Aussie VW Touareg with multiple fault codes
72mac1
Sydney, Australia
C?ID=428900
G'day all, just a little background to this point before I hand my house deeds to the dealer next week. I have a 09/2014 (7P6) the change over month being 08/2014 (7P5), so I want to install a tow hitch and order the correct tow module for the 7P6 only to find it's incorrect seems that my 7P6 has 7P5 wiring so exchange the tow module - install this and still have some issues with it being recognized so I pulled the RHS dash fuse panel out to check the back for issues or lack or wiring and ZAP (insert self inflicted punch to face here) I've shorted out fuse #47 on part of the metal dash and no longer have any power to instrument cluster or radio and although I haven't driven it since it appears to be in limp mode, any help really, really appreciated, although to late I have vowed to never touch any electrical in the Touareg without a battery disconnect, thanks for you patience thus far and here is the Auto scan.
many thanks - Mark
Thursday,14,January,2021,20:10:09:17027
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WVGZZZ7PZED045533   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 52
          53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A7
17-Instruments -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
A7-Infotain. Interface -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  X41 0007
   Revision: 53X41---
   Coding: 292A4012236E00020000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
   ROD: EV_ECM30TDI011_VW52.rod
   VCID: 323D116524AB49ABB56-8066
4715 - No Communication with Instrument Cluster
          U0155 00 [039] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Engine RPM: 0.00 /min
                    Coolant temperature: 29 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 11.720 V
                    Cruise Control System (CCS): status-Bits 0-7: 52
                    selected gear-Bits 0-7: 0
   Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
   Component: AL1000 AISIN  002 2530
   Coding: 003568
   Shop #: WSC 08361 002 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7CA1FF5DB66F4FDB2FA-8028
12814 - No Communication with Instrument Cluster
          U0155 00 [009] - -
                    Reset counter: 201
                    Engine RPM: 0.0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -60 Nm
                    ATF temperature: 30 °C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    EOP failure status 2: Normalcy
                    EOP target revolution: 0 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV 1: Motor normal stop
                    EOP target current: 65278 mA
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 404740010EC815
   Coding: 5B6B13C34B286F58DAF9C896D2D5F650F700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD6985AC3B216BED6-801E
337156 - Databus
          [Steuergerät für Schalttafeleinsatz kein Signal / Kommunikation]
                    Reset counter: 88
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 32
337284 - Databus
          U1121 00 [137] - Missing Message
                    Reset counter: 88
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 10
332548 - Databus
          [Diagnose-Interface für Datenbus-J553 (Gateway): kein Signal/Kommunikation]
                    Reset counter: 88
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 59
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.CLB
   Part No SW: 4H0 907 064 EM    HW: 4H0 907 064 EM
   Component: BCM2 2.0      H36 0521
   Coding: 01B60010000000000000
   VCID: 78A9E34D82D763FB4B2-802C
   Subsystem 1 - Part No SW: 7P6 959 754 AL    HW: 7P6 959 754 AL
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 0514000043371011
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0213000405915015
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.06
                    Time: 18:30:49
Address 06: Seat Mem. Pass (J521)       Labels: NONE
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000098559801
   Coding: 0038330000004201000001010101202020202121202020
   VCID: 3431177DDE3F479BA7A-8060
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 4 Zonen H21 1306
   Coding: 36A6207ED0
   VCID: 05579AB9C5A50E13404-8050
0312 - Control Module for Rear Air Blower
          B10BC 31 [009] - No Signal
                    Reset counter: 88
0241 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 88
0516 - Positioning Motor for Left Indirect Vent Flap
          B12A1 22 [008] - Signal Amplitude Too High
                    Reset counter: 128
0517 - Positioning Motor for Left Indirect Vent Flap
          B12A1 21 [008] - Signal Amplitude Too Low
                    Reset counter: 128
0518 - Positioning Motor for Left Indirect Vent Flap
          B12A1 07 [009] - Mechanical Failure
                    Reset counter: 88
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.CLB
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001872137
   Coding: 26001010D1345D030021000780005D0C431D670807010241800000020000
   VCID: 6C81CF1DC68FDF5BBFA-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    140411  033 0021
   Serial number: 90243401140416101105
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20302785
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002604140227
   Component: EVLS-SG  H08 0300
   Serial number: WA107529000006276728
   Coding: 020300
                    Reset counter: 88
                    Mileage: 1048574 km
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 88
                    Mileage: 1048574 km
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28261411901941
   Coding: 508D01
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43D344A18B11F0232E0-8016
