Wednesday,20,January,2021,09:36:34:36485
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WAUBGAFC5CN023211 License Plate: PA
Mileage: 255179km-158560mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 42 44 46 52 53 55
56 5F 62 6C 72 8F 90
VIN: WAUBGAFC5CN023211 Mileage: 255179km-158560miles
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0010
Revision: --H07---
Coding: 0A2A0032052600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 2708F3968F65FC63128-8072
6506 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [109] - -
Mileage: 255178 km
Date: 2020.12.12
Time: 12:28:43
Engine RPM: 3085.00 /min
Normed load value: 37.3 %
Vehicle speed: 36 km/h
Coolant temperature: 62 °C
Intake air temperature: 10 °C
Voltage terminal 30: 13.507 V
Engine speed: actual: 992 /min
MAF_ENVD: 288.69411 mg/stroke
Coolant temperature (unfiltered): 35.25 °C
Engine: operating status: IS
Engine load: 18.750000 %
Vehicle speed: actual: 2 km/h
Readiness: 0010 0101
Part No SW: 4G0 927 158 P HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 0003
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002017
VCID: 3B203FE663ED4883660-806E
8709 - Shift Monitoring
P0780 00 [237] - Shift Error
Mileage: 255173 km
Date: 2020.12.08
Time: 12:54:14
Voltage terminal 30: 13.665 V
Engine RPM: 2964 /min
Transmission input speed: 2819.00 /min
Transmission output speed: 896.00 /min
ATF temperature: 12 °C
Driving position: d
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
Current N215 Pressure control valve 1: 50.0 mA
Current N218 pressure reg.valve 4: 50.0 mA
Current N216 pressure reg.valve 2: 850.0 mA
Current N233 pressure reg.valve 5: 850.0 mA
Current N217 pressure reg.valve 3: 432.5 mA
Engine torque: 109 Nm
Current N443 pressure reg.valve 7 main pressure: 638.3 mA
M015_Time Normal Mode: 76 s
M019_Time Since Reset: 7650 ms
M014_Time Since Shift: 2160 ms
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 F HW: 4G0 907 379 F
Component: ESP PREMIUM H09 0250
Coding: 44A70F0122E5F0805B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 343214DA4EB387FBA7A-8060
Part No SW: 4H0 907 064 BC HW: 4H0 907 064 BC
Component: BCM2 2.0 H31 0330
Coding: 09883006000000000000
VCID: 6B80CFA6538D1803B60-803E
Component: J764 ELV MLB H39 0046
Serial number: 2311000115253001
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 N HW: 4G0 820 043 N
Component: KLIMA 2 ZONEN H10 0056
Serial number: 30061100040368
Coding: 6681201808
ASAM Dataset: EV_AirCondiBasisUDS 002033
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 2A0E0AA29C77C10B0D6-807E
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000000958232
Coding: 06002011163C9FE08100088380003908CF9CD208A2090121000004402000
VCID: 6E86C6B2609FED2B91E-803A
Component: WWS57X 110615 H35 0051
Serial number: 110621120815
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11525959
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 20 06 2011 00000854
Component: USHL4.2 H30 0030
Serial number: 0000002274555R0FSF02
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 4528C6B5000000000001
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000007
VCID: 2D0401BEAD19D633E84-8078
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901118000274
Coding: 280105
Shop #: WSC 08221 444 103350
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D80018KFP
Coding: 303234373131303030314A55304C34473053
VCID: 333017C64BBD80C3BE0-8066
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H11 0027
Serial number: 6940000Y11000057TK0U
Serial number: 3575HRB40570INGSAHF3
Serial number: 3585HRB404T0INGS81UM
Serial number: 3515JRB404V0IOK6191H
Serial number: 3525JRB404T0IOK6296M
Serial number: 3554VRB405J0JE3GA0OS
Serial number: 3564VRB405J0JE3G71RU
9442587 - Igniter for battery interrupt
B1015 1B [137] - Resistance Too High
Mileage: 255173 km
Date: 2020.12.07
Time: 15:05:42
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KFR0014U
Coding: 000414
VCID: 382A20EA525B639B8B2-806C
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0009
Serial number: 08 06 2011 33091382
Part No SW: 4G8 920 982 HW: 4G8 920 982
Component: TBenUsa H71 0375
Revision: 26181114 Serial number: 658060711592014
Coding: 0BE609040B01D705020000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K_AU57.rod
VCID: 71BCDDCE7121F2D38CC-8024
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000188521
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
VCID: 323E12C2B4A789CBB56-8066
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650828348
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006273140
Coding: 0058130000002001000001010101102030303232203232
VCID: 77A8E3D61FC5ACE3428-8022
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA42019TTP0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D0401BEAD99D633E84-8078
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011F17204E00628002000002
VCID: 42DE42020487394B256-8016
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0023105067
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0153416402
Coding: 0106023A00FA440480B00800020500000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000038740
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1265150.
Coding: 001F00
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 83
Mileage: 255173 km
Date: 2020.12.07
Time: 15:05:42
02616 - Fuel Tank Cap; Unlock
Reset counter: 79
Mileage: 255173 km
Date: 2020.12.07
Time: 16:06:57
02615 - Fuel Tank Cap; Lock
Reset counter: 80
Mileage: 255177 km
Date: 2020.12.08
Time: 13:04:00
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 41DC4D0E018122533CC-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000099285
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 110704-0004-075
Coding: 1221A6101002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2C020CBA9683DF3BFFA-8078
Component: Radio U SIRIU H51 0133
Revision: AB001007 Serial number: 156G10B7519277
Coding: 020007020100000001
VCID: 2412E49AFED3177B37A-8070
02617 - Satellite Antenna (R170)
Fault Status: 00101011
Reset counter: 122
Mileage: 255178 km
Date: 2021.01.06
Time: 09:16:52
Voltage: 12.20 V
Fault Status: 00101100
Reset counter: 123
Mileage: 255178 km
Date: 2021.01.19
Time: 13:15:54
Voltage: 14.90 V
03405 - Bass Loudspeaker
Reset counter: 79
Mileage: 255173 km
Date: 2020.12.07
Time: 15:05:44
Voltage: 12.20 V
Part No SW: 4G0 035 746 E HW: 4G0 035 746
Component: H-BNT-NA H48 0735
Revision: -------- Serial number: 031GS0B7509342
Coding: 050200000003E0EF45128B0E00000003100001000000000000
VCID: 290CF5AE99F1CA1304C-807C
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1301460S
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Serial number: 90349KG1000H9
Component: CD-Database 3371
Reset counter: 79
Mileage: 255173 km
Date: 2020.12.07
Time: 15:05:47
Text: IDC_UDF,IDC,M,0,0,6
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17204000628002000002
VCID: 44D2441A1E93377B17A-8010
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J19G3BA
Coding: 1080004
VCID: 2616FE9284EFE56B29E-8072
Component: TSG HR H04 0212
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FB8DBB66715E4239A8-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70BAD8CA7A2BFBDB832-8024
End----(Elapsed Time: 02:11, VBatt start/end: 11.9V/11.9V. VIgn 11.6V)-----
