Hello: Looking for input on an issue I created. I installed APR's Stage3 kit on my 2016 Golf R and after installing the high output LPFP my gas gauge no longer works. I checked to ensure the arm moves freely and ensured the wires are connected tightly. Any input would be greatly appreciated. Thanks in advance!
IDE03473-IDE00730 tank sensor-Fuel level sensor 1 including soiling resistance 510 Ohm
IDE03473-IDE00731 tank sensor-Fuel level sensor 2 including soiling resistance 268 Ohm
IDE03473-IDE00732 tank sensor-Fuel level sensor 1 soiling resistance 412 Ohm
IDE03473-IDE00733 tank sensor-Fuel level sensor 2 soiling resistance 0 Ohm
IDE03473-MAS03798 tank sensor-Raw value sensor 1 resistor 1 3410
IDE03473-MAS03799 tank sensor-Raw value sensor 1 resistor 2 3410
IDE03473-MAS03800 tank sensor-Raw value sensor 2 resistor 1 2354
IDE03473-MAS03801 tank sensor-Raw value sensor 2 resistor 2 1093
Address 01: Engine Labels: 06K-907-425-V1.clb
Control Module Part Number: 8V0 906 259 H HW: 06K 907 425 E
Component and/or Version: 2.0l R4 TFSI H13 0002
Software Coding: 091900122446000E3004
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003 (VW37)
ROD: EV_ECM20TFS0208V0906259H.rod
VCID: C58B49DB44B7D7ACF0-8090
23086 - Fuel Level Sensor Circuit
P0463 00 [039] - Signal too High
Mileage: 55190 km
Date: 2021.01.10
Time: 18:57:39
Engine RPM: 0.00 /min
Coolant temperature: 47 °C
Intake air temperature: 43 °C
Ambient air pressure: 870 mbar
Voltage terminal 30: 12.421 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 86 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.015625 %
FUP_H_SAE: 7260.0 kPa
22063 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [039] - -
Mileage: 55190 km
Date: 2021.01.10
Time: 18:57:27
Voltage terminal 30: 12.441 V
ECU_STATE: ENG_STOP
Engine oil temperature: 49.0 °C
Time since engine start: 0.0 s
T_ES: 4 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
ECU_STATE: ENG_STOP
22092 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [039] - -
Mileage: 55190 km
Date: 2021.01.10
Time: 18:57:27
ECU_STATE: ENG_STOP
T_ES: 4 min
ECU_STATE: ENG_STOP
Readiness: 1110 0101
