Hi guys, today I had car from title.
1. Car came with windows problem: only rear right window was possible to close via 2nd click on window control button, for others windows you had to hold button until window is all way up/down, or it stops when you release button. There were only DTC for rear right window missing basic setting. I went to module 42 Door Elect. Driver, Basic Setting, front driver side window and reset adaptation and standardization. When procedures were launched, I rolled window all the way down, release button, held it again for few secs in DOWN positon and released it, rolled all the way up, released button and again held it in the UP position for few seconds. When went to rear left window, I received error REQUEST OUT OF RANGE. After that I went to module 52 Door Elect. Pass. and did same steps for both front and rear windows. Now all windows except rear left window works great, 2nd click rolls them up/down without holding button, but rear left window doesn't work. Also, windows comfort opening/closing doesn't work, and it didn't work before my coding. Everything is set to active, comfort closing is set to ALL via Navi settings for CAR, but it doesn't work.
Also if I change mirror folding mode to "by look command.." mirrors fold successfully when car is locked, but if I change it to "by convenience..", mirrors are not folded when holding lock button on key after locking the car.
Here is auto-scan before coding:
Thank you!
P. S. Please change thread title, only problem with windows
Sunday,10,January,2021,13:18:35:52361
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: VSSZZZ5FZER095512 License Plate: Seat Leon 5F mk3 2014 FR
Mileage: 174663km-108530mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A5
VIN: VSSZZZ5FZER095512 Mileage: 174663km-108530miles
Address 01: Engine (J623-CHPA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 F HW: 04E 907 309 A
Component: 1,4l R4 TSI H08 7603
Revision: WAH08---
Coding: 01190032234401080000
Shop #: WSC 00049 770 00123
ASAM Dataset: EV_ECM14TFS01104E906016F 002010
ROD: EV_ECM14TFS01104E906016F.rod
VCID: 2517F522456DCEB3204-8070
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 60444000000D70
Coding: 20EE6A9224292971007C060141C5240456249400608224F2F421F070C009
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4BC3639A8349D8C3D60-801E
Part No SW: 5F0 907 044 E HW: 5F0 907 044 E
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 00000004200100011105004000101000
Shop #: WSC 00049 770 00106
ASAM Dataset: EV_ACClimaBHBVW37X 003017
VCID: 2809FC16327FD3DB1B2-807C
Air quality sensor:
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011404101295
Coding: 08000B46424302FB4BE44000401C07281000000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
VCID: 7BA3F35A9369A843260-802E
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140125 041 0574
Serial number: 140129091338
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M12D13H23M15S59S7
Coding: 00885D
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331405200039
Coding: 0071051001
VCID: 3E253A4EC0FB7D6B41E-806A
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0200
Serial number: 17011477030658
Coding: 00200600FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001014
VCID: 3635226EE8CBB52B99E-8062
Part No SW: 3Q0 959 655 AB HW: 3Q0 959 655 AB
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P3P1CUJVK
Coding: 98FCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EA5FA4E807BBD6B01E-802A
Subsystem 1 - Part No SW: ----------- HW: 454 002 202 14
Serial number: 3576U000000A57580F0F
Subsystem 2 - Part No SW: ----------- HW: 454 002 202 14
Serial number: 3586U0000007B23DCE0S
Subsystem 3 - Part No SW: ----------- HW: 454 801 902 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R891B1203000000Y
Subsystem 4 - Part No SW: ----------- HW: 454 802 002 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R9E5C12030000003
Subsystem 5 - Part No SW: ----------- HW: 454 800 202 14
Component: FrontSensor_D 114 0149
Serial number: 3556V62CCD802000000J
Part No SW: 5Q0 953 507 DL HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 12021408491255
Coding: 6C00
ROD: EV_SMLSKLOMQB_018_SK37.rod
VCID: 03538BBAEB99D0836E0-8056
Part No SW: 5F0 920 871 HW: 5F0 920 871
Component: KOMBI 303 2210
Coding: 07AD02006D80020801887A03000000
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 6695B22EF8EB05ABE9E-8032
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001643745
Coding: 030100F42B085700EF0006D8080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB474AC7F174634A8-806A
Generator:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0455200114
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 7487142503
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000092146204
Coding: 00110320DE00040000001000
VCID: 44D148A6AE1717BB17A-8010
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001756222
Coding: 390000
589827 - Window Regulator; Rear Driver Side
B131F 54 [009] - Missing Calibration / Basic Setting
Reset counter: 103
Mileage: 174663 km
Date: 2021.01.10
Time: 13:11:59
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 9103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF41B2B10502933CC-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000090661292
VCID: 43D34BBAAB1910832E0-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001774096
Coding: 290000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 048A000009000000
VCID: 75B7E562B54DFE33504-8020
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 846 A HW: 5F0 035 846 A
Component: MU-S-N-ER 040 0425
Serial number: E1F01902142757
Coding: 04730001FF0A000021110001000800002F0101040100010046
ASAM Dataset: EV_MUStd6C3PASE 002029
ROD: EV_MUStd6C3PASE.rod
VCID: 2615F22E386BC5AB29E-8072
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H51 0022
Serial number: SEZ8Z9PL400WEJ
Subsystem 2 - Part No SW: 5F0 919 866 F HW: -----------
Component: ECE 2014 --- 0036
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H05 0052
Serial number: 10000037787
Coding: 0100010001020304000500000100000100
ROD: EV_MFKBoschAU370.rod
VCID: 3B23335AD3E96843660-806E
End----------(Elapsed Time: 01:14, VBatt start/end: 12.3V/12.3V)-----------
Thank you!
