- Jan 16, 2021
- 1
- 0
- Portland, OR, USA
- C?ID=425451
Hi All,
Just ran the first scan of my 2008 A3 2.0 FSI problem child of a vehicle. This vehicle has been sitting for a while and just got a new intake camshaft, cam follower, timing chain plus has a new battery (verified 12.0V at the fuse block). Here's the current scan results - thank you in advance for any guidance. Any initial pointers & research topics would be much appreciated.
Saturday,16,January,2021,13:27:49:35349
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WAUNF78P58A081997 License Plate:
Mileage: 90370km-56153mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 65 72
VIN: WAUNF78P58A081997 Mileage: 90370km-56153miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 P HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0G8FNT00G
Coding: 0103010A1C070160
Shop #: WSC 06314 000 00000
VCID: 3FDB48E1EB751DA34A8-806A
P0300 - 008 - - Intermittent
Fault Status: 00111000
Mileage: 90376 km
Date: 2017.01.09
Time: 03:40:20
RPM: 1146 /min
Load: 45.5 %
Temperature: 33.0°C
Temperature: 28.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
Mileage: 90376 km
Date: 2017.01.09
Time: 03:40:26
RPM: 1051 /min
Load: 22.7 %
Temperature: 35.0°C
Temperature: 29.0°C
Voltage: 13.970 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
Mileage: 90376 km
Date: 2017.01.09
Time: 03:40:26
RPM: 1051 /min
Load: 22.7 %
Temperature: 35.0°C
Temperature: 29.0°C
Voltage: 13.970 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage
Temperature: 6.0°C
Temperature: 8.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 12.065 V
Readiness: 0000 0101
Part No SW: 02E 300 044 J HW: 02E 927 770 AD
Component: GSG DSG 082 1404
Revision: 05108020 Serial number: 00001004010143
Shop #: WSC 04940 001 00001
VCID: 1C61DF6D5AA366BB8FA-8048
Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0053890
VCID: 6889B3BDDE7B7A1BDB2-803C
013 - Check DTC Memory
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0420
Revision: 195627 Serial number: 8P0820043AG
VCID: 71BFDED9EDA1BBD38CC-8024
Reset counter: 75
Mileage: 88980 km
Voltage: 8.80 V
01273 - Fresh Air Blower (V2)
Reset counter: 75
Mileage: 90357 km
Date: 2015.11.03
Time: 01:14:23
Temperature: -50.0°C
Speed: 325.0 km/h
(no units): 137.0
(no units): 248.0
Fault Status: 01101000
Reset counter: 39
Mileage: 90376 km
Date: 2017.01.12
Time: 00:02:33
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007662113
Coding: 018C0F81D01410004F1818001800000000285E175C110000000000000000
Shop #: WSC 06314 000 08192
VCID: 45D75A0989A94773004-8010
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Reset counter: 79
Date: 2005.09.13
Time: 31:63:63
Voltage: 5.00 V
Reset counter: 75
Mileage: 90357 km
Date: 2015.11.03
Time: 01:14:00
Voltage: 7.00 V
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 M HW: 8P0 959 655 M
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CQ0000XA+
Coding: 0032605
VCID: 4CC16F2DAAC3B63BDFA-8018
Subsystem 1 - Part No: 8P0 910 339 C
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 002ZB
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB405F9539C+ÿ†63
Subsystem 5 - Serial number: 9539C+ÿ†6342DRB405F8C78D9ÿ†63
Subsystem 6 - Serial number: 8C78D9ÿ†63528RB402E67699Xÿ†63
Subsystem 7 - Serial number: 67699Xÿ†63628RB402EB8500Lÿ†63
Subsystem 8 - Serial number: B8500Lÿ†63747RB402EC1500Hÿ†63
Subsystem 9 - Serial number: C1500Hÿ†63847RB402EC14D3Xÿ
Subsystem 10 - Serial number: C14D3Xÿ
Fault Frequency: 14
Reset counter: 79
Mileage: 88980 km
Date: 2015.03.12
Time: 00:00:11
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0012142
VCID: 41DF4E199D816B533CC-8014
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 N HW: 8P0 920 981 N
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2248G001100115
Coding: 0016288
Shop #: WSC 06180 001 1048576
VCID: 43D34411879D79432E0-8016
00771 - Fuel Level Sensor (G)
Fault Status: 00101010
Reset counter: 75
Mileage: 90358 km
Date: 2015.12.07
Time: 19:44:24
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0792580E0
