Wednesday,13,January,2021,18:24:41:05954
-- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
Version: 20.12.0.1 (x64) HEX-V2 : 0.4529.4
VIN: WAUZZZF24KN020992 License Plate:
Mileage: 52606km-32687mi Repair Order:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 09 15 16 17 19 2B 36 42 44 46 52 5F 6C 80 81 A5 AC
BB BC D6 D7 DE
VIN: WAUZZZF24KN020992 Mileage: 52606km-32687miles
03- Brakes -- Status: OK 0000
80-Batt. reg. aux. accum. -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFBA) Labels:. 04L-907-309-V2.clb
Part No SW: 05L 906 027 E HW: 05L 907 309
Component: R4 2.0l TDI H21 6315
Revision: E1H21---
Coding: 0A2540322524050C34082000000400000000000000000000
Shop #: 02391 785 00200
Dataset: EV_ECM20TDI01105L906027E 005003
ROD: EV_ECM20TDI01105L906027AG.rod
VCID: 2E0505EF4096315BD1E-807A
37210 - Position Sensor for Coolant Flow Control Valve
P2B60 00 [096] - Implausible Signal
Mileage: 51726 km
Date: 2020.12.19
Time: 11:24:04
Engine RPM: 0.00 /min
Coolant temperature: 16 °C
Intake air temperature: 13 °C
Voltage terminal 30: 12.600 V
Unlearning counter according OBD: 9
Coolant temperature sensor 1: B1: on cylinder head: raw value: 16.5 °C
Engine temp. mangmt. actuator: specified value of angle: 38.79 %
Engine temp. mangmt. actuator: actual value of angle: 100.00 %
Engine temperature management actuator: specified value: 120.31 %
Engine temp. management actuator: raw value: 4405.2
Heater support pump 1 bank 1 primary circuit: activation: 38.87 %
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 153 AB HW: 0HK 927 156 B
Component: 0CK 20TDI H01 0004
Revision: --H01--- Serial number: 0000001297
Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 6D87C2E38D108A43A84-8038
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180190002374
Address 03: Brakes (J104) Labels: None
Part No SW: 4K0 907 379 M HW: 4K0 907 379 A
Component: ESP9 Plus H06 0850
Coding: 0CAA499714A40A9611A7489A007FD2D2F5B9C0309228508812004B4BAF9D03
Dataset: EV_ESP9BOSCHCMP 004011
ROD: EV_ESP9BOSCHCMP_004_AU65.rod
VCID: 3FDB48AB97FCC8D34A8-806A
420352 - Warning; Front Left Tire
C1054 00 [032] - Pressure too Low
416768 - Warning; Front Right Tire
C1056 00 [032] - Pressure too Low
420096 - Warning; Rear Left Tire
C1058 00 [032] - Pressure too Low
417024 - Warning; Rear Right Tire
C105A 00 [032] - Pressure too Low
419584 - Warning; Rear Left Tire
C1059 00 [032] - Flat
419840 - Warning; Rear Right Tire
C105B 00 [032] - Flat
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0652
Coding: 07000143C13900CD074C87081FAF8C68130B3310000600970101080039321C810A45093242560508000001000001001A0000000000010100000000000000000000
Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 76B5ED8FF846499B59E-8022
Subsystem 1 - Part No SW: 4K2 955 119 HW: 4K2 955 119
Component: J400FRWISCH 063 0730
Serial number: 00000001804200401893
Coding: 7DC727
Serial number: 21666024X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K2 941 501 HW: 4K2 941 501
Component: E1 - LTM H05 0053
Serial number: 16S24.07.1800300470
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE117051823610951
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 B HW: 4K0 947 135 B
Component: Dachmodul H42 0413
Serial number: C00058509
Coding: 0D0104
66887 - Databus
[Left LED headlamp power output module: high beam faulty]
Fault Frequency: 95
Reset counter: 155
Mileage: 44805 km
Date: 2020.10.22
Time: 07:07:29
average_Voltage_terminals: 13.20 V
Outside air temperature sensor-Outside air temperature on CAN: 10.50 °C
interior_temperature: 24.50 °C
Vehicle speed: 58.24 km/h
66888 - Databus
[Right LED headlamp power output module: high beam faulty]
Reset counter: 158
Mileage: 44839 km
Date: 2020.10.22
Time: 18:10:03
average_Voltage_terminals: 14.20 V
Outside air temperature sensor-Outside air temperature on CAN: 11.50 °C
interior_temperature: 27.50 °C
Vehicle speed: 61.66 km/h
Address 15: Airbags (J234) Labels:* None
Part No SW: 4N0 959 655 J HW: 4N0 959 655 J
Component: AirbagVW31 H01 2710
Serial number: 003YTM0075M-
