I just acquired a new to me 2017 Audi S7, which is still covered by the original factory warranty for another year. I see no warning lights on the dashboard, and as far as I can tell all the systems are currently functioning, though I have not yet been able to verify the active lane assist functionality.
I ran a VCDS AutoScan this morning and it revealed several faults in a few different modules, and I was wondering if any of the errors are concerning enough to warrant a service appointment. Since the car is currently under warranty I would of course like to address as many issues/faults as I can before the warranty runs out, but I have also owned enough Audi's to know that if a mosquito lands on the hood it can throw off a sensor or two in the car.
Ca you please review the AutoScan below and let me know your thoughts. Thank you very much in advance!
Wednesday,13,January,2021,09:56:37:08798
VCDS Version: 20.4.2.0 (x64)
VIN: WAUWFAFCXHN120*** License Plate:
Mileage: 64984km-40379mi Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
44 46 52 53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 BA
VIN: WAUWFAFCXHN120*** Mileage: 64984km-40379miles
Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0002
Revision: NCH63---
Coding: 1A2500326546010E3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
ROD: EV_ECM40TFS0114G0906014D.rod
VCID: 2345D40B2AF7A69E2E-8076
18742 - Control Module for Exhaust Flap
P14AB 00 [096] - Mechanical Malfunction
Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H06 0007
Revision: --H06---
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 306F2B476B010D06A3-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 65BED44BA67D2BD21B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41897E83D0AB948E5C-8014
36352 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Mileage: 64542 km
Date: 2020.12.16
Time: 14:58:32
VzRef: 00
Bit Info 1: C0
Bit Info 2: 0F
Bit Info 3: 22
Bit Info 4: 1F
Uz: 70
Unlearning counter according OBD: 22
168448 - ASR and ESP Switch
C109C 29 [040] - Signal Implausible
Mileage: 64963 km
Date: 2021.01.12
Time: 13:28:57
VzRef: 00
Bit Info 1: C0
Bit Info 2: 48
Bit Info 3: 26
Bit Info 4: 1F
Uz: BA
161792 - Tire Pressure Warning
C102D 00 [040] - -
Mileage: 64609 km
Date: 2021.01.06
Time: 14:31:23
VzRef: 66
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: BC
Unlearning counter according OBD: 27
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0825
Coding: 0DAA6F4E000000000000
VCID: 000FBB8793215D8613-8054
Serial number: 3217000042766012
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 02041700040296
Coding: 680330784D0000
VCID: 6ADBF92F8D5DB7D6AD-803E
Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0368
Revision: 2102003S Serial number: 00001629742102
Coding: 01050011043C9FF2F90048C780007800CF9CC208AE0802218000089C710017020060002D0B0000
VCID: 79F9D663F0FB0C4E54-802C
Component: WWS57X 170226 H38 0080
Serial number: 170308085335
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20172789X81A955547A0
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 30 03 2017 00000737
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02D0F73F
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA126936000030664580
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: E4E90F9800PAG0MUFU03
Component: ACC3 H21 0055
Coding: 7E01010101
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
VCID: 2959C62348DB7CCE64-807C
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 183
Mileage: 64542 km
Date: 2020.12.16
Time: 14:58:33
Control Module temperature: -6 °C
Voltage terminal 15: 10.866 V
140288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 183
Mileage: 64542 km
Date: 2020.12.16
Time: 14:58:34
Voltage terminal 15: 14.022 V
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0092
Revision: -------- Serial number: 003G0003Z4W7
Coding: 303331333131303134334A55304C34473853
VCID: 346727579F193126C7-8060
Component: BF-Gewichtss. H15 0046
Serial number: 6940000Y170001L5TA0+
Serial number: 3575HRB406344NL6CP8J
Serial number: 3585HRB406344NL6196Y
Serial number: 3515JRB400G59FV0IHKY
Serial number: 3525JRB400O59FV0A1ML
Serial number: 3554VRB401A59HKIQPJP
Serial number: 3564VRB401A59HKIFOOJ
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372QD20003V
Coding: 0000FC
VCID: 377D105B866FDA3EE2-8062
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 09 03 2017 D0020535
Part No SW: 4G8 920 988 M HW: 4G8 920 988 M
Component: TBenUsaAccNv H15 0225
Revision: 15001309 Serial number: 658300317596032
Coding: 0BC70107BF53D705020300
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 44877797CFB981A677-8010
