Hello everyone!
For more than a year, when scanning my VW Amarok, I see an error in the left temperature flap motor, which says that it is stuck. the error is intermittent. but lately I can hear noises when the servo motor works and the climatronic no longer cools as before.
For example, before, having the car in the sun, at about 35 ° C, I would enter the car and when I turned on the air conditioning, set at 22 ° C, it applied 3 or 4 levels of the blower, this to try to cool the cabin. as fast as possible. but now it only applies 1 or 2 levels of the blower. I can compare this with the climatronic of my Tiguan.
I have already bought the servo motor to replace it, but according to the service manual, before removing it, the climatronic must be put in "service position" and after removing and putting the servo motor, make a basic setting, which I already saw how to do it with the VCDS, but I have not seen how to set the service position.
Just to clarify, the temperature registered by the internal sensor is almost the same as the external one, it varies only by about 2 or 3 degrees. so I assume the problem is the servo motor.
I leave a scan, but since I did a delete of errors it has not been generated again.
Monday,18,January,2021,11:19:20:04451
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WV1ZZZ2HZEA001376 License Plate:
Mileage: 103600km-64374mi Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 22 25 32 56
VIN: WV1ZZZ2HZEA001376 Mileage: 103600km-64374miles
Address 01: Engine (J623-CNEA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 012 AT HW: 03L 907 309 AC
Component: R4 2,0L EDC H24 5931
Revision: 74H24--- Serial number: 00000000000000
Coding: 01590012232600080001
Shop #: WSC 07456 000 09999
ASAM Dataset: EV_ECM20BTD01103L906012AT 001006
ROD: EV_ECM20BTD01103L906012AT.rod
VCID: 76B5E55B58462B8B59E-8022
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 L HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0110
Revision: 00H44001
Coding: C07324B69194039624A589AA6F5690
Shop #: WSC 07456 000 01807
VCID: 392F2E67295884F374C-806C
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H0 907 040 E HW: 2H0 907 040 E
Component: ClimatronicT5 H19 0406
Revision: 00001003
Coding: 0000000002
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 2313EC0FBB54EE234E0-8076
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
Component: PQ25 BCM H30 0555
Revision: -1------ Serial number: --------------
Coding: 750002380C210000003808102C4B84C40080410E60000000300000000003
Shop #: WSC 00241 865 100878
VCID: 4EC56DBB80D6334BB1E-801A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3323
Coding: 840000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3323
Coding: 840000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0573921
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3323
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3323
Coding: 800000
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00B H07 0013
Revision: -------- Serial number: 003HN00CUA2B
Coding: 000000000000000000000000000000003042
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 33331C4F0BB47EA3BE0-8066
Serial number: 3495RRB400C50H9GCOFS
Serial number: 3505RRB400C50H9GIP3F
Serial number: 3555YRB401C50GJ0KP8S
Serial number: 3565YRB401I50GJ0R9R2
Part No SW: 2H0 920 853 C HW: 2H0 920 853 C
Component: KOMBI H05 0605
Coding: 150A00
VCID: 2809FB23C2720D7B1B2-807C
Part No SW: 6N0 909 901 HW: 6R7 937 087 M
Component: GW-K-CAN TP20 H30 0555
Revision: -1------
Coding: 742200
Shop #: WSC 07462 790 50316
VCID: 70B9D3433AA205BB832-8024
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 D HW: 2H0 927 755 D
Component: SG offroad VTG 0156
Revision: 00H07000 Serial number: T53YC14433OSPV
Coding: 0000013
VCID: 313F1647FD284CB3CCC-8064
Component: IMMO H05 0605
VCID: 6A8DC12B1CFEFF6BCD6-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 12.06.13 00
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C010733D68A215BFFA-8078
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5516
Revision: -------- Serial number: VWZZZ4J6246404
Coding: 16000440040016
Shop #: WSC 00078 790 00103
VCID: 46D5559B68A6FB0B09E-8012
End----------(Elapsed Time: 00:46, VBatt start/end: 13.6V/13.7V)-----------
