2001 Audi TT Quattro 225BHP w/ 6 speed Manual Trans
Issue: Bought the car with known ABS Issues. Found out that the ABS Control Module was removed and never re-installed. So I do not have a scan with the original control module. I bought a used control module that was, at the time, closest to my car as possible. Now I can read the module but I have been unsuccessful in coding. From what I can tell reading the service manual is that the coding for the module is correct but its not coded to my car. I have gone through the service manual and completed all the steps, in order, to code the module. I'm not sure if I am missing a step or what? I may even have the wrong module. I took an educated leap of faith with the module I bought.
Current Modifications: Lowered 1 inch with Bilstein shocks/ Eibach springs, Forge DV, Silicone TIP, Open Air filter, PCV Delete/catch can install (all lines were cracked), All vacuum hoses replaced with silicone hoses.
I have replaced all wheel speed sensors but have not driven the vehicle to be able to clear those faults.
I have VCDS Lite and I am newer to coding and all.
Any help, in layman terms, would be great! Here is all the information I have and will be useful.
VCDS-Lite
Windows Based VAG/VAS Emulator
Version: Release 1.2
Workshop Code: 000 00000
Self-Diagnosis Log
Sunday, 17 January 2021, 14:24:47:10944
VIN Number: TRUWT28N511003538 License Plate:
Mileage: Repair Order:
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8N0 906 018 T
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 01236
VCID: 42F7E3CB5D97
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
VCDS-Lite
Self-Diagnosis Log
Sunday, 17 January 2021, 14:24:48:10944
Page 2
Address 03: ABS Brakes Labels: None
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 12346
VCID: 3E0F973B296F
10 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-00 - -
35-00 - -
35-00 - -
35-00 - -
01312 - Powertrain Data Bus
37-00 - Faulty
57-00 - Electric Circuit Failure
00813 - Sensor 2 for Brake Pressure (G214)
00812 - Brake Pressure Release Solenoid (F84)
35-00 - -
62-00 - No or Incorrect Adjustment
49-00 - No Communications
Address 08: Auto HVAC Labels: 8N0-820-043.LBL
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 28235163DBEB
Address 15: Airbags Labels: 8N8-909-601.LBL
Controller: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
VCID: F781C21FC6D5
00-10 - - - Intermittent
VCDS-Lite
Self-Diagnosis Log
Page 3
Address 17: Instruments Labels: 8Nx-920-xxx-17.LBL
Controller: 8N1 920 930 E
Component: KOMBI+WEGFAHRS. M73 D07
Coding: 07244
Shop #: WSC 21032
VCID: 3319B60F122D
Address 22: AWD Labels: 02D-900-554.LBL
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F314ABF8EA5
Address 35: Centr. Locks Labels: 8Nx-962-267.LBL
Controller: 8N8 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
VCID: 3FF1EA3F2E65
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Controller: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
VCID: FC8BDD33FFF3
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: E5BD98576C79
VCDS-Lite
Self-Diagnosis Log
Page 4
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Controller: 8N0 035 186 A
Component: Radio D05
Coding: 00517
Shop #: WSC 01236
VCID: 2E2FA77BF90F
End --------------------------------------------------------------------------------------------------