12670210 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation]
                    Reset counter: 88
12670208 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Schalttafeleinsatz-J285 - Diagnose_01.Kombi_02_alt - kein Signal/keine Kommunikation]
                    Reset counter: 88
   Part No SW: 7P6 907 561 B    HW: 7P6 907 561
   Component: ACC3          H19 0340
   Coding: 3E04010101
   ASAM Dataset: EV_AdaptCruisContrVW526 002011
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3B233C41F3E188E3660-806E
30720 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_KOMBI]
                    Reset counter: 88
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 11.779 V
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 88
                    Voltage terminal 15: 11.788 V
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag05K H06 0026
   Revision: --------    Serial number: 003L50059MCY
   Coding: 00000000000000000000000000000000354B
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 42DD41A5940BF92B256-8016
   Serial number: 3575LRB405V2E3MI60JV
   Serial number: 3585LRB40552KAFO3GCO
   Serial number: 3515RRB405B2DJEUC04L
   Serial number: 3525RRB405B2DJEU8G5Z
   Serial number: 3555NRB400C52JN0BPLT
   Serial number: 3565NRB400C52JN0MQ8T
1048581 - Databus
          [CAN: 0x5F0 Dimmung_01 Failure-value DI_KL_58d]
                    Reset counter: 88
1051904 - Databus
          [CAN: 0x30B Kombi_01Timeout]
                    Reset counter: 88
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.CLB
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 T
   Revision: --------    Serial number: 01335NDE001EJ
   Coding: 000C9D
   VCID: 3829234DC257A3FB8B2-806C
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0044095 TRW 20140310
                    Fault Status: 00101101
                    Reset counter: 128
                    Mileage: 1048574 km
Address 17: Instruments
Address 19: CAN Gateway        Labels: None
   Part No SW: 7P6 907 530 K    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H13 6032
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 40D94BAD9A07EB3B332-8014
   Subsystem 1 - Part No: 7P0 915 181 B
   Component: Batt_Sensor
   Voltage stabilizer:
   Subsystem 2 - Part No: 7PP 959 663 E
   Component: J532_DCDCStab
7 Faults Found:
4875 - No Communication with Instrument Cluster
          U0155 00 [009] - -
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.14
                    Time: 17:41:39
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 55 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5715 - Interface for Infotainment
          U10B9 00 [009] - No Communication
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.14
                    Time: 17:41:39
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.7 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5717 - Digital sound System control module
          U106A 00 [009] - No Communication
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.14
                    Time: 17:41:39
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5733 - Telephone Transceiver
          U1058 00 [009] - No Communication
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.14
                    Time: 17:41:39
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6677 - Voltage Regulator Stage 1
          C10AF F1 [009] - Short to GND
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.14
                    Time: 17:41:39
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.14
                    Time: 18:04:40
                    Control Module temperature: 52 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 128
                    Mileage: 122949 km
                    Date: 2021.01.14
                    Time: 18:04:28
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.5 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049 P    HW: 7P6 907 049 P
   Component: Klima Fond    H14 1305
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck_VW52.rod
0080 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 88
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
   Component: PASM          H04 1800
   Revision: 00000000    Serial number: 00000141120756
   Coding: 14210001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 76B5ED758843158B59E-8022
0838 - Indicator Lamp in Operating Control for Loading-Sill Lowering
          C10DA 13 [009] - Open Circuit
                    Fault Frequency: 88
                    Reset counter: 1
                    Mileage: 961024 km
                    Date: 2075.04.10
                    Time: 12:49:07
                    Default: 00
                    Default: 7D
                    Default: 00
12656664 - Databus
          [CAN-Timeoutfehler Kombiinstrument]
                    Fault Priority: 14
                    Fault Frequency: 88
                    Reset counter: 0
                    Time: 00:01:03
                    Default: 00
                    Default: 89
                    Default: 00
12656797 - Databus
          [CAN-Signalfehler CAN/CAN-Gateway]
                    Fault Frequency: 88
                    Reset counter: 0
                    Time: 00:01:03
                    Default: 00
                    Default: 89
                    Default: 00
0786 - Electical Consumer Cut-Off Active
          U1402 00 [009] - -
          [Spannung Fahrbatterie - Abschaltstufe aktiv]
                    Fault Frequency: 88
                    Reset counter: 0
                    Time: 00:00:57
                    Default: 00
                    Default: 86
                    Default: 00
Address 36: Seat Mem. Drvr (J136)       Labels: NONE
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000098559803
Address 3C: Lane Change        Labels: REDIR FAIL!