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Revision: -------- Serial number: 00000002571458
Coding: C0ED074814
VCID: 3D710273AC53F06E38-8068
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 1565543404
Voltage stabilizer:
Serial number: 17011500000000000080
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0E0100
VCID: 3A7B096FB57DC7561D-806E
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04018E64747464545425363E00
VCID: 67DD801B964F8ABEB2-8032
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 003003170001003
VCID: 285FC32753D145C67B-807C
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 03041700040824
Coding: 20
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008006
ROD: EV_AirSuspe_VW51.rod
VCID: 2F6D283B763F12FEBA-807A
C10C8 00 [008] - -
Reset counter: 193
Mileage: 64525 km
Date: 2020.12.04
Time: 14:05:02
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000247417794
VCID: 77FDD05BC6EF1A3E22-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02R6Y+
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 377D105B8E6FDA3EE2-8062
Component: SWA Master H08 0070
Serial number: 0437059314
Coding: 040211
VCID: 39791663B87BCC4E14-806C
Lane Change Assistant 2:
Component: SWA Slave H08 0070
Serial number: 0423176046
Coding: 040211
Component: TSG FA H04 0511
Coding: 011F57035E00628002000413
VCID: 45816A93CC83B8AE60-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000689383
Coding: 011001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A7B096FBD7DC7561D-806E
Revision: 00002001 Serial number: 0437274633
Coding: 0126063A20BAF08580B00A8402030D470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000391843
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST001IYUMX00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00031816354
Subsystem 5 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
Component: HSP-SG H11 0031
Serial number: WA126937000030667294
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 66002;2;
03976 - Control Module for Rear Lid/Hatch Opening: Play Protection Active
Reset counter: 185
Mileage: 62799 km
Date: 2020.09.29
Time: 18:30:29
Component: TSG BF H03 0511
Coding: 011F57035E00628002000402
VCID: 46836D9FF185B3B669-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002155125
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 326B214F650D3F16D5-8066
Component: MxB-ECU 001 0100
Coding: 05FA0A1122600400
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E02000
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E02000
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 D HW: 4G1 035 025 C
Component: MU-H-LNS-US 053 0902
Serial number: A741C0H7535032
Coding: 017553020000000013220002041A00102F000DE5F17001047E
VCID: 1F4DD8FB069F827E0A-804A
Subsystem 1 - Part No SW: V03 959 802 DK HW: -----------
Component: NAR 2018/2019 --- 0066
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY807KUV
Multimedia Operating Unit:
Serial number: 90349QCO000EG
Compact Disc Database:
Component: Gracenote2--- --- 3011
Component: TSG HL H03 0511
Coding: 010F17024000628002000002
VCID: 499966A3E09B5CCE84-801C
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0380
Revision: 11001001 Serial number: 82330JG0391892
Coding: 0217000101010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Part No SW: 4G8 959 107 T HW: 4G8 959 107 J
Component: HDSG-Modul H14 0049
Revision: 12014001 Serial number: 077701998
Coding: 0A3305C122
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 46836D9FF985B3B669-8012
Component: TSG HR H03 0511
Component: DPC-SG H28 0081
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C573F37472969E69F-8078
Coding: 7E01010101
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
VCID: 275DC01B5ECF4ABE72-8072
U1113 00 [008] - -
Reset counter: 183
Mileage: 64542 km
Date: 2020.12.16
Time: 14:58:33
Control Module temperature: -4 °C
Voltage terminal 15: 10.830 V
Velocity_vehicle_reference: -0.00 m/s
U1113 00 [008] - -
Reset counter: 183
Mileage: 64542 km
Date: 2020.12.16
Time: 14:58:34
Control Module temperature: -5 °C
Voltage terminal 15: 14.123 V
Component: BV-SG H34 0090
Serial number: 005002453103177
Coding: 03C1BA1B0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 183
Mileage: 64542 km
Date: 2020.12.16
Time: 14:58:33
Outside air temperature: -3.0 °C
Voltage terminal 15: 10.9 V
Control Module temperature: 0.0 °C
Component: RGS-VL H16 0080
Coding: 0066E608031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 31692E43600B040EAC-8064
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 170225200732
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813008212801
ROD: EV_AEMLearAU64X.rod
End-------------------------(Elapsed Time: 06:58)--------------------------
