2012 VW Passat Adblue reset
iltdi
C?ID=192198
Posting this up, hoping someone can help out, i have a 2012 passat the low adblue indicator is on and will not go off despite filling tank to the top.
The first thing that i was informed to try was to leave the key on for 30 sec to a min in the on position without starting, then turn to the off position for the same time period. Then start the car to see if the light goes off. As of yet no luck.
Other things i have tried with the vagcom is to go to engine, basic settings, reset the scr lock and Resetting of SCR tank level detection? The first time i have done this it works without error, but the light remains, the next time i try it again without logging completely out, i get the error of "Service not supported in active session". So i log all the way out of vcds and am able to run again with the same results, ie successful, "Finished Correctly End system ok", but the light remains, 20 miles till no engine start.
I also tried the output tests on pump for reducing agents, the message i get is "Aborted for safety reasons"
Anyone have any ideas on how to get the light to go away or to reset the no restart portion, car was run low with adblue then sitting for winter. Do i need to prime the system somehow, disconnect the battery or ?
Thanks in advance
iltdi
C?ID=192198
codes
does this one have anything to do with it? i have other codes that are not related ie tpms, bulbs out etc, this is all im seeing that may be something?
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
00484 - Vehicle Position Recognition Control Module (J603)
Reset counter: 153
Mileage: 45989 km
Date: 2015.01.27
Time: 21:21:28
Bruce
Near Philadelphia, PA, USA
Are there any fault codes?
Please post up an Auto-Scan.
Hard to say... you have not posted the Autoscan requested. Please do so. If you do not know how, please read the thread linked in Uwe's message. An Autoscan gives us details about the car which we can not divine through the ether of the interwebs without your help. ;)
iltdi
C?ID=192198
Chassis Type: A3 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWBN7A37CCxxxxxx   Mileage: 46000km-28583miles
03-ABS Brakes -- Status: Malfunction 0010 tpms as i have aftermarket wheels need to disable
09-Cent. Elect. -- Status: Malfunction 0010 bulbs ie recall and led lights?
15-Airbags -- Status: Malfunction 0010 aware of this
1C-Position Sensing -- Status: Cannot be reached 1100
Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
   Part No SW: 03L 906 012     HW: 03L 907 309 S
   Component: R4 2,0L EDC   H21 2157
   Revision: 71H21---    Serial number:
   Coding: 00190012042400000000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM20TDI01103L906012 004009
   ROD: EV_ECM20TDI01103L906012.rod
   VCID: 61C9722070FB4429011-8034
   Revision: 00H31001
   Coding: C54BC0F549290003A31303E5921A0042A71000
   VCID: 7DF12E50E44380C9059-8028
                    Reset counter: 196
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:23
                    Count: 2
                    Count: 2
                    Count: 20480
                    Count: 16390
                    Count: 43264
                    Count: 512
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 154
                    Mileage: 45989 km
                    Date: 2015.01.29
                    Time: 19:31:49
                    Count: 4608
                    Count: 16401
                    Count: 51200
                    Count: 12056
                    Count: 2053
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001002
   VCID: 1C3703D4171929C1927-8049
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0064
   Revision: BH021001
   Coding: 6F200EB8902908D408880001160004480071008650A00560648040000C70
   VCID: 438598A8C227363933D-8016
   Component: RLS 210312 05  54  0403
   Coding: 22300A
                    Reset counter: 196
                    Mileage: 46007 km
                    Date: 2015.02.16
                    Time: 00:11:21
                        Term 15 Off
                    Voltage: 8.50 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 23:42:21
                    Voltage: 13.80 V
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 23:42:21
                    Voltage: 13.95 V
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 23:42:25
                    Voltage: 14.20 V
01339 - Door Warning Light
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:26
                    Voltage: 12.10 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM024E0$
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 6FED0418B62FE259875-803A
   Serial number: 3572MSME05356369ZZZU
   Serial number: 3582MSME6227106AZZZS
   Serial number: 3516KSME57562D17ZZZZ
   Serial number: 3526KSME6019271AZZZQ
   Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3556LSME421F2515ZZZT
   Serial number: 3566LSME0A012515ZZZJ
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:24
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [137] - Resistance Too High
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:25
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [137] - Resistance Too High
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:25
9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:26
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20120127101640
   Coding: 008A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76E3317CC975D391443-8023
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Coding: 231C00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 1A3B05CC1D2D57F180B-804F
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 31031201290081
   Coding: 461000
   VCID: 3D71EE50A4C340C9459-8068
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:28
Address 1C: Position Sensing
   Component: IMMO          H07 0507
   VCID: 6ADB150C8DCD0771D0B-803F
   Revision: 13110009    Serial number: 0004093713
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BB540C852976EF95BD-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
67584 - Warning Light for Front Door
          B11F5 01 [009] - Electrical Failure
                    Fault Frequency: 12
                    Reset counter: 156
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:22
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:22
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 377DFC7846FF6A999F5-8062
   Component: EZE_2         H40 1623
   Coding: 00000008
   VCID: 6FED0418BE2FE259875-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0004
   Revision: 15110009    Serial number: 0004255251
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CB743D4579969C1527-8009
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Reset counter: 154
                    Reset counter: 153
                    Mileage: 45989 km
                    Date: 2015.01.27
                    Time: 21:21:22
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7M3274251
   Coding: 0500040004000B
   VCID: 63C5782862E7563913D-8036
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661964617
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
   VCID: 275D2C385E5FFA190F5-8072
End-------------------------(Elapsed Time: 02:36)--------------------------
roth
C?ID=242642
My friend,
Watch this :cool:
BR, Andy
OK, he fixed it. I need to poke around in what we know about this engine this afternoon.
