- Jul 5, 2019
- 48
- 3
- Kuala Lumpur, Malaysia
- C?ID=345326
I need some help to read the wiring diagram. My right headlight cornering light is always on instead of turning on only when I turn the steering wheel to the right. In its always on condition it put out a lot of heat that I can feel the intense heat on the headlight cover. Because of this I've disconnected the cornering light and this has caused the DRL to die as well. I'm trying to find out the cause of the always on condition for the cornering light. I did a vcds scan and got faults at 2 different addresses.
A few in Address 09 Central Electrics (J519) i.e :
1.Supply Voltage for LED Module for DRL and Parking Light; Left and Right
2.Lamp for Low Beam; Left (M29) and Right (M31) - Electrical Fault in Circuit
3.Bulb for Blinkers; Front Left (M5) and Right (M7) - Electrical Fault in Circuit
4. Control Module for Headlight Range (J431) - Implausible Signal, Check DTC Memory
and the other few in Address 55 Headlight Range (J431) :
1.Adjusting Motor for Variable Lighting Right - Short to Ground
2.Function Restriction due to Implausible Message
3.Positioning Motor for Headlight Range Right - Short to Ground
4.Power Output Module for Right Headlamp - No Signal
5. Positioning Motor for Dynamic Cornering Light Right - Short to Ground
I cannot access the headlight through vcds to carry out the output test at address 55 headlight range control as vcds states "refused by the controller". My right main beam now is pointing to extreme right and my left main beam is pointing downwards apart from the problem stated earlier.
I got the wiring diagram below want to try to understand where the short to ground can occur. The motor for the headlight range motor V49 and dynamic cornering light V319 are in the diagram but I cannot find the motor for the variable lighting.
The full scan:
The full scan:
Wednesday,30,December,2020,22:49:26:34670
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WAUZZZ4G9BN031310 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310 Mileage: 184703km-114769miles
Address 01: Engine (J623-CGWB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 HW: 4H0 907 551
Component: 3.0l V6 TFSI H05 0007
Revision: --H05---
Coding: 0A250034052701020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551 002010
ROD: EV_ECM30TFS0214G0907551_002.rod
VCID: 6695B5FFE8EFBBDBE9F-8032
6368 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
P0018 00 [032] - Incorrect Correlation
Mileage: 183937 km
Date: 2020.12.01
Time: 21:30:18
Engine RPM: 703.00 /min
Normed load value: 20.0 %
Coolant temperature: 95 °C
Intake air temperature: 72 °C
Ambient air pressure: 860 mbar
Voltage terminal 30: 13.405 V
Unlearning counter according OBD: 15
Engine speed: actual: 704 /min
MAF_ENVD: 136.17647 mg/stroke
Calculated oil temperature: 85
Engine: operating status: IS
ENVD_CAM_IN_2: 0
Battery voltage: 13.406250 V
Part No SW: 4G0 927 156 M HW: 0B5 927 156 F
Component: 0B5 30TFSIRdW H10 0024
Revision: --H10--- Serial number: 0000000785
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 363525BFF8CF0B5B99F-8062
8040 - Torque Restriction due to Clutch Temperature
P17D8 00 [032] - -
Reset counter: 18
Mileage: 184138 km
Date: 2020.12.04
Time: 11:55:01
Engine RPM: 1558 /min
Transmission input speed: 1558 /min
Transmission output speed: 603 /min
Engine torque: 164 Nm
ATF temperature: 91 °C
Accelerator pedal position: 27.2 %
Clutch status: Kupplung 2 kann Moment übertragen
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Coding: 44A687002265E100DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 6E85CDDFC01F739B91F-803A
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H24 0217
Coding: 05B82F00000000000000
VCID: 77ABE8BBBFC53253429-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000097450009
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 25
Mileage: 183937 km
Date: 2020.12.01
Time: 21:31:37
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 72
Mileage: 184208 km
Date: 2020.12.05
Time: 11:13:40
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0056
Serial number: 06051100040574
Coding: 6621007824
ASAM Dataset: EV_AirCondiComfoUDS 002029
VCID: 270BF8FB2F6562D3129-8072
0378 - Coolant Circulation Pump
B10D0 04 [008] - Internal System Fault
Fault Frequency: 29
Reset counter: 89
Mileage: 183937 km
Date: 2020.12.01
Time: 21:30:46
Voltage terminal 30: 13.96 V
Outside temperature: 40.0 °C
Inside temperature: 24.46 °C
0379 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 01 [009] - Electrical Failure
Fault Frequency: 42
Reset counter: 49
Mileage: 183937 km
Date: 2020.12.01
Time: 21:30:47
Part No SW: 4H0 907 063 N HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0092
Revision: 20012002 Serial number: 00000001044197
Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
VCID: 33331CABEB3D1E73BE1-8066
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels:
1KX-955-119.CLB
Component: WWS57X 110404 H35 0051
Serial number: 110407090850
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels:
8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11418017
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 22 04 2011 00000235
Component: AQ_Hum_Sensor H02 0002
Serial number: 5228C6A5000000000001
8 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 00101100
Reset counter: 90
Mileage: 184700 km
Date: 2020.12.15
Time: 11:09:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Status: 01101100
Reset counter: 49
Mileage: 184700 km
Date: 2020.12.15
Time: 11:09:00
Reset counter: 90
Mileage: 184703 km
Date: 2020.12.15
Time: 11:20:00
Reset counter: 89
Mileage: 184703 km
Date: 2020.12.15
Time: 11:20:00
Reset counter: 90
Mileage: 184702 km
Date: 2020.12.15
Time: 11:15:00
Reset counter: 89
Mileage: 184700 km
Date: 2020.12.15
Time: 11:12:00
Fault Status: 01101000
Reset counter: 43
Mileage: 184596 km
Date: 2020.12.12
Time: 14:14:00
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 25
Mileage: 183937 km
Date: 2020.12.01
Time: 21:30:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55901107004778
Coding: 300306
Shop #: WSC 00097 210 98728
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 392F2E83C9D1E42374D-806C
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG002BRPH
Coding: 30323436313330303631554A305234473053
Serial number: 3575HRB404T0HM766GDR
Serial number: 3585HRB405H0H0LUC8R2
Serial number: 3515JRB405D0H4DU9P4N
Serial number: 3525JRB405F0G944N0G$
Serial number: 3554VRB40630GR36HOS5
Serial number: 3564VRB405D0GR36IHD.
