- Jan 13, 2021
- 4
- 1
- Milwaukee, WI, USA
- C?ID=382571
I replaced the OEM CCM with a third-party CCM. 2002 Jetta Wagon 1.8T. Identical part numbers, and circuit board layouts & components are, at a glance, the same.
Here are my problems. Thanks in advance for any assistance, ideas, links to solutions or next steps:
1. I changed coding from 00259 to 00258 to match the OEM, but with one push on the remote, it still unlocks all four doors instead of just the driver door. (Scan says 00259 below because I did the scan before changing that.)
2. When locking or unlocking with the remote, pushing the button ONCE, it double locks and unlocks. For example, when locking, the alarm LED on the driver door goes on, and all four lock buttons go down, and then they energize again and click even though the buttons are already down.
3. I am getting "Implausible Signal" faults from all four doors.
I'm guessing all of these things are related.
Why I replaced the CCM: Tyco v23072-c1059-a208 light relay got stuck with the right signals lit. A common enough problem, apparently. If I'd been able to simply solder in a new relay for a reasonable price, I would have done that. But with shipping, minimum order of five new relays were only $15 less than a whole new CCM. So, I replaced it with a third party module. I could put the OEM unit back in to re-scan it, or for other troubleshooting.
Wednesday,13,January,2021,20:22:36:36947
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Dealer/Shop Name:
VIN: WVWSE61J02W135xxx License Plate:
76
VIN: WVWSE61J02W135xxx Mileage: 307650km-191164miles
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 06A 906 032 HS
Component: 1.8L R4/5VT G 0006
Coding: 07500
VCID: 76B5E1DEF1DE388B59E-5184
WVWSE61J02W135xxx VWZ7Z0A3795595
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 01317 785 00200
VCID: 2B0300AA7F1C3563F60-5184
Part No: 6Q0 909 605 F
Component: 03 AIRBAG VW6 0202 0004
Coding: 12339
Shop #: WSC 01317
VCID: 3A2D35EE85469CEB7D6-5160
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V65
Coding: 07232
Shop #: WSC 02615
VCID: 2F3B14BA4E044943DA8-5160
00771 - Fuel Level Sensor (G)
01176 - Key
Part No: 6N0 909 901
Coding: 00006
VCID: 70B9D7C693BA16BB832-5160
Part No: 1C0 959 799 C
Component: Komfortgerát HLO 0004
Coding: 00259
Shop #: WSC 00222
VCID: 372B2CDAB6548183828-4B1E
Component: 1G Tõrsteuer.FS KLO 0003
Component: 1G Tõrsteuer.BF KLO 0002
Component: 1G Tõrsteuer.HL KLO 0002
Component: 1G Tõrsteuer.HR KLO 0002
27-00 - Implausible Signal
End----------(Elapsed Time: 05:04, VBatt start/end: 14.4V/14.3V)-----------
