- Nov 28, 2020
- 3
- 1
- Brick, NJ, USA
- C?ID=189920
My 2006 A8 I acquired did have some water intrusion via the sunroof being left open. There was enough water exposure to puddle in both the front driver side and passenger side floors. I did remove the carpets to dry everything out and opened the modules that are in those areas and they did not appear to be wet/damaged. When I originally received the car there was intermittent audio with only volume control available when and if it worked and the system would turn on then shut down by itself. This is not the original battery in the car, it has a Deka battery in it and whether that battery is compatible and if it's been coded, I'm not sure. I've been online and searching around to try and resolve the issue with this and I have changed the printed circuit board on the MMI in the center console and still do not have any improvements. There's no illumination on the buttons of the controls for the MMI as well, nor does the screen/display open. I did do a scan which I pasted below .... I apologize for that.... I want to focus on restoring the MMI and will tackle the other issues down the road. The optical bus diag shows electrical error only on the control head and errors on everything on the optical. Is there a way to positively identify this as the issue? Or should I try something before replacing that?
Saturday,09,January,2021,14:31:32:31671
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WAULL44E56N010100 License Plate:
Mileage: 231280km-143710mi Repair Order: 1-09-21
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E56N010100 Mileage: 231280km-143710miles
06-Seat Mem. Pass -- Status: Malfunction 1010
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Sporadic communication error 1000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E7772529
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E0505188C10FE0BD1E-807A
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Mileage: 231279 km
RPM: 1627 /min
Load: 36.5 %
Temperature: 0.0°C
Temperature: 3.0°C
Absolute Pres.: 0.0 mbar
Voltage: 11.430 V
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit - Intermittent
Mileage: 231285 km
RPM: 779 /min
Load: 38.8 %
Temperature: 90.0°C
Temperature: 26.0°C
Voltage: 13.843 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Fault Status: 01101000
Mileage: 231286 km
RPM: 1425 /min
Load: 53.3 %
Temperature: 0.0°C
Temperature: 3.0°C
Voltage: 11.176 V
18010 - Power Supply Terminal 30
Temperature: -40.0°C
Voltage: 0.000 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0065390
Coding: 0000002
VCID: 2517FA34D9E6BD53204-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 221DE128C8C84A6B456-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H07 0160
Revision: 01604707 Serial number: AUX3Z0E7772529
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58E983C0DE14D0BB6B2-800C
Component: ELV XXXX
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:20
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: 2411E730D2DC445B37A-8070
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 230
Date: 2005.01.01
Address 07: Control Head
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000074911
Coding: 1052993
VCID: 1C61DFD0EAAC7C9B8FA-8048
00003 - Control Module
Fault Status: 00100011
Reset counter: 216
Mileage: 231228 km
Date: 2020.04.18
Time: 00:01:42
Temperature: 39.0°C
01854 - Heated Seat; Front Right (Z46)
Fault Status: 00101011
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.24
Time: 05:04:39
Temperature: 10.0°C
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
Fault Status: 00101010
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.24
Time: 05:04:39
Temperature: 10.0°C
01853 - Heated Seat; Left Front (Z45)
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.25
Time: 01:50:40
Temperature: 7.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.25
Time: 01:50:40
Temperature: 7.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 L HW: 4E1 955 113 B
Component: ILM Fahrer H13 0210
Coding: 0143123
VCID: 313F1E649D2EE1F3CCC-8064
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Fault Status: 00100001
Reset counter: 229
Mileage: 231286 km
Date: 2020.08.25
Time: 00:00:06
01494 - Bulb for Parking Lamps; Left (M1)
Fault Status: 01101010
Reset counter: 191
Mileage: 231286 km
Date: 2020.08.25
Time: 00:34:20
Reset counter: 229
Mileage: 231286 km
Date: 2020.08.25
Time: 00:00:06
00908 - Control Module for Wiper Motor
Reset counter: 230
Reset counter: 229
Mileage: 231286 km
Date: 2020.08.25
Time: 00:00:06
Address 0E: Media Player 1
Address 0F: Digital Radio