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH05 0110
   Revision: 00H05000    Serial number: 6PZ 010 316-01
   Coding: 0001151
   VCID: 7EA5F555ACF35DCB01E-802A
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H03 0110
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F17.04.1400H03000AMS14851ÿ
   Subsystem 4 - Serial number: S14851ÿ
                    Reset counter: 88
                    Mileage: 1048574 km
                    Date: 2014.01.01
Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.CLB
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000099653092
   Coding: 011D0620DE01459205080003
   VCID: 7AADF945BCDB71EB3D6-802E
                    Reset counter: 88
                    Mileage: 1048574 km
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.CLB
   Revision: 00002001    Serial number: 0331882579
   Coding: 011A162028B91080832006240D0000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
                    Reset counter: 88
                    Mileage: 122949 km
                    Date: 2021.01.06
                    Time: 18:30:49
Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.CLB
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000100026791
   Coding: 011D0620DE01459205080000
   VCID: 48C9538DB2B7D37BFB2-801C
                    Reset counter: 88
                    Mileage: 1048574 km
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1441800678
   Coding: 01040100
   Shop #: WSC 08856 002 1048576
   ROD: EV_ParkbA7.rod
   VCID: 36352D75C8C3558B99E-8062
   Slave 3:
12656790 - Databus
          [CAN-Signalfehler Kombiinstrument]
                    Voltage: 11.8 V
0038 - Databus
          [Steuergerät PSM - Notbremsung nicht verfügbar]
                    Voltage: 11.8 V
12656664 - Databus
                    Voltage: 11.8 V
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AE00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
13705477 - Databus
          [Timoout Kombi_02]
                    Reset counter: 88
Address 56: Radio
Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.CLB
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000100890187
   Coding: 011804200001259005080000
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 E    HW: 7P6 907 441 D
   Component: TopView       H05 0100
   Revision: 11001001    Serial number: 82330JF0144621
   Coding: 0100000001000002000102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Functional limitation by undervoltage]
                    Reset counter: 128
                    Voltage terminal 30: 7.5 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 105400102
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   VCID: 3FDB4851E7F994C34A8-806A
0046 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 88
                    Voltage terminal 30: 11.64 V
Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.CLB
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000100887731
   Part No SW: 7P6 907 217 B    HW: 7P6 907 217
   Component: DPC-SG        H25 0035
   Coding: E9030000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 392F2649F9DDBAF374C-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000007060775_4038
0718 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Kombi_Timeout]
                    Reset counter: 88
                    Outside temperature: -37.5 °C
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 62.0 °C
   Part No SW: 7P6 907 541 B    HW: 7P6 907 541
   Coding: 3E04010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002010
   ROD: EV_AdaptCruisContr2VW526_002.rod
          U1111 00 [009] - -
                    Reset counter: 88
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 11.773 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1113 00 [009] - -
                    Reset counter: 88
                    Voltage terminal 15: 11.778 V
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H32 0035
   Serial number: 005000010204147
   Coding: 0AA09E000000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
   VCID: 372B2071CFC9AC83828-8062
   Coding: 00660600031F037F00033810594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1E6921AD72B3CCC-8064
   Coding: 006606000317037F00033810594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
Address A7: Infotain. Interface
End----(Elapsed Time: 18:35, VBatt start/end: 11.7V/11.5V. VIgn 11.5V)-----
Hi and welcome.
That scan is harder to read than it should be. Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
Thanks!
72mac1
Sydney, Australia
C?ID=428900
Hi and welcome.
Thanks!
Thanks Uwe, fixed
OK, your instrument cluster is clearly off-line, as is your 5F infotainment module. The gateway also complains that A7-Infotain. Interface is AWOL, but I don't recall seeing those in a 7P...
Do you have a wiring diagram for this vehicle?
72mac1
Sydney, Australia
C?ID=428900
Yes have EslaWin and the A7 was me will remove it next scan
You're going to have to trace through the wiring diagram and figure out why power is out to the cluster and 5F. The cluster being off-line cascades faults into numerous other modules.
