2016 GLI pedal response coding
GLIRob
Illinois, USA
HUC-2H
Hi... does anyone know how to code to increase the acceleration pedal response sensitivity on 2016 GLI. It’s so laggy and annoying.
South Molton, UK
Got a full VCDS Auto-Scan of your 2016 GLI - not all ECUs have the same coding/adaptation settings.
I doubt there are any tweaks available for this.
It's a turbo. It will have some lag. The question is whether the lag the OP is unhappy about is just normal turbo lag, whether there's something wrong with his car. If he simply wants a more responsive pedal, then that can be done by tweaking a map in the ECU (requires a tuner), or via something like a Pedal Commander.
GLIRob
Illinois, USA
HUC-2H
Here is a full scan off hand, thanks
Tuesday,22,December,2020,21:15:36:21683
VCDS Version: 20.12.0.1 (x64)
VIN: 3VW4T7AJXGM236099   License Plate: 12-22-2020 #2
Mileage: 37960km-23587mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52
          55 5F 62 72 75
VIN: 3VW4T7AJXGM236099   Mileage: 37960km-23587miles
Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 AT    HW: 06K 907 425 C
   Component: R4 Stg2 TFS   H13 4886
   Revision: --H13---
   Coding: 001D0012242400171000
   Shop #: WSC 00066 000 00293
   ASAM Dataset: EV_ECM20TFS02006K906071AT 001003
   ROD: EV_ECM20TFS02006K906071AT.rod
   VCID: 7DF1F6C0ECA5DD6C69-8028
17178 - Databus
          U1123 00 [036] - Received Error Message
                    Mileage: 37960 km
                    Date: 2020.12.22
                    Time: 09:01:57
                    Engine RPM: 1620.50 /min
                    Normed load value: 36.9 %
                    Vehicle speed: 52 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 13.750 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
   Part No SW: 02E 300 043 T    HW: 02E 927 770 AL
   Component: TVS DSG         531 2299
   Revision: 06253104    Serial number: 00001506120064
   Coding: 0000024
   Shop #: WSC 00020 000 90108
   VCID: 2541FEA0ECB5B5AC51-8070
   Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
   Component: ESP MK60EC1   H46 0174
   Revision: 00H46001
   Coding: A14B600C49250000850B06ED922200412118F06A
   Shop #: WSC 00066 123 12345
   VCID: 74E7D3E4D7EF9C2416-8020
                    Fault Status: 00101101
                    Reset counter: 45
                    Mileage: 37960 km
                    Date: 2020.12.22
                    Time: 09:01:57
                    Count: 24
                    Count: 32768
                    Count: 4608
                    Count: 8196
                    Count: 49716
                    Count: 256
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0373208211
   Coding: 030C0C
   VCID: 377D24E88E19373CF3-8062
   Part No SW: 1K8 907 044 AR    HW: 1K8 907 044 AR
   Component: Climatronic   H05 0304
   Revision: 00001K02
   Coding: 0050019002
   Shop #: WSC 00066 000 00320
   VCID: 7F0D0CC8E6A9CF7C7B-802A
   Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
   Component: BCM PQ35 H+   122 0183
   Revision: BL122001
   Coding: EF200A3A942F06D40188008124008BCC0174000E45A08DB2E4842000A040
   Shop #: WSC 12345 123 61029
   VCID: 7DF1F6C0E4A5DD6C69-8028
   Component: RLS 080715 05  54  0403
   Coding: 02300A
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331519700769
   Coding: 0071155011
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 366329EC8913CE34E8-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM00RM38
   Coding: 8CCCF000000000005000001AC20800000065
   Shop #: WSC 00066 790 00065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63C5A0B86A010B9C7F-8036
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003AKC49
   Coding: 30314C
   Subsystem 2 - Part No SW: -----------    HW: 480 002 506 15
   Serial number: 357000000006B029841D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 506 15
   Serial number: 35800000000507298419
   Subsystem 4 - Part No SW: -----------    HW: 480 023 006 15
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001A319D1C31A670
   Subsystem 5 - Part No SW: -----------    HW: 480 020 906 15
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001BD19BDF25475L
   Subsystem 6 - Part No SW: -----------    HW: 480 020 807 15
   Component: FrontSensor_D  000 0189
   Serial number: 3550001BD1B2C52293A9
   Subsystem 7 - Part No SW: -----------    HW: 480 020 807 15
   Component: FrontSensor_P  000 0189
   Serial number: 3560001BD1B2C520F47C
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20150702201993
   Coding: 0012440008
   ROD: EV_SMLSNGVOLWSR8C.rod
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H03 0102
   Serial number: 29150001070060035212
   Coding: B1FFFF
   Part No SW: 5C6 920 985 C    HW: 5C6 920 985 C
   Component: KOMBI         H04 1009
   Coding: 271E010000
   VCID: 326B15FC657BD214C4-8066
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 29071503000366
   Coding: 351032
   VCID: 72EBD5FCADFB921404-8026
   Component: IMMO          H04 1009
   Coding: 000007
   VCID: 6ADBCD9C8D2B5AD4BC-803E
   Revision: 00000000    Serial number: 15000155110004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 306F1FF46B77E004B2-8064
   Component: HRE_Master    H11 0071
   Serial number: 0372977213
   Coding: 02011102
   Shop #: WSC 00066 790 00293
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C773BC4B73F14641E-8068
   Component: HRE_Slave  H11 0071
   Serial number: 0372997556
   Coding: 020111
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0009903010
   Coding: 0404BD
   Shop #: WSC 00066 790 00196
   VCID: 5BB598585271335C37-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587150803023402
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 5
                    Mileage: 37955 km
                    Date: 2020.12.22
                    Time: 07:58:12
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 397922D0700D214C05-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0064535
   ROD: EV_AudioVerst10KanalSTT3_VW36.rod
   VCID: 285FF79453A7A8C46A-807C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1663
   Coding: 01030100
   VCID: 6FEDDC88BEC9BFFCEB-803A
   Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST000AMWD500000
   Coding: 180000
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0009912985
   Coding: 0404BC
   VCID: 5CB79B44577F34643E-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14202586150731091716
   Coding: 800000
                    Reset counter: 5
                    Mileage: 37955 km
                    Date: 2020.12.22
                    Time: 07:58:12
   Component: AFS-ECU       H05 0111
   Coding: 081200010B000200
   Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H21 0241
   Serial number: VWZAZ2R0364976
   Coding: 02630102AA00000051220003001808001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 62CBA5BC751B029474-8036
   Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140540
   Coding: 02630102C24232107F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 1427B364FF2F3C24B6-8040
GLIRob
Illinois, USA
HUC-2H
Looks like you've already got a tune..
Yes I do... however the pedal is still laggy, it was like that when it was stock too. I understand the GTI's have a coding to help this so I'm hope there would be one for mine.
