Bentley Continental 2008 - Remote Control Matching
grant@gendan
Hi all,
Please can you help?
I'm trying to find the procedure to match Remote Control Fobs for this Bentley 3W.
The keys work with the immobiliser and start the vehicle but the remote fobs do not work.
Neither module 46 or 09 offer any adaptations for Remote Fobs.
Module 05 is asking for a security code to access Adaptation 001.
Any ideas how to match the remote fobs to this car please?
This car has lots of faults.
2 modules have been changed in the car:
3W0909610F - Trunk Control Module
3D0959933H - Central control unit (BCM)
Tuesday,19,January,2021,11:11:51:48730
VCDS Version: 20.4.2.0
VIN: SCBCE63W08C0587XX   License Plate:
Mileage: 120130km-74645mi   Repair Order:
Chassis Type: 3W (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 34 36 37 38 46 47
          53 54 57 65 68 6C 71 76 77
VIN: SCBCE63W08C0587XX   Mileage: 120130km-74645miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
54-Rear Spoiler -- Status: OK 0000
68-Wiper Electr. -- Status: Malfunction 0010
71-Battery Charger -- Status: Malfunction 0010
Address 01: Engine (   )       Labels: 07C-906-018-BWR1.clb
   Part No SW: 07C 906 018 FK    HW: 07C 906 018 FK
   Component: BY- 6.0L -TT NC G  ª1548
   Revision: --H03---    Serial number: VWX3Z0H3757879
   Coding: 0001175
   Shop #: WSC 00092 106 66965
   VCID: 73EE1BED110B721E1E-513C
005769 - Powertrain Data Bus
               P1689 - 004 - Implausible Message from Elect. Load Controller - Intermittent
                    Mileage: 120132 km
                    Temperature: 51.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.827 V
001169 - Secondary Air Injection System: Bank 1
               P0491 - 002 - Insufficient Flow
                    Fault Status: 01100010
                    Mileage: 120132 km
                    RPM: 671 /min
                    Load: 23.1 %
                    Temperature: 34.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.589 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Fault Status: 01101000
                    Mileage: 120132 km
                    Temperature: 22.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 12.192 V
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 09E 927 760 P    HW: GS1 911 4
   Component: ZWDU3404  6L W12TT  3404
   Revision: --H04---    Serial number:        0124675
   Coding: 0000111
   Shop #: WSC 00083 790 00000
   VCID: 3D7AFDD567CFF46E38-513C
Address 03: ABS Brakes        Labels: 3W0-614-511.clb
   Part No SW: 3W0 614 511     HW: 3W0 614 511
   Component: ESP 8.1 4WD     H01 0250
   Coding: 0002307
   VCID: 6CDC00914B35ADE6DF-8038
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0023
                    Hex Value: 0x0199
                    Hex Value: 0x0001
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component: 74 Kessy            6850
   Revision: 00H22070    Serial number: VWX3Z0H3757879
   Coding: 0422125
   VCID: 2A50C689814173D66D-807E
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 C
   Component:    CM Seat Pass.    0018
   Coding: 0000002
   Shop #: WSC 39310 001 1048576
   VCID: 49929905240758CE84-801C
8 Faults Found:
02569 - Control Module for Massage (J740)
00003 - Control Module
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
01975 - Passengers Seat Height Adjustment Motor (V191)
01904 - Passengers Backrest Adjusting Motor (V46)
01976 - Seat Depth Adjustment Motor (V234)
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 Q
   Component:    ZAB COCKPIT      2215
   Coding: 0401337
   Shop #: WSC 00092 106 182494
   VCID: 3A70F6C976E1C3561D-513C
8 Faults Found:
00823 - Line-Output; Front Left
00859 - Line-Output; Front Right
00385 - Positive Output Audio Channel for Speech/Telephone
00386 - Negative Output Audio Channel for Speech/Telephone
00387 - Plus Output Audio Channel for Navigation Announcements
00388 - Negative Output Audio Channel for Navigation Messages
00856 - Radio Antenna
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 F
   Component: Climatronic BY614   2014
   Coding: 0000111
   VCID: 346CD8F153853526C7-8060
01232 - A/C Compressor Regulator Valve (N280)
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 M    HW: 3D0 937 049 M
   Component: J519                6500
   Revision: -4004---    Serial number: --------------
   Coding: 40020000AB2A11000000000000000000
Address 11: Engine II        Labels: 07C-906-018-BWR2.clb
   Coding: 0001175
001672 - ECM Power Relay Load Circuit
               P0688 - 002 - Open Circuit - Intermittent
                    Mileage: 120132 km
                    Temperature: 143.0°C
                    Temperature: 6.0°C
                    Voltage: 0.127 V
001170 - Secondary Air Injection System: Bank 2
