- Oct 20, 2020
- 7
- 5
- Long Island. NY, USA
- C?ID=423262
Hi all.. Recently turned in my 2018 Premium Plus S4 from lease and took home a 2021 S4, also Premium Plus. On the 2018, the car remembered the last setting of the heated steering wheel. On the 2021, you have to turn heated steering on every time you get in the car. Wondering if its possible to add this functionality back to the 2021.
Below is my auto-scan... Under module 16, I do see some references to personalized settings for the heated wheel, but not sure if its related to this issue:
IDE03504-MAS03692,Personalized settings-Key 1,not detected,
IDE03504-MAS03693,Personalized settings-Key 2,detected,
IDE03504-MAS03694,Personalized settings-Key 3,not detected,
IDE03504-MAS03695,Personalized settings-Key 4,not detected,
IDE03504-MAS11282,Personalized settings-Status steering wheel heater key 1,OFF,
IDE03504-MAS11283,Personalized settings-Status steering wheel heater key 2,OFF,
IDE03504-MAS11284,Personalized settings-Status steering wheel heater key 3,OFF,
IDE03504-MAS11285,Personalized settings-Status steering wheel heater key 4,OFF,
Wednesday,13,January,2021,14:05:43:09815
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WAUB4AF49MA026025 License Plate: 2
Mileage: 139km-86mi Repair Order:
Chassis Type: F4-AU49 (80B)
Scan: 01 02 03 08 09 13 15 16 17 19 32 42 44 46 52 5F 6C 74 75 81
8B A9 BB BC CA CF D6 D7 DE
VIN: WAUB4AF49MA026025 Mileage: 139km-86miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD) Labels: None
Part No SW: 8W0 907 559 S HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0002
Revision: B8H11000
Coding: 0A2A00322366010E34280000000000000000000000000000
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ECM30TFS0118W0907559S 001003
ROD: EV_ECM30TFS0118W0907559S.rod
VCID: 55F78A7C558333D3704-8000
Address 02: Auto Trans (J217) Labels:* Redir Fail!
Part No SW: 8W0 927 158 AC HW: 0D5 927 156 N
Component: 0D5 30TFSINAR H05 0002
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011_AU49.rod
VCID: 03538424EB977D636E0-8056
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 AJ HW: 8W0 907 379 N
Component: ESP9 Premium H17 0870
Coding: 1CAA149930A40A9C119E4893428252A2E5359A38280C508812424A45A7AC59
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 0D47A21CBDD33B13084-8058
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8W0 820 043 AP HW: 8W0 820 043 AP
Component: Klima Zone 3 H60 0270
Coding: 1608050D5544000D10020100080000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 015F8E2CF18B6F737CC-8054
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000005519812
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H04 0010
Serial number: A56D0D7500PAG0MUFU04
Rear A/C control head:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W1 907 063 AG HW: 8W1 907 063 G
Component: BCM1 MLBevo H10 0712
Coding: 07000363E0691CCD050D870918AC9CAB110B35440000009401010A00200016010869013B0257090000000000000000000000000000000000000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM1BOSCHAU651 017002
ROD: EV_BCM1BOSCHAU651_017.rod
Subsystem 1 - Part No SW: 8W1 955 119 A HW: 566 955 119
Component: J400FRWISCH 051 0822
Serial number: 887353F0402027301746
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 20191208X81A955555B0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AS HW: 4M0 941 531 AS
Component: E1 - LDS H07 0008
Serial number: 10 08 2020 02409832
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z00IY02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 C HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR122092023310296
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 AH HW: 4K0 947 135 AH
Component: Dachmodul H42 0416
Serial number: A00114655
Coding: 0D0104
Valve block 1 in front seat driver side:
Subsystem 7 - Part No SW: 8W0 907 182 B HW: 8W0 907 182 B
Component: J873 MKS_FSv H03 0010
Serial number: 7009137235A204156123
Coding: BF0500
Valve block 1 in front seat passenger side:
Subsystem 8 - Part No SW: 8W0 907 182 B HW: 8W0 907 182 B
Component: J872 MKS_BFSv H03 0010
Serial number: 7009137235A204156146
Coding: B30500
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 G HW: 8W0 907 561
Component: LRR4 H12 0451
Coding: B57687F258FFEC06747861A1
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_ACCBOSCHAU49X 003024
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 42DD4120B40DB46B256-8016
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 N HW: 8W0 959 655 N
Component: Airbag10.44 H09 0109
Serial number: 0030D000J7UT
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 54F177785E792ADB87A-8000
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2042
Serial number: 8W0857705M0304U00585
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2042
Serial number: 8W0857706P0301U00966
Coding: 80000D
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H12 0022
Serial number: IBH0000D20000ENBSX0+
Subsystem 4 - Part No SW: ----------- HW: 442 060 610 20
Serial number: 3577Y009D36BE4723324
Subsystem 5 - Part No SW: ----------- HW: 442 060 610 20
Serial number: 3587Y00C13648C63622-
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 210 20
Serial number: 3517700BD002E315112X
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 010 20
Serial number: 3527700AD005A8421191
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 010 20
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C90093C93329A
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 010 20
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C70093C93919E
