I had problem with G195 G196 giving intermittent error code and car could not be driven over 60kmh
Now I replaced Mechatronic and its asking basic settings and giving fault codes for them.
I tried VCDS guide, car running on idle, P on lever and brake applied.
I go to settings and go to 061 and press go, it tries to do something, then car starts to judder like its engaging clutch and it goes on until car stalls and shuts down.
I cannot get this one. I tried to do also 060 it does it and says ok but when I leave the screen and come back, its gone again?
Am I doing something wrong?
Also car is build and uses 02E 6-speed from golf R 2011 MTX gearbox
I thought mecha was busted and installed older mecha from diesel and reprogammed it for golf V gasoline version
Seems like the G195 G196 was not mecha fault, any ideas? can it be the magnetic ring?
but mostly what can I do to get the basic settings done?
Sunday, 10 January 2021, 21:48:29:50763
VCDS-Lite Version: Release 1.2
Control Module Part Number: 02E 300 042 M
Component and/or Version: GSG DSG 081 0824
Software Coding: 0000020
Work Shop Code: WSC 44551
VCID: 1D4D9C3C84A9
003 - Mechanical Failure
VCID: 1D4D9C3C84A9
17106 - Transmission Output Speed Sensor (G195): No Signal
P0722 - 000 - - - Intermittent
18201 - Transmission Output Speed Sensor 2 (G196): No Signal
P1793 - 000 - - - Intermittent