               P0492 - 002 - Insufficient Flow
                    Mileage: 120132 km
                    RPM: 669 /min
                    Load: 21.6 %
                    Temperature: 34.0°C
                    Temperature: 19.0°C
                    Voltage: 13.462 V
Address 15: Airbags        Labels: None
   Part No SW: 3W8 909 601     HW: 3W8 909 601
   Component: 15 Airbag 9.41  H14 0040
   Revision: 91H14004    Serial number: 0039L000B63A
   Coding: 0012597
   VCID: 7BFE33CD3E5B3A5E46-802E
   Subsystem 1 - Serial number: 63328RB403CA2371
   Subsystem 2 - Serial number: 63428RB403CA2BD0
   Subsystem 3 - Serial number: 63528RB403CA2EBC
   Subsystem 4 - Serial number: 63628RB403CA33B3
   Subsystem 5 - Serial number: 63700RB4
   Subsystem 6 - Serial number: 63800RB4
                    Reset counter: 243
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 18:01:05
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000032
   Shop #: WSC 01065 000 00000
   VCID: 47969F3D3213AEBE92-8012
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No SW: 3W0 920 841 E    HW: 3W0 920 841 E
   Component: J285 KOMBI-INST.    1623
   Revision: K0H10V35
   Coding: 0005402
   Shop #: WSC 57808 002 1048576
   VCID: 3776EFFD46F3DE3EE2-8062
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00101100
                    Reset counter: 243
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 17:59:46
                    Reset counter: 203
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 17:59:49
                    Reset counter: 243
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 18:01:02
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3W0 920 841 E
   Component: J533  GW-K-CAN TP20 1623
   Coding: DFF8FF2E9F0E4701
   VCID: 70E414E1631D4906E3-8024
                    Reset counter: 243
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 17:59:46
                    Reset counter: 203
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 17:59:49
Address 34: Level Control        Labels: None
   Part No: 3W0 907 553 B
   Component: LUFTFDR.-CDC- 3C3V0 7205
   Coding: 0005561
   VCID: 3972E9C574E7C84E14-806C
            013 - Check DTC Memory
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 C
   Component:    CM Seat Driver   0018
   Coding: 0000002
   VCID: 418281251C37908E5C-8014
11 Faults Found:
00997 - Motor for Driver's Seat Position; Fore/Aft (V48)
01174 - Driver Seat Height Adjustment Motor (V138)
00998 - Motor for Driver's Seat Recline (V45)
01903 - Seat Tilt Adjustment Motor (V231)
01895 - Motor for Steering Column Adjustment; Vertical (V123)
01896 - Motor for Steering Column Adjustment; Axial (V124)
Address 37: Navigation        Labels: None
   Part No: 3W0 919 887 J
   Component:    NAVIGATION       2197
   Coding: 0400000
   VCID: 4E98AA19DD697FF6D1-801A
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 F
   Component: Dachmodul           0802
   Coding: 0006589
00926 - Terminal 30
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 H
   Component: 0P HSG              0200
   Coding: 0000040
   VCID: 356AE5F55FFF2C2EF0-4B00
   Subsystem 1 - Part No: 3W8 959 701 J
   Component: Tuersteuergeraet FS 1106
   Subsystem 2 - Part No: 3W8 959 702 J
   Component: Tuersteuergeraet BF 1106
   Subsystem 3 - Part No: 3W8 959 703 D
   Component: Tuersteuergeraet HL 0703
   Subsystem 4 - Part No: 3W8 959 704 D
   Component: Tuersteuergeraet HR 0703
   Subsystem 5 - Part No: 3W0 909 610 G
   Component: 14 HDSG             1810
   Subsystem 6 - Part No: 7L0 907 719 A
00321 - Rear Lid Hydraulic Sensor (G383)
00319 - Rear Lid Hydraulic Motor (V241)
   Part No: 3W8 035 456
   Component: 12K-AUDIOVERST      3000
   VCID: 79F229C53467084E54-802C
00419 - Left Front DSP Midrange Speaker (R103)
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 E    HW: 3W0 907 801 E
   Component: EPB  BC7H0270   HC7 0270
   Coding: 0022413
   VCID: 3874ECC148EDD146EB-513C
01019 - Relay
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 H
   Component: Heckspoiler         0002
   VCID: 3064D4E1F09D0906A3-51D0
Address 57: TV Tuner        Labels: None
   Part No SW: 3D0 919 148     HW: 3D0 919 148
   Component: TV-Tuner            0160
   Revision: R0H16000    Serial number: 91100500436101
   Coding: 0000003
   VCID: 67D67FBD52D38EBEB2-8032
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No SW: 3W7 907 273 A    HW: 3W7 907 273 A
   Component: J0502 RDK           0004
   Revision: 0004 004    Serial number: 00000700004345
   Coding: 3501E052A5F952A5F9A7DA00A7DA00
   VCID: 3E78FAD96DC9EF7621-806A
01840 - Antennas for Tire Pressure Monitoring
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON
                    Fault Status: 10100101