Part No SW: 4N0 907 129 KD HW: 4N0 907 129 KD
Component: Lenks.Modul H03 0009
VCID: 7DA7F2DC8D730B93184-8028
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 790 K HW: 8W5 920 790 K
Component: FBenRDW------ H09 0159
Coding: 8BEF28C97EA8D7050280636018000B0008000800
ASAM Dataset: EV_DashBoardAU65X 002025
ROD: EV_DashBoardAU65X_002_AU49.rod
VCID: 4ACD69008C3D6C2BED6-801E
Part No SW: 80B 907 468 H HW: 80B 907 468 B
Component: Gateway H06 0506
Serial number: F0498141863601
Coding: 030300010000064054070000005900127C980001900000000100008E00000000
ASAM Dataset: EV_Gatew31xAU65x 003210
ROD: EV_Gatew31xAU65x_AU49.rod
VCID: 343117F8FEB90ADBA7A-8060
Subsystem 1 - Part No SW: 83A 951 523 L HW: 83A 951 523 L
Component: J453 MFL H07 0004
Serial number: 20201023194235 31770
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8943455605
Subsystem 3 - Part No SW: 4M8 419 508 A HW: 4M8 419 508 A
Component: J1158 KLR H10 0010
Serial number: 00000000000000060019
Coding: FFFFFF
131830 - Unknown Error Code
U1642 00 [008] - -
[Timeout_Node_0xF6_conBox_DiagAdress_0075]
Mileage: 9 km
Date: 2021.01.07
Time: 10:32:45
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605043408201207
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 79AFE6CC995B37B334C-802C
Part No SW: 4M0 959 793 M HW: 4M0 959 793 J
Component: TSG FS 010 0384
Serial number: 0000424097996
Coding: 005F8B205200108000010032
VCID: 48C9530892319E3BFB2-801C
Part No SW: 8W0 909 144 J HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0411
Coding: 0D008380008080
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 44D14738AE19BA5B17A-8010
Part No SW: 8W1 907 064 BC HW: 8W1 907 064 C
Component: BCM2 MLBevo 044 0565
Coding: 013421004FB00080650FA0002C01000203004000810426502F0400000B04803F001E0681001F11
ASAM Dataset: EV_BCM2HellaAU736 018017
ROD: EV_BCM2HellaAU736_018.rod
VCID: 7F5B08D4877F19830A8-802A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY2026019N9
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000048764183
left tail lamp 1:
Subsystem 3 - Part No SW: 8W5 945 423 A HW: 8W5 945 423 A
Component: T1 LH SAE H09 0600
Serial number: H9X1102UTV9W000020BC
Subsystem 4 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 38251359
left tail lamp 2:
Subsystem 5 - Part No SW: 8W5 945 429 A HW: 8W5 945 429 A
Component: T2 LH SAE H09 0600
Serial number: H9X1102156AW000020BJ
Right rear tail lamp 1:
Subsystem 6 - Part No SW: 8W5 945 424 A HW: 8W5 945 424 A
Component: T1 RH SAE H09 0600
Serial number: H9X1101PAV9W000020BB
Right rear tail lamp 2:
Subsystem 7 - Part No SW: 8W5 945 430 A HW: 8W5 945 430 A
Component: T2 RH SAE H09 0600
Serial number: H9X1103MF6AW000020BH
Part No SW: 4M0 959 792 M HW: 4M0 959 792 J
Component: TSG BFS 010 0384
Serial number: 0000423966674
Coding: 005F8B205E00108000010030
VCID: 47CB50349F2F9143F28-8012
Part No SW: 8W2 035 050 B HW: 8W2 035 050
Component: MU-TH-NS-US 042 3385
Serial number: GRO-63322.10.20
Coding: 14910000804220000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU27.rod
VCID: 30391BE80AA136FBC32-8064
Part No SW: 8W0 907 428 B HW: 4M0 907 428
Component: Areaview 2 H16 0107
Serial number: C854609JI005565
Coding: 02940102BA0FA10038004000
ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 002001
ROD: EV_CamSysRVAV2CE2MLBPA_002.rod
VCID: 3FDB48D4C7FFD9834A8-806A
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 T HW: 8W0 907 777 C
Component: Fahrwerk-SG H38 1215
Serial number: 3110201081
Coding: 1460484958
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 58E9834842910EBB6B2-800C
Part No SW: 4KE 035 283 A HW: 4KE 035 283 B
Component: CB_H_NAR 039 0236
Serial number: A971J0LS087670
Coding: 01E0E0F8C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X.rod
VCID: 3A2D39C0DCDDFCAB7D6-806E
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 M HW: 4M1 713 041 G
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 20101262753090
ROD: EV_GSMWaehlZFAU736.rod
VCID: 3D2732DCCDF3CB93584-8068
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 G HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 003024
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 40D94B28BA01A67B332-8014
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 M HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 201002202109
VCID: 4BC36C0483477523D60-801E
Part No SW: 4M0 959 795 M HW: 4M0 959 795 J
Component: TSG HFS 010 0384
Serial number: 0000424507603
Coding: 000F89200000108040000020
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
Component: TSG HBFS 010 0384
Serial number: 0000424507605
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 4K0 907 594 AB HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 228000049100
ROD: EV_SunRoofCONTIAU736_009_AU37.rod
VCID: 74B1D7F8BE394ADB67A-8020
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 F HW: 4M0 907 590
Component: MRR1Rear H22 0440
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
VCID: 35372AFCF5C313D3904-8060
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 4K0 941 572 DD HW: 4K0 941 572 D
Component: LMS_MLBevo H06 0040
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 73B3D4E4BB374DE37E0-8026
Address D7: Light Ctrl Right 2 (A27) Labels: None
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146) Labels:* None
Part No SW: 4K0 035 502 B HW: 4K0 035 502 B
Component: WLC Front H14 0061
Coding: 800000
ROD: EV_Charg1MobilDevicAU651_004_AU37.rod
VCID: 2019EBA85A41867B532-8074
End----------(Elapsed Time: 02:18, VBatt start/end: 12.8V/12.9V)-----------
