- Jan 13, 2021
- 3
- 1
- Sydney, Australia
- C?ID=428900
G'day all, just a little background to this point before I hand my house deeds to the dealer next week. I have a 09/2014 (7P6) the change over month being 08/2014 (7P5), so I want to install a tow hitch and order the correct tow module for the 7P6 only to find it's incorrect seems that my 7P6 has 7P5 wiring so exchange the tow module - install this and still have some issues with it being recognized so I pulled the RHS dash fuse panel out to check the back for issues or lack or wiring and ZAP (insert self inflicted punch to face here) I've shorted out fuse #47 on part of the metal dash and no longer have any power to instrument cluster or radio and although I haven't driven it since it appears to be in limp mode, any help really, really appreciated, although to late I have vowed to never touch any electrical in the Touareg without a battery disconnect, thanks for you patience thus far and here is the Auto scan.
many thanks - Mark
many thanks - Mark
Thursday,14,January,2021,20:10:09:17027
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WVGZZZ7PZED045533 License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 52
53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A7
17-Instruments -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
A7-Infotain. Interface -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 X41 0007
Revision: 53X41---
Coding: 292A4012236E00020000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
ROD: EV_ECM30TDI011_VW52.rod
VCID: 323D116524AB49ABB56-8066
4715 - No Communication with Instrument Cluster
U0155 00 [039] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Engine RPM: 0.00 /min
Coolant temperature: 29 °C
Intake air temperature: 28 °C
Voltage terminal 30: 11.720 V
Cruise Control System (CCS): status-Bits 0-7: 52
selected gear-Bits 0-7: 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 BQ HW: 0C8 927 750 BQ
Component: AL1000 AISIN 002 2530
Coding: 003568
Shop #: WSC 08361 002 1048576
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7CA1FF5DB66F4FDB2FA-8028
12814 - No Communication with Instrument Cluster
U0155 00 [009] - -
Reset counter: 201
Engine RPM: 0.0 /min
Transmission input speed: 0 /min
Engine torque: -60 Nm
ATF temperature: 30 °C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
EOP failure status 2: Normalcy
EOP target revolution: 0 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV 1: Motor normal stop
EOP target current: 65278 mA
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 404740010EC815
Coding: 5B6B13C34B286F58DAF9C896D2D5F650F700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4ACD6985AC3B216BED6-801E
337156 - Databus
[Steuergerät für Schalttafeleinsatz kein Signal / Kommunikation]
Reset counter: 88
Standard Freeze Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 32
337284 - Databus
U1121 00 [137] - Missing Message
Reset counter: 88
Standard Freeze Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 10
332548 - Databus
[Diagnose-Interface für Datenbus-J553 (Gateway): kein Signal/Kommunikation]
Reset counter: 88
Standard Freeze Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 59
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.CLB
Part No SW: 4H0 907 064 EM HW: 4H0 907 064 EM
Component: BCM2 2.0 H36 0521
Coding: 01B60010000000000000
VCID: 78A9E34D82D763FB4B2-802C
Subsystem 1 - Part No SW: 7P6 959 754 AL HW: 7P6 959 754 AL
Component: FBSTOUAREGIDG H08 0084
Serial number: 0514000043371011
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 0213000405915015
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.06
Time: 18:30:49
Address 06: Seat Mem. Pass (J521) Labels: NONE
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000098559801
Coding: 0038330000004201000001010101202020202121202020
VCID: 3431177DDE3F479BA7A-8060
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BR HW: 7P6 907 040 BR
Component: Klima 4 Zonen H21 1306
Coding: 36A6207ED0
VCID: 05579AB9C5A50E13404-8050
0312 - Control Module for Rear Air Blower
B10BC 31 [009] - No Signal
Reset counter: 88
0241 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 88
0516 - Positioning Motor for Left Indirect Vent Flap
B12A1 22 [008] - Signal Amplitude Too High
Reset counter: 128
0517 - Positioning Motor for Left Indirect Vent Flap
B12A1 21 [008] - Signal Amplitude Too Low
Reset counter: 128
0518 - Positioning Motor for Left Indirect Vent Flap
B12A1 07 [009] - Mechanical Failure
Reset counter: 88
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.CLB
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001872137
Coding: 26001010D1345D030021000780005D0C431D670807010241800000020000
VCID: 6C81CF1DC68FDF5BBFA-8038
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 140411 033 0021
Serial number: 90243401140416101105
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20302785
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 D HW: 7P6 941 431 D
Component: E1 - LDS H04 0031
Serial number: 00000000002604140227
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA107529000006276728
Coding: 020300
Reset counter: 88
Mileage: 1048574 km
01517 - Control Module for Trailer/Towing Sensor (J345)
Reset counter: 88
Mileage: 1048574 km
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28261411901941
Coding: 508D01
ASAM Dataset: EV_VW526ParkiAssis2 001012
ROD: EV_VW526ParkiAssis2.rod
VCID: 43D344A18B11F0232E0-8016
12670210 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation]
Reset counter: 88
12670208 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Schalttafeleinsatz-J285 - Diagnose_01.Kombi_02_alt - kein Signal/keine Kommunikation]
Reset counter: 88
Part No SW: 7P6 907 561 B HW: 7P6 907 561
Component: ACC3 H19 0340
Coding: 3E04010101
ASAM Dataset: EV_AdaptCruisContrVW526 002011
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3B233C41F3E188E3660-806E
30720 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_KOMBI]
Reset counter: 88
Control Module temperature: 35 °C
Voltage terminal 15: 11.779 V
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VDC_FAIL]
Reset counter: 88
Voltage terminal 15: 11.788 V
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 D HW: 7P0 959 655 D
Component: VW10Airbag05K H06 0026
Revision: -------- Serial number: 003L50059MCY
Coding: 00000000000000000000000000000000354B
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 42DD41A5940BF92B256-8016
Serial number: 3575LRB405V2E3MI60JV
Serial number: 3585LRB40552KAFO3GCO
Serial number: 3515RRB405B2DJEUC04L
Serial number: 3525RRB405B2DJEU8G5Z
Serial number: 3555NRB400C52JN0BPLT
Serial number: 3565NRB400C52JN0MQ8T
1048581 - Databus
[CAN: 0x5F0 Dimmung_01 Failure-value DI_KL_58d]
Reset counter: 88
1051904 - Databus
[CAN: 0x30B Kombi_01Timeout]
Reset counter: 88
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.CLB
Part No SW: 4H0 953 568 H HW: 7P6 953 507 T
Revision: -------- Serial number: 01335NDE001EJ
Coding: 000C9D
VCID: 3829234DC257A3FB8B2-806C
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0044095 TRW 20140310
Fault Status: 00101101
Reset counter: 128
Mileage: 1048574 km
Address 17: Instruments
Address 19: CAN Gateway Labels: None
Part No SW: 7P6 907 530 K HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6032
Coding: 000D07AD00
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 40D94BAD9A07EB3B332-8014
Subsystem 1 - Part No: 7P0 915 181 B
Component: Batt_Sensor
Voltage stabilizer:
Subsystem 2 - Part No: 7PP 959 663 E
Component: J532_DCDCStab
7 Faults Found:
4875 - No Communication with Instrument Cluster
U0155 00 [009] - -
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.14
Time: 17:41:39
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Control Module temperature: 55 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
5715 - Interface for Infotainment
U10B9 00 [009] - No Communication
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.14
Time: 17:41:39
Voltage terminal 30: 11.7 V
Voltage terminal 15: 11.7 V
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
5717 - Digital sound System control module
U106A 00 [009] - No Communication
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.14
Time: 17:41:39
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
5733 - Telephone Transceiver
U1058 00 [009] - No Communication
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.14
Time: 17:41:39
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
6677 - Voltage Regulator Stage 1
C10AF F1 [009] - Short to GND
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.14
Time: 17:41:39
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
0267 - Optical data bus
U1049 00 [009] - Open circuit
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.14
Time: 18:04:40
Control Module temperature: 52 °C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 128
Mileage: 122949 km
Date: 2021.01.14
Time: 18:04:28
Voltage terminal 30: 11.5 V
Voltage terminal 15: 11.5 V
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 1
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 7P6 907 049 P HW: 7P6 907 049 P
Component: Klima Fond H14 1305
Coding: 0000000000
ASAM Dataset: EV_AirCondiHeck 001007
ROD: EV_AirCondiHeck_VW52.rod
0080 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 88
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 AA HW: 7P0 907 553 AA
Component: PASM H04 1800
Revision: 00000000 Serial number: 00000141120756
Coding: 14210001
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 76B5ED758843158B59E-8022
0838 - Indicator Lamp in Operating Control for Loading-Sill Lowering
C10DA 13 [009] - Open Circuit
Fault Frequency: 88
Reset counter: 1
Mileage: 961024 km
Date: 2075.04.10
Time: 12:49:07
Default: 00
Default: 7D
Default: 00
12656664 - Databus
[CAN-Timeoutfehler Kombiinstrument]
Fault Priority: 14
Fault Frequency: 88
Reset counter: 0
Time: 00:01:03
Default: 00
Default: 89
Default: 00
12656797 - Databus
[CAN-Signalfehler CAN/CAN-Gateway]
Fault Frequency: 88
Reset counter: 0
Time: 00:01:03
Default: 00
Default: 89
Default: 00
0786 - Electical Consumer Cut-Off Active
U1402 00 [009] - -
[Spannung Fahrbatterie - Abschaltstufe aktiv]
Fault Frequency: 88
Reset counter: 0
Time: 00:00:57
Default: 00
Default: 86
Default: 00
Address 36: Seat Mem. Drvr (J136) Labels: NONE
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000098559803
Address 3C: Lane Change Labels: REDIR FAIL!
