Hi pls healp
eng.mfr
Middle East
C?ID=317341
Hi all I'm have seat leon 5f not led lights iwant activate us mode lights how and if I can do phase oppostion in turn signal pls the car 5F but not led halogen light
@eng.mfr: Hi. I assume that the "seat leon" mentioned in your post above is the same seat leon that you have referenced through-out your previous 17 x posts on this forum.
If so, then based on your historic information (I note that the BCM on your auto-scan indicates that the car has halogen headlight fittings) and more importantly, because you say "not led lights" above - I would suggest caution regarding "us mode lights" on a RoW MQB model car with incandescent turn-signal lamps.
As I'm sure that you will find if you Google the tweak, the problem with applying this tweak to non- NAR cars is that the lamp base on the turn signal lamps has a lowered power rating because they are only designed to operate at what's known as a 50% duty cycle (Google the term). This lowered rating is because turn-signal lamps are illuminated for only half the time that they operate (because they blink). If you force the lamp to illuminate for 100% of the time (in DRL mode), the lamp base can (and does) overheat and melt. So the US mode tweak is a definite no-no (alas)!!
As for your inquiry for "phase opposition in turn signal" - try this on the BCM by first entering the security code 34147:
  • Left-side turn signal lamp: access ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0. ONLY if the setting is Blinken links Hellphase, change to Blinken link Dunkelphase.
  • Right-side turn signal lamp: access ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1. ONLY if the setting is Blinken rechts Hellphase, change to Blinken rechts Dunkelphase.
