- Jan 15, 2021
- 3
- 0
- Aberdeen, UK
- C?ID=429233
Good Evening all,
I was hoping one of you smart people could assist me with this issue I’m having with this Amaro? The issues or complain is lights on in the car, to be fai it’s like Christmas in the cab lol.
the 4x4 lights are flashing in the instrument cluster along with most of the other lights, also the 4x4 lights on the centre console are illuminated and flashing.
what I have done is checked can resistance and getting a healthy 66 ohms, however I am getting no commas on the can network, it looks like the can low is being pulled to ground on the scope.
so with this in mind I have started to look for module, I have found the body control module above the fuse box in the drivers footwell, disconnected and no effect on can network also not sure what they are but disconnected a module in the centre of the car under the heater also behind the kick panel on the passenger side but unable to find anymor.
are there any more if so does anyone know where please
any help greatly received thanks
#hndoc:?docid=00006644&xt=hnh:3DED524935E24C142008A493F9197B189FC6E743F85ED1BC8F239E5C525471F3
Thu,Jan,14,2021,15:55:31
VCDS Mobile 0.4529.0.4
VCDS Mobile: 0.4529
Data Version: 30000060
VIN: WV1ZZZ2HZFH001808
Scan: 01 03 08 09 10 15 17 19 22 25 37 56
08-Auto HVAC -- Status: Malfunction 16010
09-Cent. Elect. -- Status: Malfunction 16010
19-CAN Gateway -- Status: Malfunction 16010
22-AWD -- Status: Cannot be reached 1110
37-Navigation -- Status: Malfunction 16010
56-Radio -- Status: OK 16000
Address 01: Engine (CNEA J) Labels: 03L-906-022-CFC.clb
Part No SW: 03L 906 012 AD HW: 03L 907 309 AC
Component: R4 2,0L EDC H24 7088
Revision: 74H24---
Coding: 01594012232600080000
Shop #: WSC 02310 790 50316
ASAM Dataset: EV_ECM20BTD01103L906012AD 001006
ROD: N/A
VCID: 668F159B117F4599E4EED4-8033
No ASAM data for: "EV_ECM20BTD01103L906012AD"
004483 - ROD - Unknown faultcode
Mileage: 61193 km
Date: 2009.14.13
Time: 00:26:43
004711 - ROD - Unknown faultcode
Mileage: 61193 km
Date: 2009.14.13
Time: 00:26:44
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 Q HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0112
Revision: 00H44001
Coding: 462C0906F1DF40
Shop #: WSC 02310 790 49160
VCID: 3E3F9DFB296F25594C7E1C-806B
02053 - Control Module for Transfer Case (J646)
Reset Counter: 25
Mileage: 61193 km
Date: 2009.14.13
Time: 00:01:28
Count: 32768
Count: 4353
Count: 8269
Count: 1022
Reset Counter: 122
Mileage: 61106 km
Date: 2008.14.17
Time: 13:28:29
Count: 16448
Count: 4097
Count: 8214
Count: 768
Reset Counter: 122
Mileage: 61106 km
Date: 2008.14.17
Time: 13:28:38
Count: 16896
Count: 4353
Count: 8268
Count: 768
Address 08: Auto HVAC (J255) Labels: 7E5-907-040.clb
Part No SW: 2H0 907 040 E HW: 2H0 907 040 E
Component: ClimatronicT5 H19 0407
Revision: 00001004
Coding: 0000000002
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: N/A
VCID: 23094C8FA2CD70B1437035-8076
No ASAM data for: "EV_ClimatronicT5"
9481748 - ROD - Unknown faultcode
Fault Frequency: 51
Reset Counter: 25
Mileage: 61106 km
Date: 2008.14.17
Time: 13:28:43
9480469 - ROD - Unknown faultcode
Reset Counter: 86
Mileage: 58972 km
Date: 2007.14.07
Time: 20:09:36
9479189 - ROD - Unknown faultcode
Fault Frequency: 18
Reset Counter: 25
Mileage: 61107 km
Date: 2008.14.17
Time: 13:30:26
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 R HW: 6R7 937 087 R
Component: PQ25 BCM H30 0570
Revision: -1------
Coding: 250002380C611400923808102C4B84D50080410E60020000300000000003
Shop #: WSC 02310 790 00104
VCID: 53E9DC4FB2EDD831935025-8006
Subsystem 1 - Part No SW: 6R0-959-802-M Labels: 6R0-959-802.clb
Component: J386__TSG_FT 002 3322
Coding: 050000
Subsystem 2 - Part No SW: 6R0-959-801-P Labels: 6R0-959-801.clb
Component: J387__TSG_BT 002 3322
Coding: 050000
Subsystem 3 - Part No SW: 1K8-951-171-A
Component: DWA-Sensor 001001 0
Subsystem 4 - Part No SW: 1K0-951-605-C
Component: LIN BACKUP HORN H05H05 1
Subsystem 5 - Part No SW: 1K8-951-171-A
Subsystem 6 - Part No SW: 6R0-959-811-D
Component: J388__TSG_HL 002 3322
Subsystem 7 - Part No SW: 6R0-959-812-D Labels: 6R-09-07.lbl
Component: J389__TSG_HR 002 3322
01326 - Control Module for Multi-Function Steering Wheel (J453)
Fault Frequency: 15
Reset Counter: 25
Mileage: 61186 km
Date: 2008.14.26
Time: 09:25:06
03156 - Sensor for Anti-Theft System (G578)
Fault Frequency: 52
Reset Counter: 65
Mileage: 61186 km
Date: 2008.14.26
Time: 09:25:07
01758 - Bulbs for Brake Lamps
007 - Short to Ground
Fault Status: 01100111
Reset Counter: 25
Mileage: 61193 km
Date: 2009.14.13
Time: 00:28:15
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00M H07 0013
Revision: --------
Coding: 00000000000000000000000000000000304D
Shop #: WSC 02739 790 50316
ROD: N/A
VCID: 3329BCCF122DE031B31085-8066
No ASAM data for: "EV_AirbaVW10BPAVN750"
Subsystem 1 - Serial Number: 3495RRB40572SIIAJODJ
Subsystem 2 - Serial Number: 3505RRB40572SIIA4PD/
Subsystem 3 - Serial Number: 3555YRB400652JMQ999T
No fault codes found.
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 6R7 937 087 R
Component: GW-K-CAN TP20 H30 0570
Revision: -1------
Coding: 742300
VCID: F0A3F3C3A3BB03290E72E2-80A5
Fault Frequency: 66
Reset Counter: 65
Mileage: 61106 km
Date: 2008.14.17
Time: 13:28:30
01324 - Control Module for All Wheel Drive (J492)
Fault Frequency: 67
Reset Counter: 25