roth
C?ID=242642
It supposed to reset itself. Light comes on, add AdBlue, light supposed go out by itself after a short time.
Andy
Yes, I agree. That's why I was adamant about seeing an Auto-Scan, to see if there were any fault codes related to the reductant system. We had a guy with a ~2009 Touareg not that long ago who thought VCDS didn't work right because it couldn't reset his AdBlue light and mileage counter. Of course, there were actual problems with his AdBlue injection system. Unfortunately, this car doesn't seem to have any such fault codes. So the next thing to do is to start poking around the measuring values. After lunch, I plan to do some digging to see what values might be useful to look at. I will also have access to a 2013 NMS TDI next week.
iltdi
C?ID=192198
Great thanks, cant drive it until we figure it out, so im hoping its out soon. Should i leave it run in the driveway for a while see if that does anything?
roth
C?ID=242642
1 thing comes to mind. What fluid did you use? This system has a reductant quality sensor. If it does not like the fluid you used it might not register the new level.
I wonder if this could be found out with VCDS.
BR, Andy
[Select]
[01-Engine]
[Advanced Measuring Values]
Scroll down the list to "448,Reducing agent fill level"
Put a check-mark in the box and let us know what it says.
Also maybe:
453,Reducing agent tank fill level indicator
458,Remaining engine starts until reducing agent deficiency
459,Remaining vehicle distance until reducing agent deficiency
467,Sensor for reducing agent fill level; fill level
468,Sensor for reducing agent tank temperature
505,Status of a reducing agent warning
You can put a check-mark in the boxes next to all of these at once, and click [Save] when they are showing values. Please post the resulting data here.
iltdi
C?ID=192198
Address 01: Engine (03L 906 012 )
14:22:06
448 Reducing agent fill level 100.01 %
453 Reducing agent tank fill level indicator; raw value 100.00 %
458 Remaining engine starts until reducing agent deficiency-Bit 0 25
459 Remaining vehicle distance until reducing agent deficiency 29.95 km
467 Sensor for reducing agent fill level; fill level 77.83 %
468 Sensor for reducing agent tank temperature; temperature 9.5 °C
505 Status of a reducing agent warning-Bit 0 53
507 Status of actuator test not active
OK, I'm stumped. Your ECU thinks the at least 78% full, or maybe 100%. Why you only have 25 engine starts and 29.95 km remaining is a puzzler.
I wonder if your ECU SW is up to date?
iltdi
C?ID=192198
how would i check this or update it if it needs it? would letting it run in the driveway help it sense the fluid, i replaced the sensor and all fluid was out of the system when i put a new one in. Could this have anything to do with it?
The only way to be sure would be to let a dealer check.
I suppose it might, especially if the repair wasn't done properly. What's surprising is no DTCs.
I did find data from another 2012 car with the same ECU. It seems 25 engine starts remaining is normal, but the remaining mileage is not; that other car had 9095.25 km remaining. ;)
iltdi
C?ID=192198
Its running now see if a dtc pops up, maybe i need to drive it with no miles left to reset it this way or others mentioned?
the codes prior to ad blue sensor replaced was:
9645, was the pressure to low, put in a new adblue sensor, and cleared it. no codes came back, just not sure if should leave the car running or not or if im limited on how many startups etc. ?
17262 terminal 30 open circuit? when i cleared the above this went away as well
is their coding when swaping this sensor out that needs to be done?
Gone But Not Forgotten
Please recode this ecu and see if it defaults this after a key cycle.
0x01-07
Make sure you change the WSC so you see the change and please make sure the tester# importer # and device # are setup in config.
As per PM please see this thread about what I am talking about that you requested.
http://forums.ross-tech.com/showthread.php?2610-2008-Tiguan-Engine-fault-cose-and-no-front-speakers
Also 2157 looks like the update firmware was done from prior level, however, I am unsure if there is an update after this currently........but don't think so.
NEtech
Denmark
C?ID=56995
As Jack mentioned in #19, or delete DTC (even that there are none).
Other suggestions:
- Ignition ON for 10 minutes, OFF, then drive.
- Check Measuring Values "Status of reduction agent level" / "Status of a reducing agent warning" (if available!)
- Basic settings "Resetting of SCR tank level detection"