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0001LFU
Coding: 0532707
Shop #: WSC 19400 444 84312
VCID: 2615FD38A4E0B64B29E-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 34WK3
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB400808C68Kÿ†63
Subsystem 5 - Serial number: 08C68Kÿ†63428RB400808A3BJÿ†63
Subsystem 6 - Serial number: 08A3BJÿ†63528RB400807E9CUÿ†63
Subsystem 7 - Serial number: 07E9CUÿ†63628RB40080867DNÿ†63
Subsystem 8 - Serial number: 0867DNÿ†63729RB4009E6DF52ÿ†63
Subsystem 9 - Serial number: E6DF52ÿ†63829RB4009E6E5A%ÿ
Subsystem 10 - Serial number: E6E5A%ÿ
8 Faults Found:
02511 - Control Module for Seat Occupied Recognition (J706)
004 - No Signal/Communication - Intermittent - MIL ON
Fault Status: 10100100
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:14
008 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10101000
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:15
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
010 - Open or Short to Plus - Intermittent - MIL ON
Fault Status: 10101010
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:15
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100001
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:16
01218 - Side Airbag Igniter; Passenger Side (N200)
Fault Status: 11100001
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:16
00592 - Seat Belt Switch; Passenger (E25)
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:17
00591 - Seat Belt Switch; Driver (E24)
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:18
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
Fault Status: 00101001
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.25
Time: 00:02:02
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 6597BA3499667D53E04-8030
Component: Lenkradmodul H07 0080
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.31
Time: 23:17:28
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3E8000539
Coding: 0048263
Shop #: WSC 54143 003 1048576
VCID: 323D11689828DAEBB56-8066
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.31
Time: 23:11:10
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 190030582280FF
Coding: FCFE7BDD1B7904
VCID: 270BF03CA3EAAF43128-8072
Reset counter: 229
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:15
00461 - Control Module for Seat Memory; Passenger (J521)
Fault Frequency: 9
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.25
Time: 03:55:19
00384 - Optical Databus
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.25
Time: 00:15:54
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:20
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A0D0908B0F8922B0D6-807E
Component: Sitzmemory FS H01 0010
Coding: 4071530
Address 37: Navigation
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000519400066
Coding: 0003477
VCID: 1D67D2D4F1B67593784-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCID: 2019EB20C6C4587B532-8074
Fault Frequency: 0
Fault Frequency: 0
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.24
Time: 05:03:06
01482 - Motors for Central Locking
Fault Status: 00100111
Fault Frequency: 0
Mileage: 231280 km
Date: 2020.08.25
Time: 00:00:14
02111 - Motor for Window Regulator
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W041709060003
Coding: 0048702
Shop #: WSC 57812 001 1048576
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0050
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
Fault Status: 01101001
Reset counter: 191
Mileage: 176703 km
Date: 2019.03.17
Time: 02:17:54
Fault Status: 01101100
Reset counter: 190
Mileage: 231286 km
Date: 2020.08.25
Time: 04:07:00
Reset counter: 230
Mileage: 231286 km
Address 47: Sound System
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H10 0070
Revision: Serial number: 00000000068924
Coding: 0010111
VCID: 1E65D5D8FCB06E8B61E-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0MZ6E
Fault Status: 00110010
Reset counter: 230
Mileage: 231284 km
Reset counter: 230
Mileage: 231284 km
Date: 2020.08.31
Time: 23:10:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Fault Frequency: 0
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.24
Time: 05:03:06
Fault Frequency: 0
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.24
Time: 05:43:52
Fault Frequency: 0
Mileage: 231280 km
Date: 2020.08.25
Time: 00:00:14
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 08277 003 1048576
02443 - Control Head
Fault Status: 00101100
Reset counter: 230
Voltage: 12.63 V
Count: 40
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 189
Voltage: 9.83 V
Count: 61
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000000091
