2011 VW Jetta, ABS module Coding (MK60EC1)
Q_Sapper95
Texas, USA
C?ID=430214
Can someone please assist me in finding the correct ABS module coding for my vehicle. I have a copy of the o f the scan that I performed today, not sure how to attach it here, so that too will help. thank you ..
Wednesday,13,January,2021,11:31:10:17444
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: 3VWDX7AJ2BM339952   License Plate: NTT935
Mileage: 278880km-173287mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VWDX7AJ2BM339952   Mileage: 278880km-173287miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 A    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 8234
   Revision: T4H04---    Serial number:
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 2C010F748A0F752BFFA-8078
7 Faults Found:
               U1017 - 000 -
                    Fault Frequency: 60
                    Mileage: 277996 km
                    Date: 2015.05.05
                    Time: 00:18:20
                    RPM: 762 /min
                    Load: 26.3 %
                    Temperature: 46.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 1000.0 mbar
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low
                    Mileage: 278048 km
                    Date: 2015.05.05
                    Time: 04:20:22
                    RPM: 821 /min
                    Load: 24.3 %
                    Speed: 51.0 km/h
                    Temperature: 90.0°C
                    Temperature: 48.0°C
               U1017 - 000 -  - Intermittent
                    Fault Frequency: 20
                    Mileage: 278168 km
                    Date: 2015.05.07
                    Time: 03:44:40
                    RPM: 1011 /min
                    Load: 25.5 %
                    Speed: 33.0 km/h
                    Temperature: 47.0°C
                    Temperature: 35.0°C
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 278120 km
                    Date: 2015.05.06
                    Time: 06:12:47
                    RPM: 1581 /min
                    Load: 20.0 %
                    Speed: 78.0 km/h
                    Temperature: 88.0°C
                    Temperature: 38.0°C
008583 - Bank 1; System too Lean at Idle
               P2187 - 000 -  - Intermittent
                    Mileage: 278181 km
                    Date: 2015.05.08
                    Time: 02:03:24
                    RPM: 721 /min
                    Load: 20.0 %
                    Temperature: 60.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1010.0 mbar
000112 - Sensor for Ambient Air Temperature (G17)
               P0070 - 000 - Malfunction - MIL ON
                    Mileage: 278251 km
                    Date: 2015.05.10
                    Time: 02:29:44
                    RPM: 2266 /min
                    Load: 68.2 %
                    Speed: 113.0 km/h
                    Temperature: 87.0°C
                    Temperature: 24.0°C
000113 - Sensor for Ambient Air Temperature (G17)
               P0071 - 000 - Implausible Signal
                    Mileage: 278251 km
                    Date: 2015.05.10
                    Time: 02:29:44
                    RPM: 2266 /min
                    Load: 68.2 %
                    Speed: 113.0 km/h
                    Temperature: 87.0°C
                    Temperature: 24.0°C
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           1741
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 00598BC45607414B732-8054
            013 - Check DTC Memory
                    Reset counter: 0
                    Mileage: 83978 km
                    Date: 2013.09.26
                    Time: 22:42:08
01679 - ABS Wheel Speed Signal; Front Left
                    Fault Status: 00101101
                    Fault Frequency: 23
                    Reset counter: 198
                    Mileage: 159102 km
                    Date: 2016.04.13
                    Time: 02:59:34
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: B14B440C492508038D1422E9921B1061A70000
   Shop #: WSC 29846 004 1048576
   VCID: 78A9E32402D7098B4B2-802C
9 Faults Found:
03839 - RPM Sensor Front Left: Incorrect Signal
                    Reset counter: 138
                    Mileage: 278092 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 39
                    Count: 40192
                    Count: 64512
                    Count: 254
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Fault Status: 00100011
                    Fault Frequency: 30
                    Reset counter: 150
                    Mileage: 277996 km
                    Date: 2015.05.05
                    Time: 01:52:58
                    Count: 3
                    Count: 4608
                    Count: 35
                    Count: 51202
                    Count: 5918
                    Count: 1536
                    Reset counter: 111
                    Mileage: 278561 km
                    Date: 2015.05.19
                    Time: 01:23:57
                    Count: 3
                    Count: 12
                    Count: 12544
                    Count: 128
                    Count: 43008
                    Count: 1024
                    Count: 2045
                    Fault Status: 00101100
