Hi.
I have a 2004 T5 Transporter. The central locking suddenly stopped working. It usually operates turning the key in any door lock (not from the key fob)
Having googled the problem, I have eliminated the notorious corroded cable that goes to the control module under the drivers seat, but it still isn't working.
I cant do a full scan on this year van. But below is the scan of the central electrics. 4 faults came up, The battery voltages must be old codes as the van has had a new battery a while ago, and after deleting the fault codes only 1 code came back which is:
Is it likely / possible that the control module itself has failed?
Thanks for any advice.
Friday,15,January,2021,10:58:49:41168
VCDS Version: Release 20.12.0 (x64) Running on Windows 8.1 x64
Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
Control Module Part Number: 7H0 937 049 H
Component and/or Version: BORDNETZ SGVER 1.0 0901
Software Coding: 0000004
Work Shop Code: WSC 02737 785 00200
VCID: 372B28B4435789B3828-513C
01598 - Drive Battery Voltage
002 - Lower Limit Exceeded
00077 - Windshield Wiper Stop Switch (F229)
