ELI AU
New ABS module. How do I code new module please help
buy used vw transporter no abs no communication to abs module get talk by electric abs need replace
i install it used part and now is need coding need help thanks
i scan with my Ross
Address 03,7E0 907 379 K,recoded (Long Coding),from,708724AD89A60E9924A99177A96010,to,708724AD89A60E9924A99177A96010,(02736/790/49152),
i scan with my Ross
Monday,11,January,2021,14:56:27:14564
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Dealer/Shop Name: =
VIN: WV1ZZZ7HZCH121775 License Plate: VW ABS TRANSPORTER
Mileage: 181085
Address 03: ABS Brakes Labels: 7E0-907-37x-MK25AXT.clb
Control Module Part Number: 7E0 907 379 K HW: 7E0 907 379 E
Component and/or Version: ESP MK25A XT H43 0110
Software Coding: 708724AD89A60E9924A99177A96010
Work Shop Code: WSC 02736 790 49152
VCID: 3A2DCF89EC5C179B7D6-806E
7 Faults Found:
03306 - Coding Not Valid
Reset counter: 150
Mileage: 181085 km
Date: 2032.14.29
Time: 00:44:41
Count: 16384
Count: 513
Count: 4161
Count: 758
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Fault Status: 00101100
Reset counter: 150
Mileage: 181085 km
Date: 2032.14.29
Time: 00:42:37
Count: 16384
Count: 513
Count: 32
Count: 758
Fault Status: 01101000
Reset counter: 150
Mileage: 181085 km
Date: 2032.14.29
Time: 00:42:37
Count: 16384
Count: 513
Count: 4163
Count: 758
Fault Status: 01100101
Reset counter: 150
Mileage: 181085 km
Date: 2032.14.29
Time: 00:42:37
Count: 16384
Count: 513
Count: 212
Count: 758
Reset counter: 150
Mileage: 181085 km
Date: 2032.14.29
Time: 00:42:37
Count: 16384
Count: 513
Count: 279
Count: 758
Reset counter: 150
Mileage: 181085 km
Date: 2032.14.29
Time: 00:42:37
Count: 16384
Count: 513
Count: 270
Count: 758
Reset counter: 150
Mileage: 181085 km
Date: 2032.14.29
Time: 00:42:37
Count: 16384
Count: 513
Count: 8215
Count: 758
Advanced Identification
Identification: TF7-047
Revision: 00H43001
Date: 09.04.13
Manufacturer number: 0105
Test stand number: 0005
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 2000.14.00
Flash Tool Code: 00000 000 00000
Misc.
Hardware number: 7E0 907 379 E
Workshop System Name: -----
Dataset Number:
Dataset Version:
VCDS Info:
Revision: 00H43001
Date: 09.04.13
Flash Status
Misc.
Dataset Number:
Dataset Version:
VCDS Info:
