3Q0980654 adaption channels for initial calibration
Ewald
C?ID=303130
Hi all,
the 3Q0980654 camera has been installed in many vehicles. It can be calibrated without special tools by changing the following adaptation channels:
IDE10924-MAS02479-Initiale Kalibrierung: Ergebnis-Gierwinkel,0.243 °,8
IDE10924-MAS05286-Initiale Kalibrierung: Ergebnis-Wankwinkel,-0.265 °,8
IDE10924-MAS05287-Initiale Kalibrierung: Ergebnis-Nickwinkel,0.986 °,8
IDE10924-MAS10678-Initiale Kalibrierung: Ergebnis-Kamerahöhe,1399 mm,8
Hight to be measured by laser and angles can be taken out of measurement channels.
How to do that with VCDS? The login is 89687. VCDS fails when I want to safe a new value.
VCP has no problems to change the above mentioned channels in Engineering Mode after login.
downtime
Finland
C?ID=280813
I think that is the problem. You need to be able to change to engineering mode to input those values and VCDS is not able to do it afaik.
What if it could, and you just had to know how? ;)
downtime
Finland
C?ID=280813
Interested. What would be the magic needed for that? :)
Ewald
C?ID=303130
Maybe you want to let us know to do this job with VCDS? ;)
AINils
Germany (AIB)
There are 2 ways, use custom label with change command or just some magic which is secret by Uwe ;-)
Ewald
C?ID=303130
Custom label is clear. What do you mean with "change command"?