Coding: AACCF0C00CC00000985400FFF08D40AC00C5
Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x.rod
VCID: 43D3445BFB14AC332E0-8016
Subsystem 1 - Part No SW: ----------- HW: 480 001 907 18
Serial number: 357000000002A854C23I
Subsystem 2 - Part No SW: ----------- HW: 480 002 307 18
Serial number: 3580000000020488E23E
Subsystem 3 - Part No SW: ----------- HW: 480 030 507 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C103B3A040983V
Subsystem 4 - Part No SW: ----------- HW: 480 030 507 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C103B36D307F10
Subsystem 5 - Part No SW: ----------- HW: 480 031 407 18
Component: FrontSensor_D 002 0149
Serial number: 355001C14E8B8C00A8FV
Subsystem 6 - Part No SW: ----------- HW: 480 031 407 18
Component: FrontSensor_P 002 0149
Serial number: 356001C14E8B8E001FAR
Subsystem 7 - Part No SW: ----------- HW: 480 031 407 18
Component: PedP_Sensor_C 002 0149
Serial number: 230001C14F2C0D605A66
Subsystem 8 - Part No SW: ----------- HW: 480 001 507 18
Serial number: I0M00000000E578D51BI
Subsystem 9 - Part No SW: ----------- HW: 480 001 507 18
Serial number: I0N00000000A96F060BC
Part No SW: 4N0 907 129 S HW: 4N0 907 129 S
Component: Lenks.Modul H03 0005
Dataset: EV_SMLSKLOAU736 007012
ROD: EV_SMLSKLOAU736_AU58.rod
VCID: 41DF4E53E108BE233CC-8014
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 790 C HW: 4K0 920 790 C
Component: FBenRDWACC--- H11 0153
Coding: A4A420C2688006000140E160B080080008001000
Dataset: EV_DashBoardAU65X 001017
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2D0702E34D904A43E84-8078
Part No SW: 4N1 907 468 AB HW: 4N1 907 468 AB
Component: Gateway H14 0036
Revision: 8N020004 Serial number: 0488N843418724
Coding: 02010005002086405A860002005B0132C81A000710000000097D078E10000000
Dataset: EV_CGateCONTIAU491 003150
ROD: EV_CGateCONTIAU491_003_AU58.rod
VCID: 78A9E3B7F2523FEB4B2-802C
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 741863110018071206E2
528129 - Databus
[NVEM_BMS_NV_01_Timeout_Failure]
Reset counter: 160
Mileage: 44739 km
Date: 2020.10.21
Time: 09:34:31
48V activation restriction-Airbag control module: not active
48V activation restriction-Engine Electronics: not active
48V activation restriction-Roll stabilization: not active
48V activation restriction-48 V activation restriction due to open circuit: not active
48V activation restriction-48 V activation restriction due to deactivation: not active
48V activation restriction-Battery management 2: not active
48V activation restriction-Voltage converter: not active
48V activation restriction-Auxiliary Air Heater Control Module/: not active
48V activation restriction-Electrical compressor: not active
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 18000214865010
Coding: 8800000000000000
Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW53.rod
VCID: 34311787AEBA1B8BA7A-8060
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000334339096
Coding: 007812400000B4010003010101010000000000000000000000000000004000
Dataset: EV_SCMDriveSideCONTIAU736 006009
ROD: EV_SCMDriveSideCONTIAU736_AU38.rod
VCID: 79AFE6B3C95826E334C-802C
Part No SW: 4M1 959 593 D HW: 4M1 959 593 D
Component: FS001 0188
Serial number: YE007RG60810D
Coding: 001FDA0052010400A000B002
Dataset: EV_DCU2DriveSideMAXHKLO 001010
VCID: 3E2535AF90F6C1DB41E-806A
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: 94002101010000
Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313F1E9351A82EA3CCC-8064
Part No SW: 4N0 907 064 BB HW: 4N0 907 064 B
Component: BCM2 MLBevo H14 0145
Coding: 013500002FB000406309A0000400000203030000804302502F04000000040030001F0100000001
Dataset: EV_BCM2CONTIAU651 008007
ROD: EV_BCM2CONTIAU651_008_AU58.rod
VCID: 70B9DB979A2267AB832-8024
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1817916DV
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099181418
Rear spoiler control module:
Part No SW: 4M1 959 592 D HW: 4M1 959 592 D
Component: BFS001 0188
Serial number: YE007RF712096
Coding: 001FDA005E010400A000B000
Dataset: EV_DCU2PasseSideMAXHKLO 001010
