Coding: 300105
VCID: F8BC7EAF4B339F44BB-80AC
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H44 0610
Serial number: 003GPD0NKU78
Coding: 303633313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: C7DECD537E4D20BC02-8092
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100007068
Serial number: 6334MSME635102651
Serial number: 6344MSME635361200
Serial number: 6352QSME195F1246K
Serial number: 6362QSME78603244C
Serial number: 63732SME0D61517A%
Serial number: 63832SME1061056CV
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KJ70005M
Coding: 000017
VCID: BD32AFBB24917A6CA8-80E8
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 G HW: 8R0 920 981 G
Component: KOMBIINSTR. H22 0258
Revision: 00000000 Serial number: EK070M5AC
Coding: 8B1622000300D705020000
VCID: BE30A8B729976174B1-80EA
Part No SW: 8T0 907 468 AH HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0120
Revision: EC101057 Serial number: 5700E119200262
Coding: 00C303
VCID: 875E0D5336CDE0BCC2-80D2
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790509138
Fault Frequency: 14
Reset counter: 174
Mileage: 158842 km
Date: 2020.09.19
Time: 06:47:00
Bin. Bits: 00000
Voltage: 11.70 V
Count: 17
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0075
Revision: AA000000 Serial number: 00000015014387
Coding: 00581300000000000000
VCID: C2C8DC475D6F0594D5-8096
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000120512396
Coding: 011D03205E00440004
VCID: CAD8F467655FDDD41D-809E
Revision: 00002001 Serial number: 0160282584
Coding: 0126023A20FA749484B0053200000000
Shop #: WSC 49173 001 1048576
Component: GTO BF H01 0070
Serial number: 00000000000000443664
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34804010228003
VCID: FAB864A7753F8D54CD-80AE
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000014902226
VCID: C9DACB6B6059D6CC14-809C
Fault Frequency: 9
Reset counter: 165
Mileage: 158608 km
Date: 2020.07.30
Time: 12:49:13
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000001033885
VCID: B4248A9F17DBBB2457-80E0
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 111006-0002-045
Coding: 1197A61010020400
ROD: EV_HeadlRegulBasic.rod
VCID: AD129FFBFCF1EAEC18-80F8
Part No SW: 4G0 035 080 B HW: 4G0 035 080
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 158G30C7504678
Coding: 020007010000000001
Shop #: WSC 06521 444 122227
VCID: 9D724F3B84511A6C88-80C8
Part No SW: 8T1 035 664 D HW: 8T1 035 664 B
Component: H-BN-NA H52 0165
Revision: -------- Serial number: 490J00B7643383
Coding: 010200060005A1EF41000B0E000000030000
VCID: B93ABBAB30B9464C84-80EC
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466J-0B0644415
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000956816
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000015347910
Coding: 010C03204000240004
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H05--- Serial number: 525PA8-J14A2KV
Coding: 1020010
VCID: B4248A9FD7DBBB2457-80E0
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: BB36A1A33A85745C96-80EE
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000015347979
End----(Elapsed Time: 02:04, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
[code]