                    Reset counter: 243
                    (no units): 177.0
02214 - Tire Pressure Warning
                    Reset counter: 202
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 17:36:31
                    (no units): 64.0
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 G
   Component: Wischermodul       ª9328
   Shop #: WSC 00000 725 65552
   VCID: 3B7EF3CD7EDBFA5E06-806E
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
   Part No SW: 3W3 907 441     HW: 3W3 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number:    PA8 J840133
   Coding: 2000002
   VCID: 76E822F90579673639-8022
                    Reset counter: 243
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 18:05:32
                        Term 15 Off
                        Reverse OFF
                    Count: 3
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 191
                    Mileage: 120066 km
                    Date: 2005.12.31
                    Time: 23:04:45
                        Term 15 Off
                        Reverse OFF
                    Count: 3
02283 - Video Connection to Output [End Unit]
                    Reset counter: 202
                    Mileage: 120132 km
                    Date: 2001.05.29
                    Time: 17:36:52
                        Reverse OFF
                    Count: 3
                    Fault Status: 01101101
                    Reset counter: 203
                    Mileage: 120132 km
                    Date: 2001.06.05
                    Time: 12:42:51
                        Reverse OFF
                    Count: 3
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 244C28B1E365A5A657-8070
00084 - Electrical System Battery Switch-Over Relay
00085 - Starter Battery Switch-Over Relay (J580)
01049 - Supply Voltage Term 50
   Part No: 3W0 919 283 B
   Component: 0C Einparkhilfe     0404
   VCID: 3C7CF0D17BD5FD660F-8068
Address 77: Telephone        Labels: None
   Part No SW: 3W0 035 385 AS    HW: 3W0 035 385 AS
   Component: rSAP Bentley        0262
   Revision: 00008000    Serial number: 30800000044935
   Coding: 0031000
   VCID: 06085239759977B629-8052
End-------------------------(Elapsed Time: 05:15)--------------------------
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Does this Bentley have keyless entry (unlock on touch of door handle)?
If yes, then you shouldn't have to take any extra actions. Matching the keys to the Immobilizer in address 05 is all you should need to do. I've successfully matched both a full keyless-entry remote and a plastic emergency key to my Phaeton. Check to make sure the batteries in the keys are good, and that you see the green LED on the key flashes when you press buttons.
If no, then I'm afraid I don't have advice to give, as I haven't had to perform Immo/remote matching on a non-keyless D1, so I don't know if you have to match both 05/46 or still just 05. Maybe @Jack@European_Parts would have some knowledge here?
NostraJackAss
Does VCDS offer service mode to add remotes in adaption menu in the lock module 0x05 and then too click them each?
Are the remotes the correct frequency to be seen on crystal?
Are the batteries charged?
Did you use a signal finder & ID old remotes + new remotes on emulation
On Hitag?
The remotes if correct should of worked upon being programmed.
Is infotainment in radio or single wire DTC causing a problem?
Look at blocks to see what is in error on CAN among modules.
grant@gendan
Thanks for replying.
The remotes were working before the control modules failed and were replaced (apparently due to water ingress).
I can only assume that changing the BCM has lost the remotes. There are 2 remotes and neither work anymore.
We looked at Adaptations in 0x05 and from memory, none were documented. If we tried to access Channel 001, it asked for Security Access.
Adaptation Channel 001 wasn't related to remote fobs in 0x46 or 0x09.
Wondering if ODIS is needed to get the car to accept these remotes :confused:. I'm thinking the Adaptation needed to match the remotes is hidden behind Security Access in 0x05.
It's possible the problem is related to the CAN Network fault but if it's happy running in Single Wire Mode, I'd expect the remotes still to work. What are your thoughts?
NostraJackAss
As aforementioned........or
Try an SVM
Now you know why I do straight up forensic data transfers, even from under water deep sea divers fishing for wet Kessy!
Would you like me to try and go fishing in old module?
NostraJackAss
In receipt of email.
Lots of documents required and modules to triangulate the identity.
Seems like short path would be to fix faults first and see if remotes wake and if not SVM since across the pond.