Coding: ED807F071002022102
VCID: 30391BDD262BF2DBC32-8064
Revision: D0H20001 Serial number: AUX7Z0G8FNT00G
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0001177
01706 - Switch for Mirror-Adjust (E43)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
VCID: 35372AC9D949D7F3904-8060
Temperature: 5.0°C
Voltage: 5.60 V
Voltage: 5.40 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H11 0080
Coding: 1B8022A001382D09050FCC8F0477
VCID: 44D1470D82937E7B17A-8010
Subsystem 1 - Component: Sounder No Answer
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674752844628
Reset counter: 79
Mileage: 90376 km
Date: 2017.01.06
Time: 07:40:13
Temperature: 12.0°C
Reset counter: 79
Mileage: 88980 km
Date: 2015.03.16
Time: 23:09:41
Temperature: 37.0°C
00422 - Rear Right DSP Midrange Speaker (R106)
Fault Status: 00111011
Reset counter: 68
Mileage: 88926 km
Date: 2015.02.18
Time: 10:25:21
Temperature: 14.0°C
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0001177
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 H HW: 8P0 035 186 H
Component: R Concert2+ H17 0240
Revision: 00H17000 Serial number: AUZ1Z3G9205240
Coding: 0210112
VCID: 372B20C1C34525E3828-8062
Time Indication: 15
Reset counter: 75
Mileage: 90357 km
Date: 2015.11.03
Time: 01:16:00
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0001176
Shop #: WSC 06314 000 1012544
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 65: Tire Pressure Labels: 8J0-907-273.lbl
Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
Component: J502-RDK H02 0300
Revision: --H02-D0 Serial number: 12679772019965
Coding: 0860021
Shop #: WSC 06435 000 00000
VCID: 2F3B18A13B15ED23DA8-807A
Not Recogn.
Bin. Bits: 00001000 00000000
Voltage: 6.30 V
Text: -50°C;n.erkannt; n.erkannt
02214 - Tire Pressure Warning
Reset counter: 77
Mileage: 90358 km
Date: 2016.02.24
Time: 16:26:59
Speed: 21.8 km/h
Bin. Bits: 00001000 10000011
Voltage: 14.10 V
Text: 11,5°C; 0,60bar;3428761392;00h; 10°C
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0001176
VCID: 42DD41159887704B256-8016
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:30, VBatt start/end: 12.0V/12.0V)-----------
VCDS Release 20.12.0: SRI Reset
Control Module Part Number: 8P0 920 981 N Labels: 8P0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H20 0640, Coding:0016288
Channel Description Unit Current val. New val.
02 Service Reminder Status 1 ---
40 Distance since Service km x100 0 ---
41 Time since Service Days 308 ---
42 Minimum Distance to Service km x100 100 ---
43 Maximum Distance to Service km x100 100 ---
44 Maximum Time to Service Days 365 ---
45 Oil Quality 1 ---
47 Soot Quantity km x100 0 ---
48 Thermal Load km x100 4 ---
49 Minimum Time to Service Days 365 ---
50 Basic Distance Value for Oil Change km x100 160 ---
51 Basic Time Value for Oil Change Days 365 ---
52 Basic Distance Value for Inspection km x100 160 ---
53 Distance since Inspection km x100 0 ---
54 Basic Time Value for Inspection Days 365 ---
55 Time since Inspection Days 308 ---
56 Day Counter Days 3380 ---
Mileage: 90376 km
Date: 2017.01.09
Time: 03:40:20
RPM: 1146 /min
Load: 45.5 %
Temperature: 33.0°C
Temperature: 28.0°C
Voltage: 13.970 V
000769 - Cylinder 1
Mileage: 90376 km
Date: 2017.01.09
Time: 03:40:26
RPM: 1051 /min
Load: 22.7 %
Temperature: 35.0°C
Temperature: 29.0°C
Voltage: 13.970 V
000770 - Cylinder 2
Mileage: 90376 km
Date: 2017.01.09
Time: 03:40:26
RPM: 1051 /min
Load: 22.7 %
Temperature: 35.0°C
Temperature: 29.0°C
Voltage: 13.970 V
Voltage: 0.000 V
Temperature: 6.0°C
Temperature: 8.0°C
Voltage: 12.065 V
Revision: 00H14001
Coding: 0053890
Reset counter: 75
Mileage: 88980 km
Voltage: 8.80 V
Reset counter: 75
Mileage: 90357 km
Date: 2015.11.03
Time: 01:14:23
Speed: 325.0 km/h
(no units): 137.0
(no units): 248.0
Coding: 00062736
Shop #: WSC 06314
Coding: 0032605
Coding: 0012142
Coding: 0016288
Coding: 0001177
Coding: 0001177
Coding: 0210112
Coding: 0001176
Coding: 0860021
Coding: 0001176
End----------(Elapsed Time: 01:23, VBatt start/end: 12.0V/12.0V)-----------