Part No SW: 7P6 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH05 0110
Revision: 00H05000 Serial number: 6PZ 010 316-01
Coding: 0001151
VCID: 7EA5F555ACF35DCB01E-802A
Subsystem 1 - Part No: 7P6 907 568
Component: J770 SWA Slave H03 0110
Subsystem 2 - Serial number: 6PZ 010 316-21
Subsystem 3 - Serial number: 5F17.04.1400H03000AMS14851ÿ
Subsystem 4 - Serial number: S14851ÿ
Reset counter: 88
Mileage: 1048574 km
Date: 2014.01.01
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.CLB
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000099653092
Coding: 011D0620DE01459205080003
VCID: 7AADF945BCDB71EB3D6-802E
Reset counter: 88
Mileage: 1048574 km
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.CLB
Revision: 00002001 Serial number: 0331882579
Coding: 011A162028B91080832006240D0000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Reset counter: 88
Mileage: 122949 km
Date: 2021.01.06
Time: 18:30:49
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.CLB
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000100026791
Coding: 011D0620DE01459205080000
VCID: 48C9538DB2B7D37BFB2-801C
Reset counter: 88
Mileage: 1048574 km
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1441800678
Coding: 01040100
Shop #: WSC 08856 002 1048576
ROD: EV_ParkbA7.rod
VCID: 36352D75C8C3558B99E-8062
Slave 3:
12656790 - Databus
[CAN-Signalfehler Kombiinstrument]
Voltage: 11.8 V
0038 - Databus
[Steuergerät PSM - Notbremsung nicht verfügbar]
Voltage: 11.8 V
12656664 - Databus
Voltage: 11.8 V
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 01AE00000F000200
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
13705477 - Databus
[Timoout Kombi_02]
Reset counter: 88
Address 56: Radio
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.CLB
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000100890187
Coding: 011804200001259005080000
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 E HW: 7P6 907 441 D
Component: TopView H05 0100
Revision: 11001001 Serial number: 82330JF0144621
Coding: 0100000001000002000102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Functional limitation by undervoltage]
Reset counter: 128
Voltage terminal 30: 7.5 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 105400102
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
VCID: 3FDB4851E7F994C34A8-806A
0046 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Reset counter: 88
Voltage terminal 30: 11.64 V
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.CLB
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000100887731
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H25 0035
Coding: E9030000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 392F2649F9DDBAF374C-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007060775_4038
0718 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Kombi_Timeout]
Reset counter: 88
Outside temperature: -37.5 °C
Voltage terminal 15: 11.6 V
Control Module temperature: 62.0 °C
Part No SW: 7P6 907 541 B HW: 7P6 907 541
Coding: 3E04010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002010
ROD: EV_AdaptCruisContr2VW526_002.rod
U1111 00 [009] - -
Reset counter: 88
Control Module temperature: 34 °C
Voltage terminal 15: 11.773 V
Velocity_vehicle_reference: -0.00 m/s
U1113 00 [009] - -
Reset counter: 88
Voltage terminal 15: 11.778 V
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H32 0035
Serial number: 005000010204147
Coding: 0AA09E000000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
VCID: 372B2071CFC9AC83828-8062
Component: RGS-VL H13 0080
Coding: 00660600031F037F00033810594097000000
Shop #: WSC 00001 790 00001
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F1E6921AD72B3CCC-8064
Component: RGS-VR H13 0080
Coding: 006606000317037F00033810594097000000
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address A7: Infotain. Interface
End----(Elapsed Time: 18:35, VBatt start/end: 11.7V/11.5V. VIgn 11.5V)-----
