Would anyone know how I can activate having the wiper service position setting added to my MMI menu? I did some looking and could not find the combination of adaptations and coding values to get it to show up in the Car section of the MMI?
2017 8V S3:
2017 8V S3:
VCDS Version: 20.12.0.1 (x64) HEX-NET CB: 0.4529.4
VIN: WAUF1GFF7H10xxxxx License Plate: 123
Mileage: 26394km-16400mi Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
47 52 55 5F 6C A5 A9 BB BC CF D6 D7
VIN: WAUF1GFF7H10xxxxx Mileage: 26394km-16400miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 K HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00122466010E3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259K 001004
ROD: EV_ECM20TFS0208V0906259K.rod
VCID: 48DCBF62F351B9C48A-801C
Readiness: 1000 0100
Part No SW: 0D9 300 014 Q HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5006
Revision: 06454104 Serial number: TFK01609201569
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 260011DA59054FB458-8072
P1734 00 [002] - -
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 60267000000107
Coding: 31AA6B7D549E13B14B990B654197698CD62AC8D2D0829673184150D482A812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_070.rod
VCID: 393ACAA6B8BBD04C05-806C
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0430239803
Coding: 030C0C
VCID: 3B36D0AEB287E25C17-806E
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001145276
Coding: 03000014010000001000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 40CCA742DB61818442-8014
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: A4C8CD8800PAG0MUFU03
Part No SW: 5Q0 937 085 BF HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H34 0236
Serial number: 02001702600394
ROD: EV_BCMBOSCH_017.rod
VCID: 7EB019BAE115377470-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 161208 043 0585
Serial number: 161219154000
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62595341
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 13 11 2016 00000497
Serial number: 00000000000037346037
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001EH8TX00000
Coding: 101F00
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617024
Coding: 0470155011
ASAM Dataset: EV_EPHVA18AU3700000 009031
ROD: EV_EPHVA18AU3700000.rod
VCID: 4AD8856AED5D4BD49C-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: B50087C219FFC42474988055000026
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 031216027
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
VCID: 45C2B656C443A4AC71-8010
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR078WEX
VCID: 47DEBC5EFE4FB6BC83-8012
Left seat belt tensioner:
Component: BeltPretRevFL H37 0350
Serial number: 34230167A02021740200
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H37 0350
Serial number: 34230168A02021740405
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001KGSYW
Coding: 303334
Subsystem 4 - Part No SW: ----------- HW: 480 003 101 17
Serial number: 35700000000AEA18112J
Subsystem 5 - Part No SW: ----------- HW: 480 003 101 17
Serial number: 35800000000EEA18112O
Subsystem 6 - Part No SW: ----------- HW: 480 402 301 17
Serial number: 35100019F246A8E484EM
Subsystem 7 - Part No SW: ----------- HW: 480 402 301 17
Serial number: 3520001BD248E893F1ER
Subsystem 8 - Part No SW: ----------- HW: 480 401 411 16
Serial number: 3550002B923C4E5622DC
Subsystem 9 - Part No SW: ----------- HW: 480 402 912 16
Component: FrontSensor_P 001 6149
Serial number: 3560002B723C4E5361B9
Part No SW: 8V0 953 521 KT HW: 5Q0 953 549 E
Revision: -------- Serial number: 01021704401390
Coding: E818
VCID: 1660211AE965DF34C8-8042
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 890 HW: 8V0 920 890
Component: FBenUSA H14 0047
Coding: 08CD18537F88CF050281E8001800000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
VCID: 7AB815AAFD3D1B544C-802E
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Serial number: 30011710800303
Coding: 030100043F085A005B00827CB80B00000001010000000000000000000000
ROD: EV_GatewNF_AU37.rod
VCID: 2F2EF4FE76FF0EFCAB-807A
Generator:
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170128000301 20007
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001605231924
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7755
Serial number: HA1-00011.01.17
Coding: 0001
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H06 0016
ASAM Dataset: EV_LCMLeftCONTIAU426 001008
VCID: 42C8AD4AD56D939454-8016
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000008796010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424FB929FD92D24D6-8060
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001008
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 D HW: 3Q0 907 566
Component: MRR1Rear H16 0410
Revision: --------
Coding: 04C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
Component: TSG FS 020 0041
Serial number: 030117EA301471
Coding: 005D1B205C00048000000003
VCID: 43C6A84ECA779A9C5F-8016
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A38D5AABDBDDB540C-806E
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAGHX00FZC+
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 24040BD22F39BDA446-8070
Component: TSG BFS 020 0041
Serial number: 211216ELK35219
Coding: 005D13205E00048000000003
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Coding: 0EE2021123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E30D9BAA195F77430-806A
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 880 C HW: 8V1 035 880
Component: MU-P-LNS-US 053 1363
Serial number: A702A0HS001534
Coding: 017351020000000011220002041A00102F0027E4017001047E
Shop #: WSC 18478 003 1048576
Subsystem 1 - Part No SW: V03 959 802 DM HW: -----------
Component: NAR 2019/2020 --- 0072
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9G1Y00GB1
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0858
Serial number: ALJAL116121600010695
Compact disc data bank:
Component: Gracenote2 --- 3011
B11CF 53 [009] - Deactivated
Reset counter: 191
Mileage: 26394 km
Date: 2021.01.03
Time: 15:47:21
Voltage terminal 30: 13.0 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Component: RVC Compact H12 0231
Coding: 0273010102002001400040
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 20011711K22916
Coding: 0403070100000201012223468048490080000E200020
ROD: EV_MFKBoschMQBB_VW46.rod
Part No SW: 8V0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 170103200241
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 070117ELD1990B
Coding: 000C13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 070117ELT10092
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 D HW: 3Q0 907 590
Revision: --------
Coding: 04C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
VCID: 3620C19A89A53F34E8-8062
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 177E2C1EEE6FE63CD3-8042
Component: LED1R H09 0008