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110505000939
Coding: 000034
VCID: 303913A71A2B256BC33-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Part No SW: 4G8 920 981 A HW: 4G8 920 981 A
Component: TBenGb H34 0312
Revision: 19100074 Serial number: 658020411593026
Coding: 33A709000B012600010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 313F16A311A12C63CCD-8064
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000141378
Coding: 00CD073000
ROD: EV_GatewUDS_AU57.rod
VCID: 303913A71AAB256BC33-8064
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650387009
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11130001538021200181
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0056
Serial number: 06051100040012
Coding: 02
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
VCID: 2F3B10DB07953A93DA9-807A
0034 - Motor for Rear Right Upper Body Vent
B10D4 21 [008] - Signal Amplitude Too Low
Fault Frequency: 8
Reset counter: 86
Mileage: 184212 km
Date: 2020.12.07
Time: 09:56:37
Voltage terminal 30: 13.19 V
Outside temperature: 28.5 °C
Right Rear Upper Body Vent Motor-Act.val.: 9849
Right Rear Upper Body Vent Motor-Target value: 9849
Right Rear Upper Body Vent Motor-Stop open: 11400
Right Rear Upper Body Vent Motor-Stop closed: 10000
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006129999
Coding: 00781B0000006001000001010101102030303232203232
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200UA850
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070AD30D994883E85-8078
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011F16205E01628002080002
Shop #: WSC 02312 785 00200
VCID: 40D94367AA8BB5EB333-8014
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 83
Mileage: 184031 km
Date: 2020.12.02
Time: 18:31:05
02116 - Mirror Adjusting Motor
Fault Status: 00100111
Reset counter: 89
Mileage: 184031 km
Date: 2020.12.02
Time: 18:31:05
02117 - Motor for Mirror Folding
Reset counter: 83
Mileage: 184031 km
Date: 2020.12.02
Time: 18:31:05
Reset counter: 89
Mileage: 184031 km
Date: 2020.12.02
Time: 18:31:05
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0010073316
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D19AF14A7177BB57-8066
Revision: 00002001 Serial number: 0149428872
Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
014 - Defective
Fault Status: 01101110
Reset counter: 44
Mileage: 184600 km
Date: 2020.12.12
Time: 18:33:23
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
VCID: 3FDB409BD775CA134A9-806A
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000070722
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D01CF3C775FBB0D7-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 110502-0004-033
Coding: 1121A633F918EB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H02 0008
Coding: 1D0000
0033 - Adjusting Motor for Variable Lighting Right
C1097 11 [137] - Short to Ground
Reset counter: 50
Mileage: 184703 km
Date: 2020.12.30
Time: 22:44:53
0061 - Function Restriction due to Implausible Message(s)
U1112 00 [137] - -
[Fehlerhafter DLC der CAN-Messages Kamera_Status (0x318)]
Reset counter: 50
Mileage: 184703 km
Date: 2020.12.30
Time: 22:44:49
392967 - Positioning Motor for Headlight Range Right
C1086 11 [137] - Short to Ground
Reset counter: 50
Mileage: 184703 km
Date: 2020.12.30
Time: 22:44:53
571908 - Power Output Module for Right Headlamp
C1082 31 [137] - No Signal
Reset counter: 50
Mileage: 184703 km
Date: 2020.12.30
Time: 22:44:48
672263 - Positioning Motor for Dynamic Cornering Light Right
C1088 11 [137] - Short to Ground
Reset counter: 50
Mileage: 184703 km
Date: 2020.12.30
Time: 22:44:53
Part No SW: 4G0 035 056 A HW: 4G0 035 056
Component: Radio U STD H52 0050
Revision: AB001007 Serial number: 051EY0B7516476
Coding: 010003020100000001
VCID: 1F1BE01B77B5AA136A9-804A
Part No SW: 4G0 035 670 B HW: 4G0 035 670
Component: H-BNT-EU H46 0239
Revision: -------- Serial number: 428EX0B7514227
Coding: 050101000003E1EF45108B3E000000030000010000000000
VCID: 221DE9EF44C787FB457-8076
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300QPJ1
Subsystem 3 - Part No SW: 4G2 919 612 L HW: 4G2 919 612 L
Component: E380 BDT C7 H08 0120
Serial number: 90349KDT0007U
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F14204001628002080002
VCID: 42DD496FA487A7FB257-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J14F0S1
Coding: 1020004
VCID: 2517F2F359E970C3205-8070
Component: TSG HR H03 0210
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Coding: 64040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B2F315E9B0C3E05-8030
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Reset counter: 83
Mileage: 184596 km
Date: 2020.12.12
Time: 13:15:17
Outside temperature: -26.5 °C
Voltage terminal 15: 13.2 V
Control Module temperature: 49.0 °C
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBD0DBC7157A939A9-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9D3A7DA2B656B833-8024
End----------(Elapsed Time: 02:15, VBatt start/end: 14.2V/14.2V)-----------
Wednesday,30,December,2020,22:50:44:34670
Gateway Installation List: 4G0 907 468 C