VCID: 3D2732A39DF0DAC3584-8068
Part No SW: 4K0 035 063 D HW: 4K0 035 063 A
Component: MU-H-LND-EU 046 2711
Coding: 01850101FF0A000043111101C00800302F0001E601F00800CE
Dataset: EV_MUHigGen2pALPI 001001
VCID: 2411E7C71E5A8B0B37A-8070
Multimedia System 1:
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00122061800060192
Compact disc data bank:
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000124042031
Multimedia System 5:
Subsystem 5 - Part No SW: 4K2 919 603 B HW: 4K2 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00113061800090806
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800441906007
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0285010102002001C20040
Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
VCID: 3333149BABB41CB3BE0-8066
Address 80: Batt. reg. aux. accum. (A1) Labels: None
Part No SW: 4K0 915 101 HW: 4K0 915 101
Component: MQ-BMS H20 0126
Serial number: 18000014519003
Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
VCID: 6099ABD74AC2D72B132-8034
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4K2 713 041 H HW: 4K2 713 041 H
Component: GSM-LL H14 0050
Serial number: 18.201 40182
Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 290FF6F37978566304C-807C
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AA HW: 4N0 907 107 F
Component: zFAS Var A H08 0291
Coding: 04C18600000000000000060000400424189D5600000000000000000000000000001900000000000000000000000000000000000000000000000080000000000000007818008000B000000000000000000080400000B0
Dataset: EV_ZFASAU516 001005
ROD: EV_ZFASAU516_001.rod
VCID: 7EA5F5AFD07601DB01E-802A
2114856 - Databus
[LED_Feh_LM_L_03_LED_L_Zus_Fernl_LH_Def]
Fault Frequency: 9
Reset counter: 151
Mileage: 45538 km
Date: 2020.10.24
Time: 01:25:18
221284 - Front Camera for Driver Assist Systems
C12B3 FD [008] - View Temporarily Restricted
[temp view limitations]
Fault Frequency: 17
Reset counter: 135
Mileage: 47289 km
Date: 2020.10.25
Time: 13:51:58
EyeQ temperatures-CPU: -40 °C
EyeQ temperatures-VPM: 35 °C
Vehicle speed: 145.09 km/h
Front camera: blinding detection-Status: not active
Front camera: blinding detection-Blinding detected by light assistance assessment module: No
Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
Front camera: blinding detection-Blinding detected by object recognition assessment module: No
Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
Front camera: blinding detection-Glare detected: No
Front camera: blinding detection-free view detected once: Yes
Address AC: Reductant Control (J880) Labels: None
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H07 0004
Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C010FE7768A434BFFA-8078
Part No SW: 4M1 959 595 D HW: 4M1 959 595 D
Component: HFS003 0188
Serial number: YE007RGB33194
Coding: 000FD80000010400A000B000
Dataset: EV_DCU2RearDriveMAXHKLO 001010
ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
VCID: 40D94B57EA02B72B332-8014
Component: HBFS003 0188
Serial number: YE007RGB31155
Dataset: EV_DCU2RearPasseMAXHKLO 001010
ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 4K0 941 572 DC HW: 4K0 941 572 D
Component: LMS_MLBevo H05 0030
Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 72BDD19F942E55BB756-8026
2338 - Light Bulb for High Beam
C1199 11 [008] - Short to Ground
Fault Frequency: 208
Reset counter: 155
Mileage: 44800 km
Date: 2020.10.22
Time: 07:04:16
4130 - Bulb for Aux. High Beam
C1261 11 [008] - Short to Ground
Reset counter: 133
Mileage: 45538 km
Date: 2020.10.24
Time: 01:25:18
Address D7: Light Ctrl Right 2 (A27) Labels: None
Dataset: EV_LMSRightHELLAAU58X 001013
Reset counter: 158
Mileage: 44798 km
Date: 2020.10.22
Time: 07:03:01
Address DE: Charger 1 for mobile dev (J1146) Labels:* None
Part No SW: 4K0 035 502 A HW: 4K0 035 502 A
Component: WLC Front H10 0061
Coding: 400000
Dataset: EV_Charg1MobilDevicAU651 004001
ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
VCID: 1F1BE82B373CA8D36A8-804A
End----(Elapsed Time: 01:48, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