Shop #: WSC 19400 444 00919
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1509060087
Coding: 344530393135313035412056413031353039303630303837
Shop #: WSC 00000 128 00289
02256 - Quiescent Current
Reset counter: 230
Mileage: 231286 km
Date: 2020.08.25
Time: 11:42:42
02272 - Quiescent Current Stage 1
Mileage: 231286 km
Date: 2020.08.28
Time: 07:52:04
02273 - Quiescent Current Stage 2
Mileage: 231286 km
Date: 2020.08.28
Time: 07:36:54
02276 - Quiescent Current Stage 5
Mileage: 231286 km
Date: 2020.08.28
Time: 07:35:42
02277 - Quiescent Current Stage 6
Mileage: 231286 km
Date: 2020.08.28
Time: 07:36:02
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
01308 - Control Module for Roof Electronics (J528)
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700033742
Coding: 0232125
VCID: 5F9BA8DCBB3A27832A8-800A
02214 - Tire Pressure Warning
Fault Frequency: 27
Reset counter: 191
Mileage: 231285 km
Date: 2020.08.24
Time: 04:51:38
Temperature: 7.0°C
Error Code: 1280
Pressure: 1.22 bar
Pressure: 2.72 bar
Pressure: 2.02 bar
Pressure: 2.35 bar
Address 67: Voice Control
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 08720523802530
Coding: 0201308
VCID: 2313E42CD7D243634E0-8076
Address 77: Telephone
End----------(Elapsed Time: 01:59, VBatt start/end: 14.2V/14.3V)-----------
Control Module Part Number: 4E0 910 468 B
Component and/or Version: Gateway H10 0080
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK ERROR
07-Control Head ERROR ERROR
0E-Media Player 1 OK ERROR
77-Telephone OK ERROR
47-Sound System OK ERROR
67-Voice Control OK ERROR
56-Radio OK ERROR
37-Navigation OK ERROR
0F-Digital Radio(SAT) OK ERROR
56-Radio OK ERROR
Coding: 0007773
Mileage: 231279 km
RPM: 1627 /min
Load: 36.5 %
Temperature: 0.0°C
Temperature: 3.0°C
Voltage: 11.430 V
Mileage: 231285 km
RPM: 779 /min
Load: 38.8 %
Temperature: 90.0°C
Temperature: 26.0°C
Voltage: 13.843 V
P1653 - 008 -
Mileage: 231286 km
RPM: 1425 /min
Load: 53.3 %
Temperature: 0.0°C
Temperature: 3.0°C
Voltage: 11.176 V
Voltage: 0.000 V
Coding: 0000002
Coding: 0008597
Coding: 0410624
Component: ELV XXXX
Coding: 4071520
Coding: 1052993
Reset counter: 216
Mileage: 231228 km
Date: 2020.04.18
Time: 00:01:42
Temperature: 39.0°C
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.24
Time: 05:04:39
Temperature: 10.0°C
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.24
Time: 05:04:39
Temperature: 10.0°C
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.25
Time: 01:50:40
Temperature: 7.0°C
Reset counter: 229
Mileage: 231285 km
Date: 2020.08.25
Time: 01:50:40
Temperature: 7.0°C
Coding: 0143123
Coding: 00000037
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Reset counter: 229
Mileage: 231286 km
Date: 2020.08.25
Time: 00:00:06
Reset counter: 191
Mileage: 231286 km
Date: 2020.08.25
Time: 00:34:20
Reset counter: 229
Mileage: 231286 km
Date: 2020.08.25
Time: 00:00:06
Reset counter: 230
Reset counter: 229
Mileage: 231286 km
Date: 2020.08.25
Time: 00:00:06
Coding: 0532707
Mileage: 231286 km
Date: 2020.08.25
Time: 00:56:04
Coding: 0012141
Coding: 0048263
Reset counter: 191
Mileage: 231286 km
Date: 2020.08.25
Time: 01:13:24
Coding: 0410624
Component: ELV XXXX
Coding: 0015510
Coding: 4071530
Coding: 0003477
Coding: 0032364
Fault Frequency: 0
Fault Frequency: 0
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.24
Time: 05:03:06
Fault Frequency: 0
Mileage: 231280 km
Date: 2020.08.25
Time: 00:00:14
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Coding: 0048702
Reset counter: 191
Mileage: 176703 km
Date: 2019.03.17
Time: 02:17:54
Reset counter: 190
Mileage: 231286 km
Date: 2020.08.25
Time: 04:07:00
Coding: 0010111
Coding: 0032364
Fault Frequency: 0
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.24
Time: 05:03:06
Fault Frequency: 0
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.24
Time: 05:43:52
Fault Frequency: 0
Mileage: 231280 km
Date: 2020.08.25
Time: 00:00:14
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Revision: --H03---
Coding: 0000532
Reset counter: 189
Voltage: 9.83 V
Count: 61
Coding: 0000018
Address 56: Radio
Coding: 0032364
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Coding: 0232125
Fault Frequency: 32
Reset counter: 191
Mileage: 231285 km
Date: 2020.08.24
Time: 04:51:38
Temperature: 7.0°C
Error Code: 1280
Pressure: 1.22 bar
Pressure: 2.72 bar
Pressure: 2.02 bar
Pressure: 2.35 bar
Coding: 0032364
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Reset counter: 230
Mileage: 231280 km
Date: 2020.08.31
Time: 23:10:56
Coding: 0201308
End----------(Elapsed Time: 01:56, VBatt start/end: 14.4V/14.3V)-----------
