@MELenium: Hi. From your auto-scan it's clear that your version A1 has the same 5QX-959-X92 series passenger door module as other platform cars like the Golf mk7 and Audi A3 8V. This suggests that perhaps the same tweak instructions might work on your car. However before changing code and as other car owner have found, it's important to first establish if your hex52 module has a memory module. The memory module is used to store the forward mirror co-ordinates after the mirror-dip returns to its original position. Users of other cars fave found that without the memory module installed, the tweak won't work at all, or the mirror won't return to its correct position.
The check is done by selecting the hex52 module and choosing
Advanced Measuring Values option in . In the search box at the top of the function list, enter the term "memory" and tick the 4 x selectable functions @ location 044-047 (see the right-side of the picture below)
If your module has a memory function, you should see the values on the left-side of the picture below (note: the X/Y coordinate values can be different, but they can't be 255):
If the memory module is not installed, the values will be as shown on the left-side below (ignore the right-side of the picture below -this screen was generated by the hex42 module):
