hi all, long time no see,
asking for help with a steering assist yellow warning light on golf mk5
posted full scan below
story is . . lost its power steering and another garage fitted and reconditioned steering rack
its now ended up at my door and as you can see from the scan
communications fault in the abs controller and torque sensor faults in the steering assist module,
dont think its coded properly but they didnt take a full scan prior to work just wondering your ideas and thoughts
there is no abs warning lights
the steering assist faults do clear but return
the abs fault does not clear so maybe can bus issue or incorrect replacement steering rack ?
many thanks in advance
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 76
VIN: WVWZZZ1KZ7W207094 Mileage: 133650km-83046miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 KH HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 9245
Revision: --H06--- Serial number: VWZ7Z0G8060300
Coding: 0000072
Shop #: WSC 01279 785 00200
VCID: 6FE7DC587E8BEEFCEA-803A
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Mileage: 133599 km
Time: 12:20:20
RPM: 882 /min
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 29.7°C
Bin. Bits: 10110000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021121
VCID: 71E3DA2068BFF80CFC-8024
Part No: 1K0 820 047 GK
Component: Climatic PQ35 120 0606
VCID: 73EFD02812A3CA1C0E-8026
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006716910
Coding: 00890F2700041500471400001400000000087B075C0001
Shop #: WSC 01287 785 00200
VCID: 6BDFC8484A9312DCC6-803E
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 120207 020 0501
Coding: 00038805
Shop #: WSC 01287
01598 - Drive Battery Voltage
Reset counter: 13
Mileage: 133631 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.25 V
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD121FTB
Coding: 0013112
Shop #: WSC 01269 785 00200
VCID: 3D7B361064674C6C28-8068
Subsystem 1 - Serial number: 6332MSME17023B296
Subsystem 2 - Serial number: 6342MSME1674006EA
Subsystem 3 - Serial number: 6352QSME1D63351BK
Subsystem 4 - Serial number: 6362QSME20691B4BM
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000012
VCID: 74EDD33417ADCD2417-8020
Part No SW: 1K0 920 963 B HW: 1K0 920 963 B
Revision: V0003000 Serial number: VWZ7Z0G8060300
Coding: 0003403
Shop #: WSC 00132 210 84759
VCID: 2B5F08488A13D2DC86-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 200207F1002696
Coding: 3D0F074007000003
VCID: 2F671C58BE0BAEFCAA-807A
Component: IMMO VDD 1610
Shop #: WSC 06402 145 00197
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 005 0986
Coding: 0000692
VCID: 39732200704F704C04-806C
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 F
Component: EPS_ZFLS Kl.14 1301
00573 - Steering Torque Sensor (G269)
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 81C802087F2D840548DBC69010CC
Shop #: WSC 00046 412 819200
VCID: 00058FE45315E18403-8054
Component: LIN BACKUP HORN H07 8003
Subsystem 2 - Part No: 1K0 951 178
Component: Neigungssensor 001 0101
Subsystem 3 - Part No: 1K0 951 178
Component: Innenraumueberw.001 0101
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000948
VCID: 3A713D0C75497B540D-806E
Part No SW: 1K0 035 186 T HW: 1K0 035 186 T
Component: Radio BVX 034 0046
Revision: 00034000 Serial number: VWZ1Z2G4503589
Coding: 0040400
VCID: 37772438465B663CF2-8062
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D5B0650B407DCEC98-8078
End-------------------------(Elapsed Time: 01:45)--------------------------
