Tuesday,12,January,2021,11:50:24:33238
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: 3VWTL71K89M263079 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 62 72
VIN: 3VWTL71K89M263079 Mileage: 288110km-179023miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 N HW: 03L 906 022 J
Component: R4 2,0L EDC G000SG 8680
Revision: 12H01--- Serial number: VWX7Z0H524I095
Coding: 0050072
Shop #: WSC 84224 299 591528
VCID: 3D273EB08179B383584-8068
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
Mileage: 287778 km
Time: 11:59:40
RPM: 2530 /min
Speed: 132.0 km/h
Load: 32.2 %
Absolute Pres.: 1591.2 mbar
Absolute Pres.: 1999.2 mbar
Lambda: 33.9 %
Lambda: 33.9 %
Readiness: 0 1 0 0 1
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B400D492700FE880C02E9921D00423000
Shop #: WSC 41669 001 104857
VCID: 7EA5F9BCC0FF689B01E-802A
Reset counter: 168
Mileage: 285096 km
Count: 32768
Count: 4608
Count: 294
Count: 51534
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 70B9D78486AB0EEB832-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009264211
Coding: 10018E234004100007140000001400000008730B5C000120000000000000
Shop #: WSC 53316 000 1048576
VCID: 323D1D8C48277CFBB56-8066
Component: Wischer 190309 021 0501
Coding: 00038805
Shop #: WSC 53316
01501 - Bulb for Blinkers; Rear Left (M6)
Fault Status: 00101100
Fault Frequency: 8
Reset counter: 144
Mileage: 285534 km
Voltage: 14.15 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7I0532598
Coding: 0000102
Shop #: WSC 00066 000 00000
VCID: 33331888B73D75F3BE0-8066
00003 - Control Module
Fault Status: 00101110
Reset counter: 6
Mileage: 36521 km
Time: 14:55:18
Reset counter: 61
Mileage: 273981 km
Time: 22:31:25
01304 - Radio
Fault Frequency: 24
Reset counter: 122
Mileage: 286667 km
Time: 17:17:52
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 2U AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08Y5PW
Coding: 0012885
VCID: 6D87CEF09199E303A84-8038
Subsystem 1 - Serial number: 6332MSME43511211W
Subsystem 2 - Serial number: 6342MSME4454272FF
Subsystem 3 - Serial number: 6351HSME1C0C494FO
Subsystem 4 - Serial number: 6361HSME1B790871C
Subsystem 5 - Serial number: 63727SME1B74466BA
Subsystem 6 - Serial number: 63827SME1B751E617
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0000331
VCID: 76B5E19CE4CF20DB59E-8022
Component: E0221 002 0010
Part No SW: 1K0 920 874 D HW: 1K0 920 874 D
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I224B0EN
Coding: 0023303
VCID: 2E0509FC5C1F581BD1E-807A
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 180209F2001694
Coding: E9807F06001102001002
Shop #: WSC 00066 123 12345
VCID: 372B2C98A34599D3828-8062
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T413504
Coding: 0000003
VCID: 392F2AA095518FA374C-806C
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000805689208
Coding: 0001205
VCID: 6FBBD4F89B9511139A8-803A
Fault Status: 00100101
Reset counter: 154
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 01101100
Reset counter: 140
Mileage: 273981 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0D05EC60F7343B0D6-807E
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 13900F880106281B0904058FB0880F0488FC00
Shop #: WSC 03285 999 14509
VCID: 71BFD2808DA107E38CC-8024
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08120722582603
Coding: 0001204
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003800031
Coding: 0001168
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003874453
Coding: 0001168
VCID: 77ABEC98E3C559D3428-8022
End----------(Elapsed Time: 01:18, VBatt start/end: 13.9V/14.1V)-----------
I have been plagued with the 000564 - Boost Pressure Regulation, P0234 - 000 - Limit Exceeded (Over boost Condition) - Intermittent code for quite some time and I'm starting
to do quite of bit of higher speed driving as of late which is what tends to set this code so I would like to take care of this sooner than later.
It doesn't seem to cause an issue until I am going over 70 MPH and holding a steady speed up a steeper hill or incline. At that point it goes into limp mode and all power is lost and I have to cycle the key to get it out of limp mode and get any power back.
I have done a graph of this and caught it in the action. I have a screenshot of this and will try and figure out how to post it to this thread.
If I go up the same hill under full throttle it will max out the boost at 2300 Mbar and holds a steady boost level with gobs of power and no limp in mode
So I should mention the car has a Malone stage 2 tune with the DPF delete. I also replaced the turbo actuator unit with an aftermarket one about 8 months ago.
When I look at measuring blocks 120-4 with the engine idling its reading .608 volts and with the key on engine off its reading 4.104 volts. I do remember setting this with the adjustment on the turbo actuator rod when I replaced it.
The voltage with the engine off had specified it should be at 3.75 volts. Its a bit high, is that a concern?
I am fully prepared to pull the turbo off this weekend and clean out the variable vanes and file any burrs off them to try and remedy the over boost condition, as I feel at this point this is where the problem lies. I had just wanted to post this to
see if there is something you guys think I might be overlooking.