                    Fault Frequency: 34
                    Reset counter: 110
                    Mileage: 277996 km
                    Count: 16391
                    Count: 12
                    Count: 24832
                    Count: 32
                    Count: 44544
03306 - Coding Not Valid
                    Reset counter: 111
                    Mileage: 394242 km
                    Date: 2000.04.04
                    Time: 00:36:10
                    Count: 1280
                    Count: 159
                    Count: 26880
                    Count: 4161
                    Count: 2304
                    Count: 36609
                    Count: 32
                    Count: 28194
00003 - Control Module
                    Fault Status: 01100101
                    Fault Frequency: 9
                    Reset counter: 105
                    Mileage: 278092 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 143
                    Count: 40192
                    Count: 64512
                    Count: 254
                    Fault Frequency: 8
                    Reset counter: 72
                    Mileage: 277996 km
                    Date: 2015.05.05
                    Time: 01:59:10
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 50176
                    Count: 256
                    Count: 65531
                    Fault Status: 01101101
                    Reset counter: 102
                    Mileage: 278120 km
                    Date: 2015.05.06
                    Time: 06:12:47
                    Count: 3
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 50945
                    Count: 1019
00667 - Ambient Temperature Signal
                    Fault Status: 01101000
                    Reset counter: 76
                    Mileage: 278251 km
                    Date: 2015.05.10
                    Time: 02:29:43
                    Count: 3
                    Count: 4864
                    Count: 8259
                    Count: 50434
                    Count: 510
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AT    HW: 5C0 820 047 AT
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001333231
   VCID: 72BDD10C68AB63DB756-8026
                    Reset counter: 76
                    Mileage: 278250 km
                    Date: 2015.05.10
                    Time: 02:29:41
   Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0226
   Revision: B2066001    Serial number: 03311336100214
   Coding: 7B994B1808AB0B0000302000240884D400C2502E60000000300000000000
   VCID: 2D070270BD157C23E84-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3463
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3463
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3463
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3463
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTD08G8U.
   Coding: 00003932
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 343117145EBF2DEBA7A-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1000001TWZ0M
   Coding: 303144
   Serial number: 3572MSME3C501459ZZZW
   Serial number: 3582MSME3C412358ZZZW
   Serial number: 3516KSME1F194E0DZZZ3
   Serial number: 3526KSME112C560DZZZU
   Serial number: 3556LSME04565D0DZZZ/
   Serial number: 3566LSME4A645B0DZZZ5
9445892 - Seat occupied recognition control module
          B1022 04 [137] - Internal System Fault
                    Mileage: 277996 km
                    Date: 2020.12.11
                    Time: 21:13:49
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 111
                    Mileage: 277996 km
                    Date: 2020.12.11
                    Time: 21:14:21
   Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
   Component: KOMBI         H07 0406
   Coding: 270201
   Shop #: WSC 00066 000 00150
   VCID: 2B030C6883817213F60-807E
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 76
                    Mileage: 278250 km
                    Date: 2020.12.17
                    Time: 02:29:42
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70B9DB046AA751CB832-8024
01304 - Radio
                    Reset counter: 64
                    Mileage: 277996 km
                    Date: 2015.05.04
                    Time: 21:13:57
   Component: IMMO          H07 0406
   VCID: 6A8DC96C4CFBAB1BCD6-803E
Address 56: Radio
End----------(Elapsed Time: 01:21, VBatt start/end: 14.1V/14.1V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
what happend for the coding to be lost? do you know?
Q_Sapper95
Texas, USA
C?ID=430214
the original ABS module failed so I replaced it with a different one from the Junk Yard, the part number matches but it says that it has the wrong code. took it to the dealership and was told that the part was superseded by a new version and they no longer have the old codes. personally I think they were trying to get me to buy a 1000 part but that is just me, plus i dont have tht kind of money
iichel
Eindhoven, NB, NL
C?ID=284912
Yeah I think what the dealer is telling you is a load of crap.
anyway
try this:
113B400D49250003881402E9921B00413000
Q_Sapper95
Texas, USA
C?ID=430214
No that code did not work. It first said that is detected a change in the length. then gave me an error 12... rejected code.
Q_Sapper95
Texas, USA
C?ID=430214
that did not work either now it gives error 31 request out of range, when I add just 1 more 0 it tells me that wrong length must be the same length as original code
Q_Sapper95
Texas, USA
C?ID=430214
Now it is saying that there is NO or Basic Setting / Adaptation , not sure what this means
m87a
Bosnia and Herzegovina
C?ID=156900
after coding abs you have to do basic settings like g85, etc... often i have noticed even when you enter correct value it will reject it if you dont do basic settings like g85 at least
NostraJackAss
Vehicle Identification No.3VWDX7AJ2BM339952
ModelJetta
JEM
Date of production11.12.2010
Model year2011
Sales type162WS3
Engine CodeCBTA
Transmission CodeMAN
Vehicle class differentiation
powertrains/platform parts
7KKVehicle class differentiation -160-
Hill start assistUG1Hill start assist
Emission standard7GJEmission standard Tier2
Trailer hitch1D0Without trailer hitch
airbag4UMDriver's and front passenger air bag, NAR with front
passenger air bag deactivation (2-stage) -
SMART airbag with automatic deactivation
Activated carbon canister/gasoline
particulate filter
1E4Activated carbon canister (ORVR)
and siphoning device for fueling
Tire pressure monitoring system7K6Tire pressure monitoring system
PART NUMBERDESCRIPTIONREMARKMODEL
1K0 907 375 BGFOD PASS!Control unit for ABS
1K0 614 517 CT
1K0 614 517 DB
1K0 907 379 BG
PR:UG1+7K6
Part No SW: 07K 906 055 A HW: 07K 906 055 <<<<<<<<<<<<<<<<<<< FOD PASS!
Volkswagen
PartVersion
07K906055A8234 , 8755 , 9214, 9740
Coding: 0000075
7 Faults Found:
U1017 - 000 -
Fault Frequency: 60
Mileage: 277996 km
Date: 2015.05.05
Time: 00:18:20
RPM: 762 /min
Load: 26.3 %
Temperature: 46.0°C
Temperature: 29.0°C
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF <<<<<<<<<<<<<<<<<<<<< FOD PASS!
Volkswagen
PartVersion
09G927750LF1914
2175
2246
Coding: 0000840
Fault Frequency: 23
Reset counter: 198
Mileage: 159102 km
Date: 2016.04.13
Time: 02:59:34
Revision: 00H31001
0000000009250003001400E9901B0000000000 STRIP VIN
113B400D49250003881402E9921B0041300000 IICHLE
B14B440C492508038D1422E9921B1061A70000 <<<<<<<<<<<<<<< OP with error!
B14B440C492408FC8D1322E492201061A70000 <<<<<<<<<< START ABSTRACTS HARDWARE COMPARE NOT YOUR CODING!
B14B400C492400008D0E02ED92190042A70000 ""
DID YOU REPAIR FAULT WITH WIRING OR SENSOR/BEARING RELUCTOR & TO COMMENCE WITH ORIGINAL CODING?
ERROR FOR CODING MAY IN FACT BE ALLEGED BULLSHIT & JUST LIKE THE AFOREMENTIONED UPSELL HUH?
Q_Sapper95
Texas, USA
C?ID=430214
I got is fixed... Hank you everyone for your assistance. I had to redo the Basic Settings and it worked
NostraJackAss
Were you correct in your assumption? ;)
Please post a new complete auto-scan to show the repair is completed for data record, okay?
Hey did you or anyone else know or see there seems to be a widespread issue with these modules and this pattern behavior from forum posts, OP, ever consider an NHTSA complaint? :rolleyes:
Did you know the JPPSG has this link too?
Maybe one day there will be a fire or reimbursement by recall no?
If the second module indeed wasn't needed and you were at the dealer for them to lock it down with their proprietary algorithm for an adaption doesn't this seem unfair to you?
Question?
Was your MIL for check engine light illuminated for the ABS module?
